New! Dark mode!
(Topic ID: 128232)
MMR Owners Club, all things MMR discussed
By SuperPinball
5 years ago
  • 7,577 posts
  • 591 Pinsiders participating
  • Latest reply 13 hours ago by SkaterVet
  • Topic is favorited by 309 Pinsiders
There have been 1,254 images uploaded to this topic. (View topic image gallery).
mmr-speaker-rgb.pdf (PDF preview)
5 key posts have been marked in this topic (Show topic index)
There are 7577 posts in this topic. You are on page 145 of 152.
#7201 41 days ago
Ok I’m updated. Will check out that battery holder.
#7202 41 days ago
Quoted from DANGERTERROR:
I have to set my time and date every few weeks. Credit dot shows up. Any idea what is causing this?
https://pinside.com/pinball/forum/topic/mmr-owners-club-all-things-mmr-discussed/page/122#post-5661848
#7203 41 days ago
Just waiting on my HD Color chip to arrive, will be interesting to see what version software update comes with it. My LE is still on version 1.00, I have only just bought it and it wasn’t used hardly at all with only 50 plays on it. Also got the box.
Are people without the latest hardware updates installing the latest software update 3.00 I think with the topper, XL display/speaker and GI updates? Can this be used if you don’t have these additions? Think this one has the sub control is why I ask which could be handy.
#7204 41 days ago
Quoted from Lostcause:
HD Color chip is just a long integrated circuit your swap with one under the playfield. It doesn't have a software update so to speak.
Did you check the first page of the CGC menu ? ( page 1-10 in the manual or
If you want them to work. I'd put in the newest update.
Yes.
#7205 41 days ago
When I got my color chip it came with a chip puller and a version 2.02 code update taped to the inside of the plastic container.
#7206 41 days ago
Cool thanks guys
#7207 41 days ago
Does the Mantis MErlin protector cause rejects?
#7208 41 days ago
Quoted from cooked71:
The Cliffy protector does not....mine is money almost everytime
#7209 41 days ago
I have both the Cliffy and Mantis installed and the Merlin works fine.
#7210 41 days ago
I also have cliffy and Mantis and all works great.
#7211 40 days ago
my dealer built in the 4pc Mantis protector set incl. Merlin hole. I had to remove the Mantis merlin protector in my MMRRE cause of many problems (e.g. kicker got stuck).
there are some comments earlier about this hole protector
#7212 40 days ago
Quoted from Pin-Pilot:
Did you have to do something additional work for the Mantis protector to get it to fit? I can fit it just fine for MM, just not for MMR.
#7213 40 days ago
To clarify, I only have the cliffy on the Merlin hole.
#7214 40 days ago
Look what I just dragged in from the porch.
#7215 40 days ago
Quoted from TechnicalSteam:
Sweet! Please upload pics of the RBG playfield kit uninstalled if you can.
#7216 40 days ago
You got some work to do Sir!
#7217 40 days ago
I'll unbox them here some point. Not sure when I will get around to installing them.
#7218 40 days ago
Quoted from Nepi23:
I believe I used a Dremel tool to thin the Mantis protector. Trial and error trimming the thickness got it just right.
#7219 40 days ago
Quoted from TechnicalSteam:I'll unbox them here some point. Not sure when I will get around to installing them.
Welcome to the upgrade party pal!
It’s probably a 6 hour job if you’re organized and efficient and everything goes well. It was more like a 10 hour job for us, hahaha.
#7220 40 days ago
Quoted from gunstarhero:
This is why I am keeping my day job. I never know how long things going to take when I crack open my game. Clean this, check that and the O'shit what
came unplugged or disconnected in the process.
#7221 40 days ago
My HD color chip and Mantis kit should be here very soon so good to know the Merlin protector needs careful attention to operate smoothly.
#7222 40 days ago
Was the RGB lighting particularly difficult?
#7223 40 days ago
Quoted from tpoeckh:
It was the biggest and most technical but kind of the easiest task since there was no drilling, sawing or breaking out cab parts. The pop bumpers (where you have to cut and splice the leads) was probably the worst part, and we needed to modify the glass channel a little bit so it would fit low enough in my cab to work.
#7224 40 days ago
Installed acrylic speaker grills received from kapsreiter.
Pro Tip: Don’t fully remove all four anchor screws at the same time. Makes the install much easier!
15F0C1C1-D45E-4773-B05B-58D0D428B023 (resized).jpegB20B2FCF-BF8F-4C2C-9493-B0504F77BE54 (resized).jpegC8151FF0-B579-4427-B810-D2C1F65900D9 (resized).jpeg
#7225 39 days ago
Got my HD color upgrade kit today and they now do not include the mini SD card with software update.
Instructions just say fit the chip, no mention of software update for it to work. I have an LE on version 1.00 still as it wasn’t used. Guess I need to buy a mini SD card and workout how to get the info onto it, great.
#7226 39 days ago
Did you check the first page of the CGC menu to see what is in your game ? ( page 1-10 in the manual )
https://www.chicago-gaming.com/coinop/medieval-madness/update complete instructions on what you need and how to do it.
I'd try it anyway. If it doesn't work, pull it out and put the old one back in, then update the game.
#7227 39 days ago
It has the first version as the guy I bought it from (Judge Dreads) did not use it or update it so pretty sure the chip will not work.
I have ordered the mini SD card and downloaded the latest update into my Mac, so will hopefully get it on the card tomorrow and all will be good.
Hope I don’t brick it, annoyed it did not include the card though with the update. For the cost it should have.
Is it going to put version 3.00 in as it says Medieval Madness 300 installer?
#7228 39 days ago
yes it will.
Neil.
#7229 39 days ago
A question for anyone that has already done the 3 upgrades. Is there any specific order that you would advise? Meaning, should you do GI first, then screen and sound, then topper? Or is order irrelevant?
#7230 39 days ago
I will try this, is there a way to test before I apply the tape?
I wanted to order HD glass, so should figure out.
Quoted from LTG:
Is it the playfield glass ? If so a little black electricians tape along the long edge.
#7231 39 days ago
Quoted from SkaterVet:
I think I’d do lighting, topper and then screen. I did the screen first and then had to unplug and remove it (no biggie but wasted time all the same) when I needed to work in the backbox, especially the drilling and cutting for the topper.
#7232 39 days ago
If someone could post a photo of the rgb lighting Uninstaller it would be greatly appreciated. Trying to gauge the size of the job
#7233 39 days ago
Quoted from sataneatscheese:
It is a 30+ page booklet with lots of pictures and states an Intermediate Level of experience working on pins is required.
#7234 39 days ago
It was certainly the biggest job but besides cutting and splicing the pops and drilling the holes for the board in the backbox it was all screws and plugs. You just remove and replace all the short lighting strings then run a long harness from the backbox that connects them all together.
I would say the topper was the worst because you cut a hole in the cab, followed by the new cab speaker, because the old one just didn’t want to come out.
#7235 39 days ago
I’ve been running the flipper strength at -5 on my MMr and MBr and have been getting tons of air balls. Finally got around to changing them to -9 tonight. They both play so much better. Wish I would have changed them sooner.
#7236 39 days ago
I would like to replace the two red flasher caps in the backboard/behind the castle by transparent caps. Are the red ones installed standard flasher caps? Could you provide me with the part no. of transparent ones, which fit in the backboard?
#7237 39 days ago
Was it a "difficult" install for all 3? Time consuming?
Would you do it again?
Only reason I ask is I'm not sure if I'd sell an older machine and then buy a Royal....or, put myself to install all the new parts to essentially make it a Royal...
They're fun either way!
#7238 39 days ago
Quoted from Highscoresaves:
So it probably took about 10 hours between a friend and I, but a lot of that was me mucking around making the cabinet work harder than it needed to be I think. Probably about 6 hours if you’re organized and efficient.
The MOST stressful part for me was the cab speaker mount because it just didn’t want to come out clean. The next was cutting the hole in the top of the cab for the topper wiring. I know for my buddy it was splicing the pop bumper wiring.
The directions are fairly clear (we did have to make adjustments allowing for MMR production changes) and there’s nothing TOO technical so if you would be comfortable doing a flipper rebuild or a shop job I’d say go for it.
If you can get a Royal Edition I will say the RE a really good looking package and I’m sure it would be nice to just have it done for you (plus I’m pretty sure the pops color change, which they don’t with the upgrade) but I’d install the upgrades again if I just happened to have another MMR and the parts.
#7239 38 days ago
Yes, the pops on the Royal color change.
#7240 38 days ago
Got my upgrades yesterday and got the topper and speaker/display installed. That topper is beautiful.
Few issues in terms of what came in the packaging/install
1) back left hole for topper screw is right where the kicker plate is
2) the template location for mounting the topper board is too low and the cables won’t reach it, had to move it up 1.5”
3) the grounding cable has too small of connectors on it to connect to grounding spades
4) rear glass guide/trim lighting, my guide/trim was stapled in and not screwed so had to make new holes for the new lighted guide/trim screws
I haven’t done the rest of the RGB lights yet, those are up next and I assume I’ll run into a few things there as well!
Didn’t bother with the sub upgrade as I upgraded mine years ago with a dedicated amp and sub box under the playfield (way before TNA was even a thing and did it) Whatever is in the box they sent won’t be anywhere near as good as what I already have. The new speakers are not as good as what I had either but the size is different now so I will have to figure that out as well.
#7241 38 days ago
Also noticed the 3.0 update drastically changed the shaker settings, it’s considerably stronger now.
Also what is “shakey” vs “lengthy” lol
#7242 38 days ago
Quoted from chrisnack:
Shakey shakes more. Lengthy shakes longer.
#7243 38 days ago
Quoted from LTG:
Sounds like my wife....
#7244 38 days ago
I had all the same issues. Plus I did install the sub and the included screws were too short.
#7245 38 days ago
She didn't sound like that for me.
#7246 38 days ago
Anyone experience an issue with the flipper strength reducing over time?
#7247 38 days ago
Quoted from Gritty:
Reseat the driver board they plug onto, into the huge board under the playfield.
#7248 38 days ago
Quoted from LTG:
Classy Lloyd!
#7249 38 days ago
Updated to version 3.0 and installed the HD color chip yesterday and all good, also noticed the shaker motor power has been changed.
Still too powerful on the lowest setting, was much better before. Shakes too violently now no matter what power setting and noisier.
#7250 38 days ago
Quoted from LTG:
compared to the default settings "shaky" vibrates with more actions. e.g. the spinners vibrate with shaky too.
yes, the shaker is also very strong (MMRRE), i mostly use "light" together with "default" or "off
€ 8.10
Buthamburg
$ 44.00
