(Topic ID: 128232)
MMR Owners Club, all things MMR discussed
By SuperPinball
  • 5,209 posts
  • 483 Pinsiders participating
  • Latest reply 17 hours ago by TimBoch
  • Topic is favorited by 274 Pinsiders
There have been 629 images uploaded to this topic. (View topic image gallery).
There are 5209 posts in this topic. You are on page 34 of 105.
#1651 2 years ago
Quoted from Damien:
Can anyone comment and let me know if this seems like the ball is bouncing normally.
I'm curious now that a few people have said there ball drops and stays on the flipper.
Damien... nice video!! Looks pretty much like pinball to me. Variables all over the place that are impossible to control and that's what makes pinball fun. An eject from the pops or moat will be different every time and cause fluctuations in ball speed and spin that cause different trajectories. Not saying that someones machine out there isn't more consistent than what your showing, but I can guarantee you that no two machines will be EXACTLY alike in their playing characteristics. I would suggest that what you are probably needing to do if you want consistent traps is to learn to introduce small taps when necessary to control the ball bounce a bit more. Will require different strategies every time depending on the angle, speed, spin and location on the flipper.
#1652 2 years ago
Quoted from Damien:
It is not. The right side is always a little sporadic so I cannot comment but the left side should always be about the same. It looks like... and I could be wrong... you need to adjust your ball guide and kick out. From the little I can see I would guess your ball is not riding the guide, the second attempt by where it hit the flipper I would guess it pulled off the guide well before it should have. Remember playfield pitch and side to side level plays a role in this. If you change from 6.5 to 7degree little things like this can be affected.
#1653 2 years ago
So if your game is truly level side to side I would look at 3 things. If you replaced your flipper rubber, put the original rubber back on. Have someone ( I'm at work) who's game consistently traps on the left flipper take a picture of the flipper in the raised position. Look how the flipper lines up with something on the playfield, and adjust your flipper the same. The last thing I would try is adjusting (bending) the left metal ball guide. That's all I can think of.......
#1654 2 years ago
Quoted from bigd1979:
Every pin is different and can play very different this is the reason i love pinball..... who likes things that are predictable all the time? That gets boring imo
Totally agree! Just was seeming weird that so I kept seeing and hearing that balls would stop on flippers, and mine was totally not doing that.
I bumped mine up to 7 degrees, but might go back down to 6.5 and play there a while. The game just started side draining like crazy this week, and it totally wasn't like that before. I'm guessing the game plays differently as you get more wear on it.
It's my first pin, so I'm definitely learning all of this for the first time. Love it though!
#1655 2 years ago
Quoted from tslayer71:
Nope, rubber is factory still.
Can you possibly get a photo of yours later? Curious to see how mine lines up.
#1656 2 years ago
Quoted from Damien:
Sure if nobody beats me to it I'll take a pic when I get home..... Also I would reconfirm your game is staying level side to side.
#1657 2 years ago
Quoted from Damien:
All looks pretty normal to me. There are adjustments that can be made by bending the metal guides at orbit starts in or out. This would place the ball further in or out when it nears the flipper area. Keep in mind, this can be a dark rabbit hole to go down and its' difficult to find the sweet spot as the trajectory will change constantly based on ball position and speed upon orbit exit. Again, yours seems fairly normal so I don't know that it would be worth the effort.
#1658 2 years ago
Just missed bftk this morning by one castle. Arrrgh.
#1659 2 years ago
Quoted from gliebig:
That happened to me last night too!
I completed everything except for Trolls a few times, so now I started to concentrate on that making sure to light Trolls before starting Multiball Madness. Last night I set a new Troll record (26), but failed to complete (by a LONG margin) the last castle.
#1660 2 years ago
Quoted from kapsreiter:
Color Rom Bugs
Some friends told me that there are a lot of Bugs in the HD
Color Rom
sometimes it changes to MONO COLOR and LOW RES
should be Buggy
and no updates
A lot? No... a few glitches here/there sure
#1661 2 years ago
One thing for sure, after I wax my game, it plays totally different. I need to get a couple dozen games on it before it "calms" down.
#1662 2 years ago
Quoted from Vyzer2:
I was under the impression that we did not need to wax these newer games for a while?
#1663 2 years ago
I heard the callout "fatality" the other day. Not sure what you need to do to get it but it was the original sound from Mortal Kombat.
#1664 2 years ago
Quoted from SuperPinball:
Heard it a couple times this week too! Curious to know what triggers it.
#1665 2 years ago
Ok when my left flipper is up, the middle of the flipper tip lines up with the top corner of the 'F' in 'Defeat'......
#1666 2 years ago
For code updates on MMr does everything get reset to factory default? Games Played count, high scores, etc?
#1667 2 years ago
Like this?
#1668 2 years ago
So I put 3 levels on to be extra sure.
You'll see both digital levels read 0, but the bubble level is not centered.
Is it due to it laying flat? Standing up I get a centered bubble, which is even more confusing.
I'm so lost!
#1669 2 years ago
Very close. Maybe a little higher. Looks like it's lined with the center of the 'f' not the top corner, but you'll be a better judge looking at it in person. I wouldn't worry about the bubble level, use the digital ones. It looks level. I just wanted to make sure that by playing and nudging the game it wasn't making the side to side level go outta wack. Playing my game tonight I'd say I can trap the ball maybe 70% of the time. The other 30% it's bouncing off the flipper....
#1670 2 years ago
You totally should make a video of it, and even include awesome music like I did
#1671 2 years ago
Keep thinking there are updates and it's just another 20 posts from Damien
#1672 2 years ago
Quoted from chrisnack:
Harsh, man!
#1673 2 years ago
haha, i was totally teasing you
#1674 2 years ago
No hard feelings brother. I know I'm noobing it up here, and probably annoying some of you, but I'm definitely learning some stuff, and although I suck ass at pinball, I must say my skills have improved
Thanks all for putting up with me!
#1675 2 years ago
I believe Dan Forden, who did the sounds for Mortal Kombat also did the sound on MM and incorporated a few sound bites from MK. I'm not 100% sure what the logic is, but it seems to be related to consecutive shots up the damsel ramp.
#1676 2 years ago
http://hem.bredband.net/b257182/Cows&Easter.htm#4032
#1677 2 years ago
Quoted from Kkuoppamaki:
Man that makes sense, we've heard "something" and could never make it out, but that was probably it.
#1678 2 years ago
Iirc the video on the screen when you get the second to last shot up the damsel ramp shows you killing the dragon. That is what's preventing you from rescuing the damsel. That's when the fatality call happens, I believe. Then the gate drops and you can shoot all the way up the ladder.
#1679 2 years ago
Decided to play a couple of quick games before bed.
First game was rough. Second game everything seemed to be flowing, and I ended up getting the closest I've been to BFTK. Had all the blue "master" lights lit, and just needed to finish off the 6th castle!!!
If I only got the extra ball from Castle Multiball, I could have done it! Damn this game is awesome when it's all dialled in right!!!
#1680 2 years ago
Anyone else had issues with the sound on MMR?
Since installing the colour upgrade chip couple of times I've been playing and the sound decreases to about 1% of it's normal level. Pushing the colour video chip in to the socket firmly seems to solve it but the trolls popping up seem to work the chip loose. The original chip came with a cable tie that held it in securely but this needed to be cut to install the new chip (as per the instructions).
Anyone else had this issue? And is the solution to try and install a new cable tie around the chip?
#1681 2 years ago
Quoted from johngravenews:
Never heard of your issue, but that's what I'd try with your symptoms.
#1682 2 years ago
Found out a couple of things playing MMR today. Yes, increasing the catapault strength, +1 I think is the setting, clears 2 balls in the catapault during multiball. Also, exploded Sir Psycho castle with a lock ball shot immediately after a direct gate castle gate shot. (No multiball at the time). Not sure if it works with all kingsmen, but I was curious which one when I saw it.
#1683 2 years ago
Quoted from KozMckPinball:
This is a shortcoming of the Medieval Madness design. (That is, this is not a problem specific to remake.) This is also not specific to any one king.
#1684 2 years ago
Joined the club a couple weeks ago with a Mmr le I found with 50 plays on it . Really enjoying this game starting to realize the high ratings on this especially compared to Afm with how close these games seem to one another . Mmr is more challenging and love it !
#1685 2 years ago
Quoted from Lord_of_the_pins:
My afm is much more difficult than my mm..... Guess it depends on how they are set up tho...
#1686 2 years ago
After playing MM and AFM more and more I can see why they are so highly rated. Two of the best games ever.
#1687 2 years ago
Having no memory of ever playing MM, MMR blew me away, the game has it all so very well-done (theme, toys, play, quality, code, voicework, artwork, dots and integration). I feel very lucky to have had the opportunity to buy a new version.
#1688 2 years ago
Quoted from dzoomer:
I totally agree
PPS really did a great job with the MMr. I really like everything about it...game play, build quality, color DMD, etc....
#1689 2 years ago
Quoted from indypinhead:
I totally agree
MMr is still the favorite in my family after 2 years of game play. I admit I am not really into AFM but found what they did with the remake to look real cool so I'm getting one.
The opportunity to have matching numbers was the real reason I bought one.
#1690 2 years ago
I've been debating about getting a AFM as well as I enjoy that game a lot too. Only concern is if it's too similar to MM, would it get boring?
I found it to be fun and the humor great like MM.
#1691 2 years ago
https://pinside.com/pinball/forum/topic/mm-vs-afm
#1692 2 years ago
I don't think they are too similiar. Very different theme, music, call outs, and toys. The fun and tongue-in-cheek humor is similiar to MM and that is a good thing!
#1693 2 years ago
I'm right there with you! I bought a TZ recently, and I'm not really feeling it. I know everyone puts this at the top of the list, but I just don't get it. I find the left jets and drains defeating, and I find the excessive punishment for missed shots to be a buzzkill.
So, I'm debating parting with the TZ, grabbing a Getaway as my second game, and perhaps saving for a AFMr
Only thing holding me back (aside from $$$) is the idea that a MB remake might be coming next!
#1694 2 years ago
Quoted from Damien:
I'm thinking MMr, AFMr, and MBr would be a nice small home collection.
#1695 2 years ago
Does MMr have an 'Adult Speech Mode' and how is it accessed?
#1696 2 years ago
Quoted from Damien:
Assuming everything goes smoothly, you are still looking at 2 years away from that.
#1697 2 years ago
Quoted from CubeSnake:
In Adjustments - Feature Adj. - A2. 22 Family Mode , default is No.
Now the F Word is still bleeped in No. Unlike the hacked ROM floating around out there, which isn't usable in MMR.
#1698 2 years ago
Quoted from LTG:
Thanks Lloyd!
#1699 2 years ago
I have some stock mmr speakers if anyone needs a replacement but prefers to remain original. Name your price plus shipping.
#1700 2 years ago
Perhaps more desirable, I have a troll complete mech that was working except the back of the troll head cracked so it twists around on the one screw still holding it together. Should be a simple reinforcement and repair. Fair price plus shipping?
Edit: look like these suckers are expensive at PPS. Flap $20, head $20, switch ? Carriage $ 49. Whoa. Like $110 new. So make a fair offer and I'm in.
$ 279.95
Pin Stadium Pinball LEDs
€ 95.00
FlipperLED
$ 89.99
$ 395.00
M&M Mods
$ 50.00
$ 89.99
$ 59.00
Pinball Sales
Cleveland, OH
PinSound
€ 9.10
$ 36.99
Lee's Parts
€ 3.70
$ 7,995.00
Classic Game Rooms
8,295
$ 49.95
$ 40.00
Arcade Arts
Nashville, TENNESSEE
Gweem's Mods
PinWoofer
$ 229.99
