Quoted from glpinball:Have an intermittent issue with right Joust loop not registering. I think it happens once in a while during regular play but I saw it not register several times during royal madness.
Also, sometimes the castle doesn't register a hit.
It's a very new machine, 300 plays, nib back in august, classic version.
Ran switch tests and it registers with a press or a ball.
Any ideas?
The castle hits work differently if the draw bridge is up or down. If it's up, the trigger is the opto just before the drawbridge. If the drawbridge is down, the trigger is the opto just in front of the gate. A really fast ball that hops because of the drawbridge will often not trigger it.
For the joust loop the switches are probably not sensitive enough and a ball that whips around quickly will not press it enough to trigger. switch adjustment is easy. The plastic housing of the switch can be turned slightly once the 2 screws holding it are loosened a bit. you need to twist it so it almost triggers. Hard to explain with just words. You can also bend the wire itself so it sits closer to the little button that sticks out on the switch housing.
In the attached picture if you loosen the microswitch and turn it clock wise it will be more sensitive. counter-clockwise would be less sensitive. The turning is really minimal. There isn't much play but it doesn't take much to adjust it usually. When that isn't enough then the metal wire itself can also be bent.
