(Topic ID: 128232)
MMR Owners Club, all things MMR discussed
By SuperPinball
  • 3,921 posts
  • 380 Pinsiders participating
  • Latest reply 1 day ago by paynemic
  • Topic is favorited by 202 Pinsiders
There have been 494 images uploaded to this topic. (View topic image gallery).
2 key posts have been marked in this topic (Show topic index)
There are 3921 posts in this topic. You are on page 75 of 79.
#3701 5 months ago
Wife and I picked up MMR at the Grand Ole Gameroom in Nashville last weekend. It has been on our wishlist for 3 years now.
Previous owner has already added the shaker motor. I purchased some Super Bands from the Marco's booth and put them in at the show. Cleaned up on the playfield, mainly some minor ball track from normal use. Once my bank account recovers, I'll upgrade the display.
About 645 plays on it when we got it home. I think the previous owner said it had about 250 to 300 plays prior to the start of the show.
#3702 5 months ago
Quoted from pencilneck:
Enjoy your game. Definitely upgrade to color! Well worth the $400!
#3703 5 months ago
Does anyone else get rejections from the damsel ramp (yes, I'm setting myself up here)? I want to do a high speed video or something to figure out what it is. My guess is it's banking off the right side of the ramp, hitting the plastic guide, and bouncing up and hitting the dragon mount.
I have removed this ramp to add plastic protectors. Can someone confirm it looks assembled right?
#3704 5 months ago
Not the answer that you are looking for, but I have a comment. I was able to install all of the Pinbits plastic protectors even the one behind the damsel ramp without removing ramps.
#3705 4 months ago
Time to see which one is better!
#3706 4 months ago
Got an error stating "drawbridge sw up" broken.
Game starts with drawbridge down.
Any suggestions?
#3707 4 months ago
Quoted from Damien:
Two switches on the draw bridge under the playfield. Easy to check both in Tests - Switch Edge, or Tests - Draw bridge - run it up and down and see if switch works. If not check for broken wires or if it needs adjusting.
#3708 4 months ago
Hey guys im having a problem with the pop bumper closest to the princess castle. Whenever it seems there is a strong vibration there is a chance the bumper will randomly fire. I currently have the shaker set to strong but im going to try setting it to lower and also try without it on. If not the shaker what do you think the issue might be?
#3709 4 months ago
Quoted from Mrawesome44:
Check the gap on your spoon switch. Likely needs to be opened slightly.
#3710 4 months ago
The leaf blade switch below the pop bumper wants a little attention.
A plastic rod from the pop bumper skirt comes down thru a hole in the playfield and hits a leaf blade switch. The top blade has a plastic spoon. The rod should be centered in it, and the spoon just touching - not pushing - the rod. You can loosen the two screws holding the leaf blade switch if you need to aim it a little to center the rod in the spoon. The lower leaf blade should be close enough so the slightest ball hit triggers it, yet vibration doesn't. Yours is too close/sensitive.
A little tweaking and you'll be good to go.
#3711 4 months ago
LTG posted this link to a plastic shim in the trough to keep magnetized balls away from the metal trough that were sticking:
https://www.marcospecialties.com/pinball-parts/03-16809
Anybody know why you'd do this for MM/MMR? It's on the parts use list but MM/MMR has no magnets.
#3712 4 months ago
Quoted from KozMckPinball:
I know. I know.
Think back. Way back. Before we had electricity. How did we make magnets then ? We took two pieces of steel and banged them together, repeatedly. This lines up their electrons and makes the steel have magnetic properties.
In a pinball machine like MM or MMR with no magnets. You still have steel balls hitting steel balls and hitting ball trough.
#3713 4 months ago
Quoted from LTG:
I know. I know.
Interesting, thanks. Why are troughs made of steel then?
#3714 4 months ago
Cheap to make and last a long time.
-1
#3715 4 months ago
Quoted from LTG:
Then why are troughs not shipped with a plastic shim? (This could go on all day/night ) Thanks for all the insight!
#3716 4 months ago
Anybody put mylar in their MMR shooter lane? Just wondering if I should do this, I have some mylar hanging around...
#3717 4 months ago
Why do you have mylar, hanging around ?
#3718 4 months ago
I put mylar in all my shooter lanes but then again I'm pretty anal.... for the 10-30 plays a year they get, I'm sure they would have been fine with only the Cliffy's I have installed.
#3719 4 months ago
Quoted from Jarbyjibbo:
Stupid question: where do you put the Mylar? Also, what length?
#3720 4 months ago
Quoted from hollywood:
Um, in the shooter lane? I'm not quite sure how to answer that lol. I remove the side rail and the strip goes from trough exit to under the rail and it's usually about 8-12 inches long down the lane depending on the game. Once I place it on, I take a razor blade and cut out for the switch. You have to be a little careful when applying since you are putting a straight piece on in a valley but once you get the hang of it, it's not that bad.
#3721 4 months ago
LOL. I know it sounded stupid as soon as I sent it. I have never added Mylar to any of my games. Is it easy to remove? I mean, it won't take clear coat with it?
#3722 4 months ago
No, not that I've ever removed my shooter lane mylar but I have removed plenty of PF mylar during restorations. You just use the upsidedown compressed air can technique.
#3723 4 months ago
So I've had an original restored MM at my place first r the last couple of weeks, and I've had the chance to play it side by side with my MMR.
I know the topic has been discussed many times, but not sure if people had the opportunity to play them in tandem.
Some previous owners of originals have said the remake plays identical, but that is going on their recollection of a game, which might be a little different from playing them both in the same room.
I personally think there is a difference. Not that it's a better or worse sort of variance, but to me at least, noticeable.
I feel like the flippers have a different feel. Like the difference between a Stern and a B/W. I feel like the ball rolls unlike each other as well, as if the wood or the clear coat are significantly different.
I'm not experienced or technical enough to dive deep into what makes these games unique, but as a player, I can say that they don't feel quite the same.
Both great games though
#3724 4 months ago
Quoted from Damien:
MM and MMR in the same collection? You must really like that game.
#3725 4 months ago
I have both in my location. My original one has what I would call a great personality that my players have always loved. When I had the playfield touched up over a decade ago, I used a different MM in better shape in it's place and the money in it dropped. Innocently one of my players told me that mine played so much better. That MM is here to stay.
My MMR does great too. Players like it.
#3726 4 months ago
Whenever I go to a show, I always play other versions of games that I own. Guess what....they ALL play differently. Every game will, remake or not.
#3727 4 months ago
Quoted from gliebig:
I totally agree. I had two LOTRs at my place for a couple months, and the differences we're noticeable.
With MM to MMR, I find it to be slightly more noticeable than what you generally finding comparing the same games.
Also I find the audio to be different. You really hear the effect of the drawbridge lowering on the original. On the remake I have had both stock speakers and upgraded speakers and they sound different.
#3728 4 months ago
I only have it temporarily. But I was happy to be able to play both of them together and experience that. Both amazing games.
#3729 4 months ago
I concur, I currently have 2 NGGs side by side and they both have their own personalities.
#3730 4 months ago
It really drives home the notion that these are hand-built games and they achieve their own feel and personality due to the subtle differences.
#3731 4 months ago
My drawbridge gear stripped out two teeth causing the drawbridge not to work correctly. Marco sells just the gear or the gear mounted to a shaft. Does anyone have experience with this? Does the gear just slide off the shaft and a new one slide on? The gear is 3.00 vs 20.00 for the whole assembly.
#3732 4 months ago
Quoted from fattdirk:
Looks like it from the picture. Can't be that difficult, as the gear is plastic and the shaft is metal. But I've never done it myself.
Robert
#3733 4 months ago
Quoted from MrSanRamon:
Robert
I bet LTG has done it! lol
#3734 4 months ago
Pardon the extreme na·ive·té of my question. For MMR, are there any board mounted batteries to be concerned about leaking?
#3735 4 months ago
One round one on the board you need to change maybe once every five years or so.
#3736 4 months ago
Quoted from LTG:
I assume we still keep the machines on while changing the battery as to not lose our settings.
#3737 4 months ago
Quoted from SuperPinball:
Same as a motherboard, yes.
#3738 4 months ago
Has anyone tried installing the Williams WPC95 Speaker Panel in an MMR...does it fit?
http://www.planetarypinball.com/mm5/merchant.mvc?Store_Code=PP&Screen=PROD&Category_Code=GS-3915&Product_Code=PPS-04-10382-7B-1
Or has anyone found a decal that fits in the space left empty by the missing Williams logo?
#3739 4 months ago
Quoted from netman63129:
I’m curious about this, too. It doesn’t necessarily need to be the Williams logo, (which can’t be sold here due to copyright violations), but maybe anything customizable. How about a “Medieval Madness” sticker with some cool graphics?
#3740 4 months ago
I have tried installing an NOS WPC95 Williams speaker panel on my MMR. Yes it will fit. The main issue is you have to cut the lock washers off to remove the old one and maybe the NOS Williams has the speaker covers already washered in, you have to cut those off as well. I wasn't prepared to do that, seems that re-assembly of the washers would be tough to do. It seemed like an easy job when I thought about doing it. Sometime I will get it done though.
The Williams decal is trademarked so you'd have to be careful about that.
#3741 4 months ago
Trademarks only prevent unauthorized reproduction and sales. If you're buying a legitimate part (and this is), you can do anything you want with it after you buy it. Nothing to be careful about, unless you're worried that when you go to sell your pin that Williams will come after you. Highly unlikely.
I did see another pinsider who was making just the logo (stainless I think), but never advertised. I never ended up pulling the trigger, but wish I had.
#3742 4 months ago
Ok well I confirmed you need to order the gear and shaft combo for the drawbridge. The gear by itself has a hole that is too large and won't work.
#3743 4 months ago
I want my widescreen please doug_duba any update on this please?
Cheers,
Neil.
#3744 4 months ago
I found this picture on Ed Cheung’s website. I do not have to expertise to make a sticker for speaker panel speaker, but maybe some can or has done this?
If this picture was stretched to fit the blank space on the panel, it might look pretty cool.
#3745 4 months ago
Quoted from Ray_Ayala:
It's really low resolution, 72 dpi. It looks kinda fuzzy when printed.
Really need something on the order of 200 dpi min.
Robert
#3746 4 months ago
Yeah, I was worried about that. I’ll keep looking.
#3747 4 months ago
I couldn’t find anything with good resolution. Maybe a pic of the side art on the machine would suffice? I’m guessing left side since the flipper button on the right interferes with the arrow. Of course, a home pic would have to be cropped etc...
#3748 4 months ago
Robert
I agree. Please let me know if you find something. That empty space needs filling
#3749 4 months ago
Here’s a pic of the right side. (Easier to take w/o having to move the machine)
#3750 4 months ago
Does updating the game (2.02) wipe the high scores?
$ 69.00
The MOD Couple
$ 98.00
$ 16.50
€ 8.10
Buthamburg
Howell, MI
7,550 (Firm)
Windermere, FL
€ 9.10
Gweem's Mods
$ 55.00
Pinball Photos
$ 229.99
7,700 (OBO)
Cheraw, CO
$ 89.99
$ 999.00
$ 55.00
Pinball Photos
$ 8.50
Bright Lights Pinball
Fulshear, TX
$ 40.00
PinSound
