Quoted from AUKraut:I’ve homebrewed fans and 3D mounts myself for my pins as well as for some friends. Fans on coils has been done since the RGP days, it does help a lot of pins. Mechanical Install itself is simple, sometimes you have clearance variations from pin to pin depending on what is mounted near the flipper mech. Of course there is a bit of electrical work to get 12V to the fans.
I’ve actually made a setup specifically R&M for a friend. Been thinking of offering them up for sale myself if my project list wasn’t so long….
I've 3D printed some myself just to play around with, but have no desire to sell. I (retired) designed RF power stuff that always needed cooled, so sticking a fan on something that needs cooled is not exactly rocket science. On bigger designs, we used water cooling. Sometimes to cool, other times to keep a temperature constant (a temperature variation would affect the system calibration accuracy).
I've worked side-by-side with the thermal engineers for decades and we've thermocoupled the crap out of things to verify our expectations many dozens of times. One thing I haven't seen that would interest me the most is measuring the temperature deep inside the windings (easier said than done). If the core's thermal resistance to the outside world is crappy (i.e. no good thermal path for heat to follow), then the internal temperature could still be toasty, regardless of the surface temperature. Thermal resistance is just what it sounds like (same as electrical, but for thermal instead): High thermal resistance is essentially an insulator. Ideally, you want it low (i.e. the heat trapped in the middle can get out easily).
But I play so lousy it's a moot point if I tried to cool the coils or not.
I hope this didn't sound disparaging to the coil cooler guys, wasn't my intent. More about the dynamics surround cooling something hot.
Edit: Thinking about this more (and reading some articles), a better way to calculate the real coil temperature is to measure the resistance at room, exercise the coil, then remeasure the resistance and work the numbers backwards for internal coil temperature rise. Another option would be to measure current and voltage simultaneously on a scope (use a clamp on current probe for the scope) and figure resistance. Those results are the real numbers that determine how effective coil coolers are.
