(Topic ID: 128232)
MMR Owners Club, all things MMR discussed
By SuperPinball
6 years ago
  • 8,880 posts
  • 663 Pinsiders participating
  • Latest reply 3 hours ago by glpinball
  • Topic is favorited by 346 Pinsiders
5 key posts have been marked in this topic (Show topic index)
There are 8,880 posts in this topic. You are on page 140 of 178.
#6951 1 year ago
Just joined the club after wanting an original, right one never came up.
Well it payed off as the mod Meister Judge Dreads just sold me his and is as good as new, he never used it! Box included.
Still on V1.0 so need to update that and to HD. Thanks JD
#6952 1 year ago
"MMR Classic Edition - same as MMR standard edition, but plywood bottom and finished backbox edges is standard now - original MSRP $8,000. Can anybody confirm that the color DMD upgrade sold for use with the standard edition works with the CE? Thanks!"
MMR Standard has a plywood bottom as well.
#6953 1 year ago
The CE is the standard just MMR is using the modeling of the other 2 remakes now.
#6954 1 year ago
Quoted from smallstocks:
It is not moving at all anymore and does not work in test either.
In test - did you pull out the high power interlock switch by the coin door ?
If so, then check the coil for a broken wire.
#6955 1 year ago
I've been working with Cointaker to create a colored plastic protector set that will include 9 pieces + the one that protects the one that Westsiderkg create.
I will be a little while before I can post pictures but I figure id let you all know its coming.
#6956 1 year ago
The graphic problems are confirmed now by a lot of people with upgrades to V 3.0.0
i also noticed this not in the past.
sometimes the first second of an animation is low res and green
any news from CGC? my tivket is unanswered until now
already did a factory reset, no change
and its not the colorchip, it is not loose and was working until the update without this.
#6957 1 year ago
Quoted from kapsreiter:
Hmm, that's the royal edition you are showing (since the loudspeakers are changing colors?)?
Its kind of surprising if they would not have tested the unit at the factory for the screen.
#6958 1 year ago
Some people on the MBr thread have had the same issue. At least one of them (maybe more) have fixed the problem by re-installing the software update.
#6959 1 year ago
Quoted from Nepi23:
No it's not.
Quoted from mbeardsley:
I'd try that.
#6960 1 year ago
Quoted from LTG:
No it's not.
I'd try that.
realy?
they are always different
could try it but don't believe
#6961 1 year ago
Joined the club with a MMR Royal that CGC released to a distributor last week. I grabbed it up less than 10 minutes after the distributor posted it. No damage or problems so far. Lloyd helped me out with the topper instructions as those wiring instructions evidently don't exist. Thanks Lloyd!
20200805_143238 (resized).jpg20200805_144706 (resized).jpg20200805_154621 (resized).jpg20200806_200437 (resized).jpg20200806_200846 (resized).jpg
#6962 1 year ago
Quoted from KingBW:
[quoted image][quoted image][quoted image][quoted image][quoted image]
ty, which apparently means that there are more than 350 Royals (#355 you got)
#6963 1 year ago
Quoted from Cayenne:
According to the distributor, the two that he got were claimed by CGC to be the last ones that they had. Maybe held back for some reason. So #355 COULD be the last one ... until they decide to make more. ???
#6964 1 year ago
Quoted from KingBW:
my distributor, talked reguarly with CGC, told me that it could possible in some years, but not the RE
#6965 1 year ago
For completely selfish reasons I wish they would just come out and say “no more Royals will be made”.
#6966 1 year ago
realy?
it makes no difference when i install the software again
same problems
#6967 1 year ago
Quoted from KingBW:
Love your pinball cover. Where did you get it!
Cheers
Craig
#6968 1 year ago
Question for you fellow remake owners. I've just noticed that my left flipper strikes higher than the right one. Are you seeing the same or do I need to make an adjustment? As I look at the photos, I think the left one needs to come down a little or the right one needs to come up a little... hmmm... what say you guys?
#6969 1 year ago
I have an extra lockdown bar. Royal Edition powdercoat. $55 + shipping. PM me if you want.
#6970 1 year ago
Likely the last batch of missing center lane plastics I plan on making....hope these go to great homes, when they're gone they are likely not coming back!!!
thumbnail_20200808_133321 (resized).jpgthumbnail_20200808_133339 (resized).jpgthumbnail_20200808_133405 (resized).jpgthumbnail_20200808_133423 (resized).jpg
#6971 1 year ago
Quoted from HeadNZ:
Cheers
Craig
35% off currently ... 60x51
https://society6.com/product/medieval-knight-templar-in-purple-smoke_throw-blanket?sku=s6-13721275p49a64v437
#6972 1 year ago
Quoted from Westsiderkg:
Likely the last batch of missing center lane plastics I plan on making....hope these go to great homes, when they're gone they are likely not coming back!!! [quoted image][quoted image][quoted image][quoted image]
Can you make some plastic protectors for this piece?
#6973 1 year ago
Quoted from wolftownjeff:
Can you some plastic protectors for this piece?
I am working with coin taker on a full set.
#6974 1 year ago
My friend has a MMR SE NIB and after a week of playing, the right pinball finger hangs.
According to distributor this is a known problem of Bally.
Is there a good turorial/DIY available how to disassemble a pinball finger and fix it?
#6975 1 year ago
Is it loose shaft and flipper or is just the plastic flipper piece broken?
#6976 1 year ago
Quoted from underlord:
nothing broken, the attached srew with the washer (gore) in the mechanic is the problem. if you fix it, it jump out
Dealer told him, its a known problem
#6977 1 year ago
Threads look stripped at the end?
#6978 1 year ago
Easy fix - your dealer can provide parts and tell you how to fix it.
#6979 1 year ago
That notched washer at the end is pressed in there. I’m not buying its a known problem. Over tightening the nut can be a problem as it will pull it right out. I did that once on an older title which is why i bought some spares. And 5 years later haven’t used one lol.
If your distributor is saying “known problem - i’ll take care of sending you a new part” that’s one thing. Sounds more like they are saying known problem = your problem.
#6980 1 year ago
I highly doubt its a "known" problem as I've never heard of it....easy fix
#6981 1 year ago
Quoted from Completist:
If your distributor is saying “known problem - i’ll take care of sending you a new part” that’s one thing. Sounds more like they are saying known problem = your problem. [quoted image]
Is that really the pinching bolt for the flipper shaft? Jeeezzz...
#6982 1 year ago
Butch is the man.
#6983 1 year ago
Quoted from LTG:
Butch is the man.
Great, ty Lloyd
#6984 1 year ago
Yeah, this is some 3rd party's "redesigned" flipper pawl - it removed the locknut and replaces it with this split washer. I can't effin' STAND them. I will go out of my way to fix an origianal. Sure, it's ''easier'' only needing a hex screw, but I've had too many of them break to make it worthwhile.
#6985 1 year ago
Quoted from Coyote:
This is what happens when they mess with success. I deal with this crap on new model cars and trucks all the time. Constantly correcting ‘new’ and ‘improved’ engineering ideas.
In the end it’s about parts availability and sometimes cost cutting. I’m thinking the former on this one.
#6986 1 year ago
Love this game.
This and Metallica are the only games my 18yo son will actually play. So for that it's worth every $.
#6987 1 year ago
any news about the graphic bugs?
did someone get an answer to his ticket?
#6988 1 year ago
Extremely disappointed that the RGB kit and the XL display do not add color changing speaker surrounds. They remain blue only.
Hopefully someone makes a work around for this problem. It was the thing that swayed my decision to go for the XL display to finish the RGB ‘package’ with the color changing speaker surrounds matching the PF RGBs.
I don’t think I would have outlayed the $$$ if I had known that in advance, I had already upgraded the panel speakers and not too worried about the smaller display.
I can live without the pop bumper rgb’s but wish the speaker surrounds were intergrated ☹️
#6989 1 year ago
Quoted from ktm450:
Same here....I cancelled my order for the larger display/speaker upgrade because of that.
#6990 1 year ago
Quoted from ktm450:
I cancelled the display and RGB kit as well.....not worth the $ and I really wasn't fond of just tossing the existing panel which is perfectly fine. I'll just install the topper and call it good
#6991 1 year ago
Quoted from indypinhead:
this is not true!!!!!!
rgb speakers are included in the game, have this already running
you just need to change the cable
#6992 1 year ago
Can you please tell more about which cable to put where?
#6993 1 year ago
you must connect the 4 rgb wires to the connector of the backboard rgb string
the new connector must look like this
#6994 1 year ago
Anyone have any dates when the RGB kits/Topper/Speaker panel will be available here in the US? I called a few vendors and they all say soon. Soon as in 1 week or 1 month, etc.
#6995 1 year ago
the new connector must look like this[quoted image]
My cable is different - was yours included in the kit or where did you manage to get it?
#6996 1 year ago
Its Not different.
I See the cable at the Right
And you Must ad the 4 wires
To the connector housing
#6997 1 year ago
Its Not different.
Can you provide drawings? Once the 4 additional wires are connected to this connector, where do those wires go?
#6998 1 year ago
See My pic this is the backboard strip connector with the 4 add Pins from the speaker
#6999 1 year ago
Why wouldn't CGC provide this as part of the kit?
#7000 1 year ago
Could you kindly post a photo of the wiring loom from the topper board to the backbox speaker panel and all the wiring on the speaker panel?
