(Topic ID: 19065)
Modified Harbor Freight Lift Table
By wizzardz
10 years ago
  • 1,102 posts
  • 347 Pinsiders participating
  • Latest reply 15 days ago by Dakine747
  • Topic is favorited by 388 Pinsiders
    9 key posts have been marked in this topic
    Display key post list sorted by: Post date | Keypost summary | User name
    Post #132 Flagpole hinge mod Instructions Posted by kungfucop (10 years ago)
    Post #194 Brake release mod Posted by edgewerx (8 years ago)
    Post #196 Flagpole hinge mod Instructions Posted by ForceFlow (8 years ago)
    Post #216 elbow mod Instructions Posted by chrisjens2 (8 years ago)
    Post #222 Triangle hinge & bolt mod Instructions Posted by leesparts (8 years ago)
    Post #238 Swivel Tee mod instructions Posted by pinwiztom (7 years ago)
    Post #384 Bimini hinge mod Posted by harryhoudini (5 years ago)
    Post #594 Bimini Cap Mod Instructions Posted by Daditude (4 years ago)
    Post #1036 Adjustment for table not lifting Posted by SirMachismo (5 months ago)
    Topic indices are generated from key posts and maintained by Pinside Editors. For more information, or to become an editor yourself read this post!
    There are 1,102 posts in this topic. You are on page 1 of 23.
    14
    #1 10 years ago
    I bought one of the Harbor Freight 500 lb lift table and love it. The obvious problem is the vertical oriented handle limiting how far under a machine the table can be placed. I normally come at the machine from the side or back when I can to help, and remove the handle as a last resort.
    http://www.harborfreight.com/500-lb-capacity-hydraulic-lift-table-94822.html
    Got some 3/4 inch nipple and 45 degree angle elbow. The elbow screwed into the nipple, and then the nipple really just screwed into the handle mount. I had to grind out the threads to allow the handle to slide into the elbow. I haven't yet, but I'm inclined to grind down the nipple to allow it to just slide into the handle mount, and then drill thru both the handle mount/nipple as well as the handle/elbow and use quick disconnection pins to secure them. This would allow for easy conversion as the vertical handle is actually useful both for moving in tight spaces as well as storage.
    The first pic is where the table can be placed with the handle vertical
    IMG_3324_(Custom).JPGIMG_3324_(Custom).JPG IMG_3322_(Custom).JPGIMG_3322_(Custom).JPG IMG_3319_(Custom).JPGIMG_3319_(Custom).JPG IMG_3325_(Custom).JPGIMG_3325_(Custom).JPG IMG_3314_(Custom).JPGIMG_3314_(Custom).JPG IMG_3318_(Custom).JPGIMG_3318_(Custom).JPG
    #2 10 years ago
    Nice mod. IM about to buy one of these and I think ill do exactly this
    #3 10 years ago
    1000% better than the modified motorcycle lifts.
    Nice job!
    #4 10 years ago
    I will be 100% copying this. thanks for the great mod ! Do you recall the sizes of the threaded fitting and the pipe ?
    #5 10 years ago
    Its a 3/4 x Close. Its about 1 inch of thread on each end (two inch total length) and no bare pipe. If I grind down the threads on one end to fit it in the handle mount, I'll likely need a nipple one inch longer.
    #7 10 years ago
    There is a fair amount of slack available in the cable to drop the table. I was able to move the handle into the elbow without modifying the cable at all. If the cable is too tight, simply loosen the nut holding the cable, move the handle in place, pull the cable tight, give it a little slack, and tighten the nut again.
    #8 10 years ago
    Cart reminds me of ape hangers. I cut the bars all the way down. Works great.
    #9 10 years ago
    Very nice! That will work tons better.
    1 month later
    #11 10 years ago
    Wizzardz I tried your mod and one thing I did not like was that it had to be in that position or removing the mod to put it back to the normal one. I came up with an adjustable mod that I can lock in at any angle. I only had to drill 2 holes in the actual lift handle. Otherwise the only modification I did to the machine itself was I rerouted the cable for the release to NOT be in a couple of the little loops that hold it in place. The cable was too tight\short without doing this. I also removed the spring where you adjust the release cable because it was just in the way.
    removed_1.JPGremoved_1.JPG removed_2.JPGremoved_2.JPG removed_spring.JPGremoved_spring.JPG
    I started with 2 different sizes of Aluminum tube, 1" & 3/4". I flattened the end of the tubes so that I could stick a bolt with some washers and a lock nut on them to hold them together.
    The 1" tube will go into the part of the lift where the origional hand went. I had to hammer it in a bit, remove it and file it down and then hammer it in again to get it far in. No modification to lift here, Just drill a hole in the aluminum tube after it is in using the current hole as a guide. Only drill through the front side of the aluminum tube and use the original bolt to secure it.
    The 3/4" tube will fit inside the original handle, I drilled a hole through the aluminum tube and out the back of the handle (the only real non-reversible modification of the project) using the original hole in the handle as a guide. Used a bolt,washer & nylon locking nut on each to fasten.
    I used a small bolt with some washers (lock washer between the flattened tubes) and a nylon locking nut to fasten each piece of flattened tube to each other. If you need/want to adjust you just loosen nuts, adjust and tighten again.
    #12 10 years ago
    I did the Stanley Hinge version of this mod (Lowes item # 902-6 2C) that someone came up with.
    Been a long time since I assembled it but IIRC, the only extra parts needed are two bolts & two nuts. Super easy mod.
    Folds up nicely and stores underneath a pin.
    No cable re-routing needed--just loosen the release wire from underneath (at its termination point) to give it more slack so it'll be able to fold.
    #13 10 years ago
    I just got a penguin dolly the other day, really like it (but I havent used it too much yet). Anyone having issues with a penguin?
    3 weeks later
    #14 10 years ago
    Thought I'd add to this in order to help the next guy in completing the hinge type conversion.
    Started with the Harbor Freight table
    I bought a set of EB (Home Depot) 6" Heavy Duty Strap Hinge Zinc Plated
    A couple of notes that may help:
    1) I had to drill the factory handle for the mod, I just used a 5/16" bit to drill using the same hole that was already drilled in the handle at the factory as a guide (that hole is only drilled thru one side of the handle) - I just drilled all the way through. NOTE: with this hinge, I needed to run the 5/16" bit thru each of the holes in the hinges that I placed a bolt thru as the bolts were just a tiny bit too large to fit - maybe the Lowes hinge fits "as-is" . . . don't know
    2) Use a titanium bit as the metal is thick and tough on the handle
    3) I used a set of nuts and bolts i had in my hardware drawer to attach the hinge (see pics) to the handle (sorry I don't have the size but any bolt that fits through the hinge snugly and is 1 3/4" long will work (pick up the 2 bolts and nuts while you are in the HD or Lowes store getting the hinge)
    4) Like everyone else, I used the existing bolts to attach the hinge to the cart itself - note from the pics that I had to stack 2 washers just inside the hinge or the bolt would not tighten completely
    5) I absolutely HAD to re-route the cable as it was simply too tight to raise from the flat (folded) position. I also HAD to flip the handle around the other way which brings the cable from the right side of the cart to the left and brings it more in line with the release mechanism . . . thus providing just enough slack to allow the handle to be placed in any position.
    6) To reroute the cable I was prepared to "knock off" the cable loops that are welded onto the cart frame, trust me . . . you will not want to do this, the weld and metal is very strong.
    7) To re-route cable, loosen the cable retention bolt under the cart and then unscrew the cable sheath from the release mechanism, then pull the cable itself out of the bolt AND out of the sheath end.
    8) This allows the cable to be pulled out of the metal cable loops and moved to the other side of the cart
    hinge_edge.JPGhinge_edge.JPG hinge.JPGhinge.JPG hinge_back.JPGhinge_back.JPG cable_reroute.JPGcable_reroute.JPG
    #15 10 years ago
    I have this table and use it more than my dolly by far. But have yet to mod the handle, great stuff, thanks for the ideas
    #16 10 years ago
    Quoted from MT45:
    Thats a good one. I just cut mine down to 24" and curled the cable. It's like dorf
    #17 10 years ago
    I like the storage of this cart better than mine. And those must be the largest ape hangers I have ever seen.
    #18 10 years ago
    Mine was modified by a Florida collector (Kbvette) and it absolutely kicks ass. Kevin welds in a joint and has a sleeve that goes over the joint so you get the best of both worlds with the cart- a full tilt on the handle or a locked up position. Totally bad ass!
    IMG_2892.jpgIMG_2892.jpg IMG_2893.jpgIMG_2893.jpg IMG_2894.jpgIMG_2894.jpg IMG_2895.jpgIMG_2895.jpg
    #19 10 years ago
    I also did the hinge modification. The nice thing about it is the handle lays flat in either direction, so you can have a game sitting on the cart with it all the way lowered. This means you can get the cart centered under the game and not have it unbalanced towards the rear. It also makes it easy to rotate the game up onto its end, or lower it from the its end onto the cart as there is no handle in the way. It also makes it easy for storage under a game, just rotate the handle flat and roll it under. Some pics here: http://kcpins.com/archives/91
    #20 10 years ago
    Install the largest wheels on your cart that will not hit each other when you swivel around to back up.
    I laid my handle down flat so it will slide completely under the play field for a balanced load.Also stores nicely that way. You can also lift it up on the front two wheels for better mobility in tight spaces.
    #22 10 years ago
    Wow I love the wheel mod. how much height does that add? My truck is about 5-6 inches too high for easy loading/unloading. That might be just the ticket
    #23 10 years ago
    Quoted from Modman:
    Where did you get the parts to do this? I like this mod.
    #24 10 years ago
    These wheels are 10" in diameter. Check with your local Harbor Freight, or go online and shop for used ones on Ebay. There will be some minor cutting and welding involved. You'll have to come up with some thin plate steel for pads to mount the wheels to and then weld them as far out on the edge as you can get. Check for rotating clearance before you nail them down...I've used this cart for unloading heavy objects out of the back of pick-ups and with the larger wheels it will go right up most porch steps.
    #25 10 years ago
    Quoted from Modman:
    Interesting idea MM; curious what the fully-extended measurement is?
    Stock HF cart fully extended is 28"; the tail gate on my GMC pickup is 32" (perhaps slightly smaller wheels might work in my example...now how to do it without welding ; another non-welding option would be to build a 4" platform).
    #26 10 years ago
    I'll try this again. Argh.....
    a38eaddcb00beb45817e5b0f5cc355d0.jpga38eaddcb00beb45817e5b0f5cc355d0.jpg 727133cac38b3a2ba9f9d016e2a6bcc0.jpg727133cac38b3a2ba9f9d016e2a6bcc0.jpg
    #27 10 years ago
    Yet another way to go. I just cut the handle down on mine. I've been using this table for over 4 years, I have more than got my money out of it.
    #28 10 years ago
    LMFAO, I like that Marc... if I see that at TPF I'm gonna start calling it the Gimp Cart.
    #29 10 years ago
    Getting some great ideas for my lift table.
    My future build so far; Stanley hinge fold down handle, big ass wheels, neon orange tie down strap. Sweet.
    #30 10 years ago
    Quoted from Frax:
    It will be there and we will use the piss out of it. When setting up 25-30 pins it comes in quite handy! I could actually use 2 at TPF!!
    #31 10 years ago
    Yeah, I really can't believe anyone else didn't think of just cutting the handle like that. I didn't want to have to deal with all the modification but I can cut a freakin' pipe and redrill it...
    IF I can get Rollergames, Shuttle and Time Machine all dialed in I will be trying to bring all 3...but I'm not doing it without a lift table.
    -1
    #32 10 years ago
    This thread inspired me, I whipped this up last night parts I had on hand.
    #33 10 years ago
    Quoted from John_in_NC:
    How is your hinges attached to your handle, and cart?
    #34 10 years ago
    Quoted from Jdawg4422:
    Looks like bolts to me but that may be just too obvious.
    3 weeks later
    #35 10 years ago
    Was at harbor freight today, this is on sale for $160 until 10/31/12
    #36 10 years ago
    Quoted from Prmailers:
    I had a 20% off coupon, got my cart for like $130 or something yesterday.
    #37 10 years ago
    That's a steal!
    #38 10 years ago
    i just got that coupon and am off to HF tomorrow.
    Quoted from Toasterdog:
    3 weeks later
    #39 10 years ago
    Anyone else have an issue with the release valve staying open?
    Mine seems to be messed up. Guess I'll have to make a trip back to HF...
    #40 10 years ago
    Sounds like the release cord needs to be adjusted from the bottom. The release wire is held down by a nut and if you plan on modding it with latches you will have to adjust that anyway to allow the bars to go fully up and down but still tight enough to release when handle is at a 45 degree angle and triggered. The hinges makes the bar lay flat across lift when lowered so you can store it under a pin thats what I like about it. Here is an old thread that I got the idea from:
    http://pinside.com/pinball/forum/topic/pinball-movers
    #41 10 years ago
    Thanks, dude. Tried that. I have since removed the cord, but it still doesn't work properly.
    Gotta spend some time monkeying with it OR schlep it back to HF for a replacement I guess.
    #42 10 years ago
    I wouldn't be in this hobby if...
    1. I didn't have a walk in basement
    2. I didn't have my heavy duty orange lift
    Sidenote: My kids have a ball playing on that lift
    #43 10 years ago
    Same here, underspin.
    Fixed the issue, the part that releases the valve wasn't seated properly.
    All is well.
    J37 on the pic...
    #44 10 years ago
    Just picked up my cart yesterday and unboxed it today, gonna cut the handle down shortly.
    #45 10 years ago
    Cut my handle down like Marc did, I like it this way. It's nice and compact.
    #46 10 years ago
    I took the handle off mine and tossed it.
    I made a release lever out of an old shooter rod.
    The handle is useless and in the way and after a couple of different configurations I realized it wasn't needed.
    #47 10 years ago
    Did the hinge mod to mine yesterday, but I think tracelifter might have the right idea.
    #48 10 years ago
    thread should be called, human mouse traps.
    #49 10 years ago
    I have that problem when I take mine "4wheeling" check the cable seating under the deck. Mine connects to the release lever via a notch that holds the cables barrel termination. My cable sometimes catches on stuff pulling it slightly out of its seating, shortening the cable and holding the lever open.
    #50 10 years ago
    Thanks, johnda. Never thought of looking for that.
    Did fixt it, though. See pic a few posts up...
    This page was printed from https://pinside.com/pinball/forum/topic/modified-harbor-freight-lift-table and we tried optimising it for printing. Some page elements may have been deliberately hidden.
