I looked maybe a mix. but I do see 44 sockets.
This topic is closed.
Rick, will I have to pull off that huge board to fix one bad led or is there a easier workaround? Just looks like a royal pain to a novice like myself.
Quoted from starbase:Rick, will I have to pull off that huge board to fix one bad led or is there a easier workaround? Just looks like a royal pain to a novice like myself.
I believe they are doubling up on LEDs, so if one goes out you won't see it.
Quoted from LTG:I believe they are doubling up on LEDs, so if one goes out you won't see it.
that's pretty neat, but i think i'd rather be able to replace them myself, what if both blow
these are the 30,000+ hour high reliability LEDs ... they're not light incandescent bulbs that blow ... that would be same concern about changing the LED's on your printer or your router or your cable modem, or a gazillion other things ...
smd led's are easy. I've been doing them on xbox/ps3 controllers for years. If you can solder you will have no problem.
Remember when we all used to replace the SMD LEDs in our cell phones to bling them out and make the screens light up blue?
These LEDs will be much larger and easier to work with!
Quoted from PPS:these are the 30,000+ hour high reliability LEDs ... they're not light incandescent bulbs that blow ... that would be same concern about changing the LED's on your printer or your router or your cable modem, or a gazillion other things ...
Yea, but those things do not experience the same degree of shock and vibration that a pinball machine experiences...
Jaz
Surface mount components aren't hard or expensive to fix. Just different. Not a big deal. If someone can't do them at home, pulling the board and taking them to a shop should only be a few bucks.
Quoted from Jazman:Yea, but those things do not experience the same degree of shock and vibration that a pinball machine experiences...
Jaz
I have a lot of LEDs on my car - tail lights, etc. I think road vibration has to be worse than a pin sees.
Jaz
I think you are wrong about this.
SMD LEDs are almost indestructible under a wide range of uses.
Quoted from Wolfmarsh:I think you are wrong about this.
Not saying I know much about the issue, but I am less concerned with the actual LEDs "blowing" than I am with the boards' on which the LEDs are socketed (or whatever is the correct term) requiring repair/maintenance.
I should say, though, that believe it or not, I have never built a pinball machine (yet?).
(still super pumped about my brand new MMR!!!)
Jaz
Your car doesn't burn through the led's...The pin won't have as many vibes or shock as a automobile. The HU, speedo cluster, hvac are all led, have been for years.
Quoted from yotaxi125:Not saying I know much about the issue, but I am less concerned with the actual LEDs "blowing" than I am with the boards' on which the LEDs are socketed (or whatever is the correct term) requiring repair/maintenance.
Boards have been used for years. My 1991 checkpoint has bulb boards. There should be almost zero maintenance for these. Worst case is 15 years later you reflow the header pin solder, or a trace burns out? but that should happen on the cpu board, not a bulb one. Unless something is seriously wrong.
Look guys, I NEVER said that there was a problem. Rick made an analogy between your printer, router, and cable modem. That is a FAR cry from a pinball machine. But, MTBF ratings (ie: the 30K hours) and the like are based on a certain type of use. I am willing to bet there is not a SINGLE LED manufacturer that gives an MTBF for usage in a pinball machine. To simply push the concern aside is careless. That said, most surface mount LEDs are encapsulated so there will likely not be an issue. BUT, not all are 100% encapsulated. Some just have a lens mounted on top of the die that is bonded to the substrate. So, not all surface mount LEDs are created equal. So, just chill.
As far as automotive, one again, NOT ALL PARTS ARE CREATED EQUAL. As a former electronics engineer for the automotive industry, I can't tell you how much work goes into making electronics reliable in the automotive environment. If you think the LEDs that illuminate your cluster are just any old part someone throws in there, then you have no idea what you're talking about. If you knew the extremes that automotive electronics are subjected to, you would be shocked.
Jaz
should conformal coat it to 1) make it more reliable / vibration tolerant, and 2) really make sure nobody can service it.
I guess I assumed when he said High reliable led's with 30k+ hours it was not the chinese ones on ebay...maybe I'm wrong? But technology does transfer down from high end r&d ex. nasa, automotive industry to other industries.
Quoted from Jazman:As far as automotive, one again, NOT ALL PARTS ARE CREATED EQUAL. As a former electronics engineer for the automotive industry, I can't tell you how much work goes into making electronics reliable in the automotive environment. If you think the LEDs that illuminate your cluster are just any old part someone throws in there, then you have no idea what you're talking about. If you knew the extremes that automotive electronics are subjected to, you would be shocked.
Jaz
okay, I have no idea what I am talking about.
Quoted from northvibe:I guess I assumed when he said High reliable led's with 30k+ hours it was not the chinese ones on ebay...maybe I'm wrong? But technology does transfer down from high end r&d ex. nasa, automotive industry to other industries.
oh shoot, not the china slam again. No wonder Jinping hates us.
Quoted from PPS:Posted an update on the blog
http://www.planetarypinball.com/category/mmr
thanks,
WMS Approval Process – we are the first ever to go thru this with WMS, so Roger Sharpe (PPS’s WMS Business Interface) is scheduled for the end of the first week of January (1/7) to review the game, as well as play the game.
rick
How did that go?
Quoted from indypinhead:Rick,
Just wondering how and when it will be communicated to us buyer as to our "place in line"?
Ditto!!!
Quoted from PPS:rescheduled to mon/tues ... busy and conflicting schedules ...
Can we get a live stream of the Roger Sharpe visit?
Hopefully the approval doesn't get bumped again and goes well. I'm really curious how this all shakes out.
Quoted from miggitymac:Can we get a live stream of the Roger Sharpe visit?
It would be cool for us buyers to see video of Roger doing his thing. Why not tape it, if it turns out well, share it .
If it goes less than perfect you can pretend you didn't tape it .
It seems like transparency in all this is important to PPS, hence Rick's participation here, the video etc. I know for me, it's made me a lot more excited for MMr and also made me feel a lot more comfortable during first part of this process.
The more transparency the better, it would be wonderful it they filmed it.
Quoted from frolic:It would be cool for us buyers to see video of Roger doing his thing. Why not tape it, if it turns out well, share it .
What we will be doing is notifying people with as much lead time as we can about when their game is expected to ship to arrange finances. Won't start even thinking about that for a month or two ...
You know what would be even cooler? A reality TV show detailing everything about building MMr from start to finish!!! You could actually name the show "Medieval Madness: The Pinball." And put it on A&E. And make little Rick bobble-heads. Or pinball bobbleheads. And sell them at truck stops. And Rick could make embarrassing political statements to get news attention for it all.
Or he could not slow down the works and get shit done.
--Donnie
+1 on everything people seem to be saying - the transparency is greatly appreciated. Yes it will be tough to keep up as there are many bad apples out there that of course make transparency frustrating, and make you want to just close up and keep everything private. I've had my issues with the non-transparency of other manufacturers, and it's refreshing to see so much involvement at this point - hopefully that continues through the entire process.
Quoted from Eryeal:+1 on everything people seem to be saying - the transparency is greatly appreciated. Yes it will be tough to keep up as there are many bad apples out there that of course make transparency frustrating, and make you want to just close up and keep everything private. I've had my issues with the non-transparency of other manufacturers, and it's refreshing to see so much involvement at this point - hopefully that continues through the entire process.
Agreed, there's definitely a reasonable middle ground here. Personally, I feel very well-informed, and you can't expect Rick to comment on something that hasn't happened yet.
I guess some people as well are coming off as impatient when they are really just super pumped about getting their MMr!
Thanks, again, Rick. Just don't leave us hanging (not that you have)
good luck this week!
Was the inspection able to move forward?
Any updates? Not PPS's fault but I think pinball people are especially sensitive about product delays based on other companies' projects.
Roger Sharpe (our WMS pinball "business" contact) was at Chicago Gaming yesterday (tues afternoon) for over an hour playing the game and doing a review with the team ... I talked with Roger this morning and he sees no issues in the game going forward, was impressed, next step in this process is now to bring the wms legal in the next week or two to close on the legal signoff of the game ... then Roger wants to be involved and check as we go thru manufacturing start, etc. Great news and as usual everything is a process ...
I will put pictures and/or vids to confirm that Roger was indeed there (as I'm sure here people will be suspicious) but as I am in CA and development is in Chicago, the first thing on the team's mind is not to document that internal meetings happened so it's a bit of an education for them ...
Quoted from 1967Firebird:Go the PPS blog new info.
Thanks again for the continued updates.
FWIW that info is: Roger liked it and said go ahead, now they need final approval from WMS legal.
Edit: Doh, too slow on the draw
Quoted from PPS:I will put pictures and/or vids to confirm that Roger was indeed there (as I'm sure here people will be suspicious) but as I am in CA and development is in Chicago, the first thing on the team's mind is not to document that internal meetings happened so it's a bit of an education for them ...
Sad state that you have to put pics/vids to confirm. So glad I'm in on MMR. This is progressing as well as can be expected. Well done!!
Quoted from Chippewa-Pin:Sad state that you have to put pics/vids to confirm.
And hopefully the pictures or vids don't get attacked here.
LTG
Quoted from LTG:And hopefully the pictures or vids don't get attacked here.
LTG
I've got my stopwatch ready for the timing on the castle destruction sequence...
Quoted from miggitymac:I've got my stopwatch ready for the timing on the castle destruction sequence...
LOL
LTG
Of course they won't! I'm sure Rick will make sure Roger is holding up his driver's license, social security card, and at least two major credit cards.
This page was printed from https://pinside.com/pinball/forum/topic/mmr-pps-and-overall-update-official-pps-oct-21-2013/page/42 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
