(Topic ID: 128232)
MMR Owners Club, all things MMR discussed
By SuperPinball
7 years ago
5 key posts have been marked in this topic (Show topic index)
There are 9,658 posts in this topic. You are on page 193 of 194.
#9601 45 days ago
Quoted from northvibe:
did the later run have rgb pops? original runs did not.
But yes that would be the bulb. I ordered those to add rgb to my pops and just haven't done the mod yet. Will do it when I shop the game as the ramps need to come off.
Yes the SE and LE in the 2019 run has RGB in the pops, above the castle, in the speakers, and all around the playfield. This particular pop led has a clear star shaped lens and then there's a black plastic body that is screwed down in the pop. I tugged on it pretty hard and am not sure if it has a socket or not. Very hard to see, and I am not sure what I'm looking at. Has anyone ever removed one? What type is it? Is it like the pic I posted from planetary pinball, or is it 555 or bayonets?
#9602 45 days ago
Quoted from CrashJT:
by le you mean royal? It is not a normal led you can buy from CT/comet.
#9603 44 days ago
CrashJT It is just an connector plugged into the globe. You need to buy the Planetary Pinball ones like the ones in your post.
Unscrew the screw holding the black plastic globe holder and pull up. I added RGB to my pops and made it exactly like the way the SEs and Royals were done, here is a link to a pic:
https://pinside.com/pinball/forum/topic/mmr-owners-club-all-things-mmr-discussed/page/169#post-6237837
#9604 43 days ago
Quoted from ktm450:
Thank you!
#9605 40 days ago
Does anyone have a spare board from royal upgrades? Need one to install just the topper into a base game.
#9606 40 days ago
Quoted from ToddSonOfOdin:
I believe i have a spare topper board packed away somewhere
#9607 32 days ago
New Medieval Madness true mirrored backglass 31-1357-50059M ... same process and supplier as for the CCR mirrored backglasses - in stock and available now.
https://www.planetarypinball.com/pinball-medieval-madness-mirrored-backglass
the video is uploading/processing so if not ready try in a little bit!
Team PPS
#9608 32 days ago
Does anyone know what this is?
Taking pics for a possible trade and lifted the pf and — naturally — this falls out of the wiring harness. Thanks.
#9609 32 days ago
Quoted from JimFNB:
Yes. Two screws go into it. It rests on the back of a troll head. The screws screw into the metal part on a stand up leaf blade switch.
Either an extra, or a troll is missing one. Just the screws holding the troll head to the leaf stack.
#9610 32 days ago
Quoted from LTG:
A different color. You can see it in this picture.
#9611 32 days ago
Thanks Lloyd. You’re the best.
#9612 31 days ago
MMR Left flipper died on me tonight when I turned it on (no credit dot) and the moat Vuk and castle gate is not always registering after ball hit. I spotted this screw on the ground of the cabinet. I don’t think it had anything to do with the flipper…
Maybe it’s a fuse issue?
Any suggestions please. See pics. Thank you for your time.
Thanks.
050177ED-721F-4C6E-A357-5C0B9BF2988C (resized).jpeg9B9A3394-3D8A-44F2-B197-FD777B335B93 (resized).jpegEC4AC736-4D45-42D1-B1A2-4F20A8DE75F4 (resized).jpeg
#9613 31 days ago
Quoted from PaulCoff:
Thanks.
F3 is clearly blown on the solenoid board. (Blue board in the center, the bottom fuse of the 3 on the left)
Also, do you have a multimeter?
Make sure you have a few 4A fuses (F3 takes 4A, slow blow), because if the coil is bad or the transistor has blown, that new fuse may blow again. It's why I asked if you have a multimeter.
#9614 31 days ago
Quoted from PinMonk:
Totally…just realized. What is the proper fuse for it? Strange things have been going on since I installed the color chip.
#9615 31 days ago
Thanks brother![quoted image]
The chart says 4A. It looks like the one that blew was a fast blow, so that may be the problem. It's supposed to be a slow blow. Once you get the fuse out, you can read the metal band at the top to see what the one that blew was before you give it a proper burial in the nearest trash.
#9616 31 days ago
The chart says 4A. It looks like the one that blew was a quick blow, so that may be the problem. It's supposed to be a slow blow.
Cool. I’ll check it out. This is the only meter I have in my “Pinball go bag.”
#9617 30 days ago
Yeah, not going to cut it. You need to spend $50 for a cheap, disposable chinese multimeter like Klein tools autoranging MM400 or about $190 for a Fluke you'll have forever. That and a (weller, hopefully) soldering station are the first two tools for a pinball maintenance kit.
#9618 30 days ago
Yeah, not going to cut it. You need to spend $50 for a cheap, disposable chinese multimeter like Klein tools autoranging MM400 or about $190 for a Fluke you'll have forever. That and a soldering iron are the first two tools for a pinball maintenance kit.
Totally. Could you send me a link to a meter you suggest? Thanks again for the quick response. I appreciate your time.
May I use a 5A or a 4A?
#9619 30 days ago
I would stick with 4A it calls for because if the coil or transistor is shorted, when you power up, it could pull an extra amp of power and blow something else up along with the new fuse.
Cheap chinese multimeter:
amazon.com link »
Fluke "forever" multimeter (apparently prices have gone up since the pandemic, but this is a GREAT multimeter):
https://www.fluke.com/en-us/product/electrical-testing/digital-multimeters/fluke-117
Weller soldering station:
amazon.com link »
Hakko soldering station:
amazon.com link »
#9621 29 days ago
Are there 2 screws on the left side of the flipper coil? Trying to find where your screw came from. I think both are there, just one is in a shadow.
#9622 29 days ago
Quoted from Pinkitten:
The one that dropped is not slotted, and it has a lock washer, which the flipper plate screws do not. It's more like the kind of screw you see on the gunmetal gray assembly just below the moat area on the right side.
#9623 29 days ago
$45 FLUKE-101 Digital Multimeter https://a.co/d/9m2fNrr
Best cheap meter you can get
#9624 29 days ago
It's a nice multimeter, but the lack of a backlight is a dealbreaker for me recommending it. Especially on a pinball machine it can be in the dark or bad lighting a lot.
#9625 29 days ago
After doing a decent amount of reading and youtubing, this was what I got and I have no complaints thus far. amazon.com link »
#9626 29 days ago
Ah, haven’t had an issue yet, but I can see a backlight being awesome. However personally I would take a higher quality build over a cheap with a back lite. I have a fluke something, Klein and Jensen and they all work ok, but the fluke from my dad is better hands down. Luckily for pinball stuff we don’t need a whole lot of features for basic troubleshooting
#9627 29 days ago
The Moat VUK is keeping the ball and not releasing it onto the playfield… there is the moat sound and flash. I’m going to check on it more tonight and see if it has anything to do with the switch, screw, or hopefully not a fuse / transistor issue. Thanks for everything
#9628 29 days ago
Another good recommendation is "alligator" clamp tips so you can clamp on to legs etc as holding 2 leads with 1 hand sucks
#9629 29 days ago
Switch or vuk issue broken wire likely.
Test if vuk fires in test menu.
#9630 29 days ago
Switch needs adjustment, or broken switch wire, or blown 12v fuse (I think the switches run off 12v on MMr, not sure) on the power board. If it's the ONLY switch not registering, adjustment or broken wire are most likely.
#9631 29 days ago
Yeah, Fluke is my go-to brand. But for the level of 99% of pinball diagnostic, if a person is on a budget and can't get the 117 with the TL175E test leads, I'd recommend a decent Chinese one with a backlight over a Fluke without. But the Fluke 117 is the #1 recommendation. It will be the last multimeter you buy.
#9632 29 days ago
Opto switch in there. If wires are intact, I'd try cleaning the optos next. Damp Q Tip works good.
#9633 29 days ago
Quoted from LTG:
Ah - what he said.
#9634 28 days ago
Quoted from glpinball:
Quoted from LTG:
Thanks guys. Problem solved. I appreciate your time. You all motivate me to fix and play pinball. Such a good feeling fixing then playing pinball.
#9635 28 days ago
What was the solution?
#9636 28 days ago
I have both a digital VOM (I think I got at Sears) and an analog VOM I got at Radio Shack (about 40 years ago).
In most cases I prefer the analog meter, though self-ranging is great in the digital meter if you have no idea what the voltage might be.
Robert
#9637 28 days ago
I did a clean on optics and reset all connections and fuses. I checked all wires. The catapult was acting up too. I assumed the shaker/ castle movement might have caused something to get loose. Shaker motor is cool, but I think it loosens mechanics/wires somewhat. All was finally working, but I still keep a close eye on it and thanks for all the quick responses.
#9638 28 days ago
ah! thanks for posting
I JUST had an issue where the castle lock wasn't registering. and i tipped the pf up. flicked the switch all worked just fine in test, but it seemed like switch arm got hung up but once I lifted the pf it unstuck and was fine... ugh pinabll
#9639 26 days ago
We put on our store (www.planetarypinball.com) all the MM Royal Edition diamond trim parts that we have. I highly suggest that you look at what items we have available and order replacements or spares. It is unknown at this time if or when we can get more.
PPS-01-8993-4-BD – Side Molding – Black Diamond
PPS-A-19514-BD – Leg Assy
PPS-A-12615-BD – Front Molding
PPS-MLS-XLFRM-BD – XL Display Frame
PPS-01-901112L-BD – Backbox Bracket LH
PPS-01-901112R-BD – Backbox Bracket RH
PPS-SUB-ROYARCH-BD – Bottom Arch Assy – MMR Royal
Team PPS
#9640 25 days ago
Does anyone know what trim level would pertain to a game with a 2017 build date and model number 11000?
#9641 19 days ago
Quoted from PPS:
Team PPS
You can put this in a remake?
#9642 19 days ago
Quoted from Dwboca:You can put this in a remake?
Yes and it looks awesome
#9643 19 days ago
Quoted from Only_Pinball:
For the mirrored backglass, do I need new trim?
#9644 19 days ago
Quoted from marioparty34:
i just received and installed the mirrored back glass for my MMRLE and used the existing trim. Looks amazing and had no issues with install.
#9645 19 days ago
Quoted from Bmanpin:
Would love one for my LE but $200 shipping plus duties to the UK is a killer, does look very nice in the video.
#9646 19 days ago
I did both my CC an MM. CC was super easy. MM was harder but I got to work with the existing trim.
#9647 7 days ago
New owner here of a 2015 remake. (And my first pin!)
Great machine, been having a lot of fun, but the one thing I can’t quite sort yet is the left orbit path. Fast balls out of it such as the super skillshot tend to go sdtm (when not flipping) or to the extreme tip of left flipper (if held up). As I understand it, the ball should come out of the left orbit and hit the middle of the left (unflipped) flipper. Slower balls do this pretty well, but fast ones come out in the middle.
Here is a video of the path:
I’ve been told that the left orbit ball guide needs to be adjusted, but it seems buried under wireform and multiple plastic covers. Before I disassemble a bunch of stuff, can anyone give me an idea of exactly which way I should adjust it or what will affect the ball in the right direction?
#9648 7 days ago
Quoted from tzakiel:
See post 8573. I had the same issue.
#9649 7 days ago
Quoted from gorditas:
Thanks! This is exactly what I think it is.
Which rubber size/part exactly do I need to shop for?
#9650 7 days ago
I got mine from Titan: just order the thinner Stern style.
$ 11.95
Toys/Add-ons
$ 64.99
Toys/Add-ons
Hardware
Pinball Haven
Hardware
$ 24.75
Precision Pinball prod.
Flipper parts
12,000 (OBO)
Houston, TX
This page was printed from https://pinside.com/pinball/forum/topic/mmr-owners-club-all-things-mmr-discussed/page/193 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
