OK, so here's the results on the Pyramid DBA. Its in and its working, that's good and it was available with a 200 note stacker which fits fine. Just plugged it in to the 9 pin connector in the game, set the dip switches, and away it went ringing up credits. The bad news is that it was a serious bitch to install. I selected an upstacker like my other pins and the lower DBA hole in the coin door has some metal tabs in the upper corners that I had to file off to physically get it onto the door as the tabs interfered with the DBA. Then the screws that came with the door weren't long enough to work but fortunately my location had some longer ones with the same thread. Then the wiring harness that came with it is really short and I have to be careful opening the coin door not to yank connectors out. Its in, kinda crooked, but working and sucking in people's money.
So it looks like LTG's original suggestion of the other one from Suzo/Happ is the way to go with this. I'd be curious to hear reports from other DBA installs.
