(Topic ID: 128232)
MMR Owners Club, all things MMR discussed
By SuperPinball
6 years ago
  • 8,858 posts
  • 662 Pinsiders participating
  • Latest reply 11 hours ago by LTG
  • Topic is favorited by 347 Pinsiders
5 key posts have been marked in this topic (Show topic index)
There are 8,858 posts in this topic. You are on page 167 of 178.
#8301 9 months ago
Quoted from LTG:
Yes. Round 2032 near top center of little board in the head. Holder and battery may need cleaning.
Thanks Lloyd...will do
#8302 9 months ago
Quoted from MK6PIN:
So MMrRE newbie here.....confess I just opened the box, set it up, usual adjustments, and playing the crap out of this thing for the past couple weeks. Got the dreaded dot this evening, stating I needed to set date and time. Simply went into menu and addressed. All my scores, etc. stayed intact.
Rebooted and everything seems to work and no dot. Haven't even opened the manual yet. Is there a battery in here or something that might have just worked loose (?).
Will read schematics tomorrow, but I've been back at fixing my WCS for too long today (had to step away as I was tempted to set that damn game on fire), so hoping something easy.
Apologies if already covered somewhere.....thx
I had issues with the clock, every day the date and time wasnt correct after power off over night.
As Llloyd said, cleaining the battery slot and replacing the CR2032 might help.
I coudn´t solved the prob with cleaning. My clock works now perfect after reinstalling the SW3.0 (same version as before, same sd card, no idea why).
#8303 9 months ago
Hi,
I would like to change the 4 post sleeves at the ramp entrance (Peasant, Damsel).
What do I have to dismount that I can pull off the rubbers? Are the two small screws at the ramp entrance only, or must be unscrewed more?
#8304 9 months ago
Quoted from Cayenne:
Hi,
You could just take off the ramp guard on both sides of the ramps. I don't think you have to remove the ramp.
#8305 9 months ago
Quoted from Jon9508:
I tried, but the ramp sides are fixed, so only to remove the screw on top of the post sleeves was not succesful.
#8306 9 months ago
Thought they were held on by 2 screws( post and on on the ramp) You can remove the 2 tiny wood screws that hold the ramp down. Might give you enough to move the ramp up. If not you might have to remove the whole ramp
#8307 9 months ago
Remove the screws on top of the post sleeve and the two small screws holding the plastic ramp down. Then you can lift the ramp up enough to change the post sleeves.
#8308 9 months ago
Quoted from LTG:
merci,
I had suspected that, but had not yet dared.
#8309 9 months ago
Quoted from LTG:
Definitely a gunky battery... cleaned and replace w lithium...suspect that cures it....thanks to LTG and neverahighscore for insight!!
#8310 9 months ago
Has anyone installed Pinstadium Fusion or similar in a MMR with the RGB upgrade? Was curious if the Pinstadiums diminish the effects of the upgraded lighting.
#8311 9 months ago
Anyone found a solution to external volume control?
#8312 8 months ago
Quoted from Reefkeep:
Pinnovators just came out with a master volume control that installs in the bill acceptor plate.
#8313 8 months ago
Quoted from bdaley6509:
I have PinStadium Neos on a MMRrRE, and it does not diminish the RGB on the field at all. Depending on how you would set up the fusions, I don’t think it would affect the RGB.
#8314 8 months ago
Quoted from MK6PIN:
Definitely a gunky battery... cleaned and replace w lithium...suspect that cures it....thanks to ltg and neverahighscore for insight!!
Followup and closure to this one - still had weird time settings, then noticed no attract music. Decided to look at the software - mine was "3.0.0 BETA3". Went to the site, downloaded/ installed "3.0.0" and she's been spot on for over a week w both time and attract sounds.
Glad it was that simple (and finding/ cleaning my gunky battery at the same time)...my OCD is back in check....
#8315 8 months ago
Two observations on startup of a game. Occasionally, when a ball ejects into the trough and hasn’t been plunged, scores show up, but the ball is still in the trough. Random switch being activated? And is it normal that when the ball is plunged, it immediately scores 5000 on the rollover switch at the upper right corner? Thanks
#8316 8 months ago
Quoted from seah2os:
Switch is too sensitive or arm on the switch is sticking or dragging in the slot in the playfield it goes up and down in.
#8317 8 months ago
Well, next "noob to this game" question - I keep getting error "check left gate - stuck closed" message. Went to T.16, but as soon as I hit any of the loop switches, "test failed left gate stuck", then went to solenoid test, tested left and right gate - they seeme to both work identically - opening and closing via the coil. Doesn't seem to bind as I can move w my finger up and down easily. All 4 loop switches work fine.
What have I missed? LTG - happen to be in the forum tonight? Thx as always....
(it is bourbon night however, so if I have to take something apart, it will wait until tomorrow)
#8318 8 months ago
Quoted from MK6PIN:
What have I missed?
Page 1-54 and 1-55 in the manual.
#8319 8 months ago
Quoted from LTG:
Mine is 1-57, then 2-21...manual is Rev. 3.0....
All good though....replicated the error then eliminated...thanks for responding...certain I'll need you again
#8320 8 months ago
On line manual you can download.
Quoted from LTG:
Later printed manual.
Quoted from MK6PIN:
Quoted from MK6PIN:
All good though
Thank you !
#8321 8 months ago
Just lightly pushing, not pounding, but pressing on the apron is awarding 5000 points. Thoughts?
#8322 8 months ago
Tests - Switch Edge - press on the apron and fix or adjust what reports on the screen.
#8323 8 months ago
Quoted from LTG:
Thanks! I’ve narrowed it down to Switch 67. Right Loop Low. Odd thing is when I lightly push on the diverter metal between the shooter lane and playfield, it senses that. But only on the lower part of the diverter, not up by the activating switch.
#8324 8 months ago
i will get new speaker grills this week
send me a PM if you are interested
for all XL versions MM MB AFM XL
122763901_10218637938529408_4753965937610816529_n (resized).jpgIMG_3263 (resized).jpgIMG_3402-2 (resized).jpeg
#8325 8 months ago
whats happening guys I have picked up a MMR LE and upgraded to the XL Screen, wow what a difference.. Question is, Cn the older MMr Le screen be used in any other games? Is there any value to the original screen, speaker panel etc? thank you for any feedback.
#8326 8 months ago
Quoted from Norcal:
The only value in the old display is if someone with a classic MMr, AFMr or MBr has one that goes out.
Totally agree on upgrade! It does make a huge difference. Super glad I did it.
#8327 8 months ago
Quoted from Norcal:
I’m going to use my original in a vpin, I’d assume more vpin people have and would use it
#8328 8 months ago
I'm having some distorted sound from my MMr Standard speakers. If I have the color chip upgrade, I can put the XL screen and upgraded sound? Will that replace the small speakers in the back glass or just the sub? Also, I can add the topper? How easy is the install if it is possible? The manual scan in the topic key post makes it look like you need to cut a hole in the cabinet?
Is it possible that a wire is energizing the speaker causing the distortion or more likely to be a blown speaker? It seems to distort at certain times but not constantly.
#8329 8 months ago
Quoted from Vernisious:
The XL replaces all three speakers. The install is pretty straight forward and you don’t need to cut a new hole, just replace the mounting block on the bottom of the cab.
#8330 8 months ago
Fix the shorted wiring.
#8331 8 months ago
I have a odd issue that just started with my MMR RE.
On the catapult wireframe, when the ball comes around to cross the playfield, traveling to the left outline drop. The ball will fly off and land some place on the playfield. Screws up the whole flow of the game.
Doesn't happen everytime, but it seems to be 50/50 chance. It never did this when I picked the machine up a few months ago. So something is out of adjustment, I was looking at everything trying to see what makes sense to adjust. Any hints?
#8332 8 months ago
Quoted from chillme:
Lower flipper strength, or try and figure out if the wireform got bent a little and needs to be a little higher on one side.
#8333 8 months ago
Came across a Gold MMR LE for sale. Really would like a MM. Wife fell in love with it. I definitely enjoyed playing it and it seems like a bolt to the floor game. Thing is he wants 12 grand. Now I do have the money, and I’ll probably let one of my games go. The question I have is he asking way to much? These MM games don’t come around often.
#8334 8 months ago
Quoted from Quick:
I get that we're in covid-times, but I bought my HUO MMR LE last June with the Color ROM upgrade for $7800 delivered to my garage. The thing is mint, < 500 plays on it.
Maybe if it has all of the upgrades and is HUO, but that's still really high. If it's just a vanilla LE, 12k is insane.
#8335 8 months ago
Quoted from Quick:
For a gold le? No. 12k is like royal money as it has all the mods in. Le’s are usually 8500-9000
Quoted from benime:
Ya, you got a deal at 7800!
#8336 8 months ago
Quoted from northvibe:
Yeah, I guess I already knew the answer to my question. In the market for another pin and none really knock me out. Played the new GnR and meh. MM is bad ass.
#8337 8 months ago
Quoted from Quick:
I love my MM, but also wish cgc would release the next game. I suck at pinball so the 90’s Williams are just fun all around
#8338 8 months ago
As everyone else has said, 12k is crazy. CGC will make more at some point I'm guessing. They way underestimated demain on the last run. Hopefully they won't make that mistake twice.
#8339 8 months ago
Quoted from Only_Pinball:
I could be wrong but I'm pretty sure they said that was the last run of any edition of MMR. that is one of the reasons the price is jumped up so much.
#8340 8 months ago
Quoted from foxtj24:
I believe they only said no more Royal editions. I do not think they made any comment about re-running other editions.
I also would not be surprised if they come out with some new "Sovereign" edition with a different topper or something.
I think they are busy working on their next game(s), but they will likely re-run some version of MM at some point - as long as demand exists.
#8341 8 months ago
They will keep running MM until demand dries up. It’s a very profitable game for them. Easy to spin up another run whenever there is enough demand. Surprised they haven’t done that now to keep the line busy while they work on the next game
#8342 8 months ago
Quoted from Quick:
Depends ... I have a first run low play HUO LE with XL display/sound package, RGB lighting, and topper mods all professionally installed. If it was for sale I would ask 12K for it.
https://pinside.com/pinball/forum/topic/mmr-owners-club-all-things-mmr-discussed/page/157#post-5959828
#8343 8 months ago
Quoted from Pin_Guy:
I agree, I have a standard with upgraded color, XL display, royal topper, shaker motor. I'm just missing the rgb lighting to make it similar to a royal. Side art and Merlin mod. It has over 10k plays. Playfield is perfect with cliffys and plastic protectors installed. I wouldn't take less than $10k.
#8344 8 months ago
Quoted from Vernisious:I agree, I have a standard with upgraded color, XL display, royal topper, shaker motor. I'm just missing the rgb lighting to make it similar to a royal. Side art and Merlin mod. It has over 10k plays. Playfield is perfect with cliffys and plastic protectors installed. I wouldn't take less than $10k.
which side art
#8345 8 months ago
I meant blades. I couldn't find them with a search. The newer ones are probably nicer. Side blades are not the main event for me.
#8346 8 months ago
Just the mirror/chrome ones?
#8347 8 months ago
You guys are a bad influence on me! Contemplating selling my nib MMRRE. I mean, its stuck on the shipping pallet in my home, been 9 months now and I won't have space for another year for it. Thinking I could pick one up later. I dunno.
Been waiting since 2005 to pick up an MM, now that I got one I'm afraid to open it up.
#8348 8 months ago
Quoted from underlord:
If prices keep going up you will regret selling it. RE will not be re-made. I know I'm going to get shit on for the following statement but.... Yes folks can accessorize their game to make it RE like but it's not the same
While you can imitate the powdercoat, you can't beat the clean factory install of all the parts including RGB pop bumpers as well as no issues with wires being too short and drilling holes in the head for the topper.
#8349 8 months ago
underlord: You will love your MMR Royal.
It truly is a stunning package in person.
The powder coated armour is really tastefully done and the topper, enhanced display & rgb lighting are simply amazing. Just makes a fantastic game even better.
For my fam, the game is bolted to the floor.
#8350 8 months ago
Quoted from JMK:
Yeah, money sounds great but my career is doing well and just knowing I own one; well, it’s a good feeling.
