New! Dark mode!
(Topic ID: 128232)
MMR Owners Club, all things MMR discussed
By SuperPinball
5 years ago
  • 7,922 posts
  • 605 Pinsiders participating
  • Latest reply 1 day ago by neverahighscore
  • Topic is favorited by 314 Pinsiders
There have been 1,340 images uploaded to this topic. (View topic image gallery).
Custom Logo Instructions.pdf (PDF preview)
5 key posts have been marked in this topic (Show topic index)
There are 7922 posts in this topic. You are on page 8 of 159.
#351 4 years ago
Quoted from PWhiz:
Having an issue with my left flipper assembly. The pin that secures the rod(indicated in the picture below as an example) has come loose twice now in so many days, causing it to completely detach from the rest of the assembly. I was able to find the pin in the bottom of the cabinet and reinsert it and thought I had clamped it down hard enough, but apparently not enough for it to happen a second time now.
How can I secure this pin better? I had a heck of a time working on this part without removing the whole thing, so not sure if there's an easier way.
I would contact CGC and get a replacement plunger/linkage. It's a roll pin and it's not supposed to have failed like that.
#352 4 years ago
Quoted from PWhiz:
Please open a ticket on the Support desk to get a new plunger assembly.
#353 4 years ago
OK thanks for the advice. Will do.
#354 4 years ago
I'm happy to report that the contrast issue with the display (https://pinside.com/pinball/forum/topic/mmr-owners-club-all-things-mmr-discussed/page/7#post-2918117) is fixed by the new firmware revision.
Looks tons better.
#355 4 years ago
What new firmware revision? Has an update been released?
#356 4 years ago
Quoted from PWhiz:
CGC posted in one of these threads today it is in beta testing and should be out in February.
#357 4 years ago
Quoted from LTG:
would of been nice if CGC posted it in an "owners" thread.
#358 4 years ago
Quoted from SuperPinball:
It was in the MMR Software Update thread.
#359 4 years ago
Link?
#360 4 years ago
Go to Community - search Pinsiders - CGC - only two there, one posted today.
LTG : )™
#362 4 years ago
Has anyone had or currently having issues with their Merlin hole kick out?
I am having the ball fall back into the Merlin hole due to it not being kicked out all of the way. This happens about 60-70% of the time and at times it will take 3-4 cycles before the ball actually kicks out of the saucer. I have adjusted the kick out setting to maximum hoping that would solve the issue but it did not help. Is there something else to look at/adjust or is it time to open a ticket with Chicago Gaming?
Any ideas?
#363 4 years ago
Thanks! Saved me having to search
Quoted from loren3233:
Any ideas?
Happens on mine too. Not 60-70% but maybe more like 20-30% though.
#364 4 years ago
Zero problems with my Merlin kick out so far. Occasionally a ball fails to stick when making the shot, which is quite faithful to the original.
#365 4 years ago
Quoted from yancy:
I think CGC actually improved this by angling the wall in slightly to the left towards the saucer.
#366 4 years ago
Well crap. Hopefully my ticket for replacement plunger assembly gets answered soon as it failed again today. Looks like my MMr is out of commission until I get a new assembly.
#367 4 years ago
Quoted from PWhiz:
Just buy one from a usual source and use your replacement from CGC as a spare.
#368 4 years ago
Quoted from PWhiz:
Reinstall the rollpin so it sticks out the top a little, then flatten the part sticking out with a pair of needlenose pliers. Just need to flatten it enough so it won't fall back through before you can get a replacement.
#369 4 years ago
How's the level bubble on your MMR? I was trying to level the pin using that, but when I had the bubble in the center the pitch was >9 degrees. If I bring the pitch to about 6.5-7 degrees the bubble is all the way to the bottom of the level, is there a way to adjust that or is it waste of time?
#370 4 years ago
Quoted from Kkuoppamaki:
Those cheap bubbles can be a headache.
http://www.pinballnews.com/learn/level/index.html
LTG : )™
#371 4 years ago
According to the manual, the tip of the bubble should be between the first and second lines(if counting from the front of the machine). The first line represents 6deg of pitch and every line after another 1/2 degree, so if the bubble is touching the second line, it should be at 6.5deg.
It's not like other levels I've seen like in my Stern ST where there are just two lines where the bubble should be centered in between.
Think I might look into some fancy leveling apps on my phone though and see what it might indicate the pitch to be if possible.
#372 4 years ago
Digital levels are a must for any pin collection. Sterns set at 6.5 degrees perfectly every time.
#373 4 years ago
That's the exact level I use. I don't even bother with the bubble levels on games, some are accurate and some are not.
I'm sure everyone knows it, but may as well mention it...level the playfield, not the glass!
#374 4 years ago
There is a perfect App for the IPad for this purpose. Shows up and side level so that you can adjust your playfield/pin accordingly.
#375 4 years ago
Quoted from Zora:
I like the "PinGuy" App on iphone for leveling glass or playfield. Which one do you use?
#376 4 years ago
Quoted from Mokthemagicman:
you CANNOT level a pin off of the glass
#377 4 years ago
make sure the level is screwed all the way down on the rail. I ran into a Stern that was way off... turns out one end wasn't tightened down. They're still only good for approximate measurements.
#378 4 years ago
Quoted from TaylorVA:
Sure you can with software that is calibrated from the playfield and then the glass.
#379 4 years ago
Yes I use PinGuy, too.
#380 4 years ago
Quoted from pintechev:
Point me in that direction.
#381 4 years ago
Whelp, that just fell off. Neato.
Loc-tite apparently not included.
#382 4 years ago
Quoted from epthegeek:
Happened to me first night. Went through and tightened everything after that.
#383 4 years ago
The PinGuy app does this! Check it out.
http://www.iweis.de/
#384 4 years ago
What is it with coil stops? JJP can't seem to tighten them down, MMR's are falling off and Stern's stops self-destruct after a few hundred plays.
You'd THINK pinball companies would know how to make and install these by now..
#385 4 years ago
JPop was going to design all new coil stops from scratch (emblazoned with a "Z" logo of course) but you meddling pinsiders had to ruin everything!
#386 4 years ago
Well holy carp! I installed that PinGuy app, made sure it was calibrated on as level a surface as possible, made sure it was set to playfield and placed it according to the instructions. Even though I had the game bubble set according to the manual, it was off by almost a full degree according to the app(7.5 instead of 6.5). I raised the front legs and the game bubble was then pegged off the scale. Useless? Not sure how much I should trust this app or maybe invest in a real digital level. When I have more time, I may have to try and cross reference it with some other apps.
I also to my surprise discovered that I actually had a spare plunger assembly sitting in my parts drawer from a replacement coil I bought for my ST Pro last year. I only needed the coil and totally forgot about the plunger left over that was just sitting there. Was able to swap that in so I could play a couple of games and test out the new angle. Seemed okay so far. I may need to tweak the plunger assembly as it may not be tight enough. Some noticeable recoil at the end of the swing. Not a lot, but it should come to a dead stop.
Ah, the neverending fun of pinball maintenance!
#387 4 years ago
The sound bytes are kind of quite. Washed out by the sound effects. Are they ever going to fix that with an update?
#388 4 years ago
Quoted from AdamTheHutt:
I brought it up to Doug, so they're aware and it's something that they are able to adjust. It's not all the callouts, though. I think the only ones that need a "boost" are the various "Castle Bosses" (or Kings or whatever you wanna call them). The princesses, trolls and others sound like they're mixed at a good level.
#389 4 years ago
Quoted from PWhiz:
You can always go oldschool... regular level and a protractor
#390 4 years ago
just wondering if any1s made say a 4way power tap for adding multiple mods,have already tapped into power supply once for topper and if stuff like under cabinet lighting etc etc need same power source i dont wish to be tapping multiple wires into same spot on power supply itself.thank you
#391 4 years ago
Quoted from peaceboy666:
http://www.dkpinball.com/DKWP/?page_id=396
#392 4 years ago
Anyone who has received their MMR LE recently should read through this thread and check to see if your playfield is affected by this issue.....
https://pinside.com/pinball/forum/topic/mmr-owners-need-some-help/page/3
#393 4 years ago
I don't think my Merlin hole light lights all the time when it should. Also appears to be some ghosting with it.
#394 4 years ago
Need some more alignment advice. Since using that PinGuy app to set the pitch angle of my MMR to 6.5, I also made sure that the side-to-side level was spot on for both front and back. It's been playing pretty well for the most part, but I've noticed a couple of things that really bug me.
1. When the ball is returning from the right orbit at either from the stop or at a medium/moderately fast speed, it has a real tendency to hit or graze the top of the right slingshot and ricochet towards the center drain. It never used to do this before and was usually a clean drop down to the right flipper. I find myself having to give the pin a good nudge every time the ball comes down the orbit to make sure it clears the top of the sling. How does this compare to the original?
I'm guessing that adjusting the level from one side to the other would help this. Should I make the right side higher, or is that counterintuitive? I wonder why it should be behaving like this when my bubble level is so spot on.
2. This may also be related to the previous problem due to the possible level issue, but it seems that there is a high propensity for the ball to center drain after a castle gate shot. Either I'm incredibly unlucky, but most of the time the hit will deaden the ball enough that it will drop straight down the middle and nothing I can do. Maybe by fixing problem #1, that might help this by edging the ball to one side or the other?
3. Catapult still plagues me when more than one ball is caught in there. I thought when I fixed the pitch that it would have helped this, giving it more leverage to eject both balls, but it didn't. If anything it seems to have gotten worse. Now, it fails to even randomly knock one of the balls out to the side and eventually the catapult just stops kicking and I have to pull the glass off. I've done just about all the tweaking to the wireform I feel comfortable doing. It doesn't appear like the balls are catching on it in any way. It's just like it doesn't have enough power to launch two hard enough to clear at least one of them. Coil is at max strength, and that seems just good enough to get one ball around the loop smoothly. That just seems really odd to me. Thinking about opening a ticket on this one.
#395 4 years ago
My friend has an original MM and it depends on the speed of the ball coming around or out of the loop. If it pops out of the Merlin scoop the ball is traveling slower and it sometimes hits the sling but never on top of the sling bouncing it to the drain. Usually it will still hit the right flipper and bounce to the left flipper. The center drain issue from hitting the castle is the same on the original as well. We have found that shooting the castle from the right flipper will drain way more often than shooting from the left. Just depends where you hit the castle will depend where the ball will come down.
#396 4 years ago
1. Watch the 4min mark of this video where he hits the side of the cab to stop the ball from hitting the right sling while it's rolling down the right orbit. I don't like to hit the side of my cab like that so I just nudge from the front which is less effective and the ball often just touches the bottom of the right sling but doesn't trigger it, I can usually keep ball control.
I assume that touching the sling from the right orbit is authentic to original gameplay and is intended to make the game slightly harder.
My eject from castle on the left orbit loop is not as smooth as this machine and often bounces down the left loop making a live catch difficult sometimes, this can be corrected with a slight nudge, but it did seem to take a smoother path when I first played it. I'm not sure why this is I will look into it.
3 Catapult....I just posted a thread about this issue on PPS forum http://www.planetarypinball.com/forum/index.php/topic,577.0.html
I don't know about your Castle SDTM issue, perhaps you are a noob player?
I have an issue with my Castle roll over switch not registering about 1 in 10 shots, seems the roll over wire doesn't sit up through the plastic very high. I have tried bending it but was a bit hesitant to be too aggressive and don't think I actually got it to sit any higher. I wanted to remove the switch to bend the wire but one of the screws was obscured by something, I will have another look when I get more time.
Also my balls don't exit the wireforms as smoothly as on the video, which slows the ball down a bit probably making gameplay slightly easier. I'm going to see if I can line mine up better to get the ball to retain more speed.
These are just small niggles and tweaks though, awesome game I'm really enjoying mine DOUBLE SUPER JACKPOT!
#397 4 years ago
I received my MMr some das ago. I notized that the flipper strength significantly decreases after 20-30minutes, although I set the strength on 4. I have not seen any complaints in this regard. Am I the only one? The weak legt flipper does nötig achieve to shoot the Right ramp up to the top.
#398 4 years ago
Quoted from PWhiz:
I have that same issue, and have not yet been able to figure out how to fix it. I saw a reference in another thread that maybe ever so slightly bending the ball guide might help but I guess the risk is if you bend it too much then those balls that come down faster would get diverted towards center drain.
If you figure the best way to fix this out, let me know
#399 4 years ago
I have the same problem but I don't think it is a leveling issue because balls coming off the right joust hit or graze the right sling, and balls coming off the left joust hit or graze the left sling too. I think if anything, it may take some minor bending/tweaking of those stainless steel guides on the sides of the joust loops.
#400 4 years ago
couldnt find the ball for ages ,i am stupid
$ 11.00
Grand Rapids, MI
