(Topic ID: 272782)
MMr constant multiball
By DumbRecords
1 year ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 1 year ago by DumbRecords
#1 1 year ago
Hi, I keep having an intermittent issue with my Medieval Madness Remake SE where the game will start spitting out balls like you're in multiball even tho you aren't.
I had this problem about 6 months ago, which led me down the path of testing the trough optic emitters and receivers. I learned how to do that with my phone camera and flashlight. I eventually couldn't find a fault and just replaced 2 new trough optic boards with new boards from pinball life, which worked fine until last week when the game started having the problem again.
I tested all the emitters and receivers again, and also I reflowed the solder on everything on the board, including the connector. It worked for a few days and then started having the problem again.
I figure I'm missing something. It would be easy if one of the optic leds failed the test, I could just solder in a new one, but this is turning out more puzzling than that. I'm starting to wonder if there is a problem somewhere else in the game that's causing this issue.
#2 1 year ago
Power off. Reseat the connectors to the ball trough opto boards.
Only 4 balls in your game ?
Balls not magnetized and rolling down the ball trough good ?
#3 1 year ago
I tested the balls to see it they were magnetized, they didn't pick up a paperclip or anything. Also I'm not seeing any divots in the trough.
I did think to reseat the connectors from the trough boards to the other boards which I haven't tried yet. I did that and the game worked fine for the rest of the night, so will see if it stays that way
