First off if you want to flame MMR or CG take it to another thread. Tired of this bickering and this is a thread to move forward with the issue. CG has been more than accommodating to fix the issue. I received an update from them today and wanted to relay it to anyone interested.
Before that I want to clarify my issue as there has been too much flaming of the playfield and blaming the thin black coloring.
I have no problems with the thickness of the ink from day one. My issue has always been the inserts were to faceted and reflective like a stop sign, etc. Add the super bright LED's and it compounds the issue. I have always said if the inserts were more frosted it would not be an issue. I have had 25+ machines and this is my opinion based on looking at the others.
If you do not have positive comments OR do not own a MMR then take them elsewhere.
CG has been experimenting with diffusers in the insert along with software to adjust the brightness and it has made a big difference.
They will be putting them on all new machines and when distributors get them we will get them. Also the new software will allow us to adjust the brightness.
The inserts CG used in the machine with the bright LED caused a unforeseen issue. They have worked hard to fix the issue and all I can say is I am 100% satisfied with their communications with me and look forward to the result.
I love the game and love the craftsmanship and will be in line for their next title.
So moving forward we all should see soon new software, diffusers and then this spring the color kit.
Let the drawbridge down and start partying with the Duke of Bourbon!
