New! Dark mode!
(Topic ID: 97183)
mnemonic hand picks up two balls every time
By BlackRabbit
6 years ago
  • 21 posts
  • 10 Pinsiders participating
  • Latest reply 6 years ago by Spies
#1 6 years ago
Hi. My hand goes to the matrix and grabs 2 balls (target ball and adjacent ball magnetically latches on). Anyone know how to fix this? I took the hand apart to confirm switch inside is ok...works perfect in test with ball inside. It worked fine for two years that we owned pin, the one day all of a sudden it does this now. I see plenty of threads about hand issues but not like mine where I pick up double balls.
Thanks in advance for assistance!
#2 6 years ago
Sounds like your balls may be magnetized... Might want to check.
#3 6 years ago
I've owned 2 JM's [still own 1] and both did this. Even with new balls.
If you let the balls drain after a game before starting another, it won't have to go pick up balls locked in another game.
Or you can just enjoy the "Free" 2 ball multiball.
#4 6 years ago
My problem is my wife and I play at the same time. If I lock a couple balls in the matrix and then she locks a couple, the hand has no choice but to remove one since it runs out of balls. It keeps what was in the matrix in memory for multi time but it directs the hand to remove a ball when needed. Never had an issue for years until now. I tried new balls so thanks for idea flaps. Is it possible my pin somehow has increased voltage the the magnet thus creating higher magnet power and grabbing unintended balls? If it does I have no idea how to lower that voltage to the magnet...if it is even possible to do without adding components to do it?
#5 6 years ago
My jm never did this. I am also guessing your balls are magnetized and need replacement.
#6 6 years ago
Quoted from dsuperbee:
Mine doesn't either. You likely have a worn x-nut that is making the whole mechanism sag. This puts the glove closer to the matrix and more likely to pick up a second ball. Replace that nut!
#7 6 years ago
Ok. I will order new balls and x-y nut today. Thanks for the input. I'll update the thread after I install that stuff so if it works other readers can benefit down the road.
#8 6 years ago
Make sure your BIH switch is functioning normally. That is designed to prevent magnetized balls.
#9 6 years ago
Quoted from Pimp77:
I tried this fix with my JM and it didn't work, unfortunately. In my research, it seemed that picking up multiple balls was a common problem on JM. Never found a fix before selling it. Tried everything.
#10 6 years ago
I had this issue on mine and noticed the whole hand assembly (back panel?!) was drooped forward from the weight of many years... so I bent it back away from the playfield(Carefully!) and now it rarely gets two balls when grabbing one from the matrix.
#11 6 years ago
Quoted from Spraynard:
This is not a common problem that all JM have. It indicates your hand is sagging. You'll need to do something to raise it up whether it's just the t-nut or not. Saying this is just how it is isn't right.
#12 6 years ago
Quoted from markmon:
I ordered an x and a y nut today. Did I miss a, "T" nut or is that a typo?
#13 6 years ago
Quoted from nerbflong:
This is pretty interesting. I am going to look into this ( did not say I will try it but going to evaluate). I mean...let's say I replace the x and y (t nut too?) and same issue? I then would be pretty cornered to try a last resort option and maybe this is it. This picking up 2 balls issue really is ruining game play for my wife and I
#14 6 years ago
I have this problem as well. There was some discussion over at the JM owner's club thread about this. Bottom line: I have tried new balls, have brand new X,Y nuts, and have adjusted the hand bracket up as high as it will go...nothing seems to help. One of the folks participating in the other thread suggested putting a varistor in the magnet power circuit and try to find the right amount of resistance that solves the 2 ball pick up problem but still allows the magnet to keep functioning correctly. I have not had a chance to play with that yet.
However, I am definitely going to look into nerbflong's suggestion about the whole mechanism sagging over time. That would be a simple fix if it works. Anyway, I hate to say, but I am glad that I am not the only one with this problem-maybe we can stumble on a solution together!
#15 6 years ago
Just a thought....for those of you having issues with the hand grabbing 2 balls, have you pulled the balls and see how badly they are magnetized? If it can pick up a paperclip, time for new balls. Pinball life has balls for games with magnets for a 1.50 each:
http://www.pinballlife.com/index.php?p=product&id=1325
#16 6 years ago
I tried new balls today and it did not solve my issue. Next comes the x-y nut when it arrives in the mail. Reading what radio said above....I might try that. I have a few dc to dc units around the garage. Nice thing is they are small and adjustable. I could place one inline and regulate the dc voltage down to just enough (hopefully) to pick up one and only one ball. This just might work. Again, I will try the y and x nut replacement first though. I will update this thread so we can all benefit if something can be ruled out or, luckily, if something actually resolves the issue at hand (Sorry, I just could not resist
#17 6 years ago
Yes, let us know how it goes, BlackRabbit. I took a look for sagging in my hand mechanism and could not find anything that I felt I could safely "bend" out. However, I did experiment with letting the matrix sag down by loosening it from the back board at bit. If it worked, my plan was to shim it and then re-tighten it. No dice, though. It still picked up two balls in multi-player mode. I like having 2 balls, but not Johhny's glove.
#18 6 years ago
Just to be clear--I didn't say that all JMs do it, or that it was normal, only that it is a common problem. Which it is.
#19 6 years ago
Yes but solvable.
#20 6 years ago
Quoted from Radiowing:
Radio. I just finished tinkering (without new parts). I hand placed two balls in the matrix at many different positions. With the game on and glass off as soon as I did this the hand march over to pick a ball. This was good since it saved me tons of time messing with the switch and test menus. Anyway, as soon as the hand reach the matrix I quickly reached in and used a finger to lift the hand. I have play at the x and y but I discovered. With this play removed or compensated for by my finger, the magnet only picked up one ball. It appears the distance between matrix and hand is very important and sensitive...on my pin anyway.
I am confident finally that I will resolve this. It all makes sense now. Played perfect for two years then started picking up two balls likely because hand sagged and is now close to matrix which allows the magnetic field to influence/grab near by balls. What caused the hand sag? I think folks here in this thread nailed it. X and y nut wear (friction between but and turn screw). Then the hand has shake or play and sits lower. In addition, like said here, gravity!!! The game, even when idle, has gravity pulling on that heavy hand mass 24 hours/day 7 days/week! Hand sags more. Too bad the engineers did not counter balance that mechanism load or even add an assist spring to help fight the gravitational pull downward.
Oh well. I feel pretty good that when my new y and x but goes in with also some gentle tugs upward to counter the sag, it will work properly again. I will update here either way though.
Thanks for all the great tips everyone!
1 month later
#21 6 years ago
Did the x and y solve your problem BlackRabbit?
$ 279.95
Pin Stadium Pinball Mods
$ 29.00
$ 12.50
Gweem's Mods
$ 50.00
