Quoted from Warbound:Is the cabinet as stout, or better, than original?
The cabinet and playfield are made by the same company that made the original, CCC.
The new cab is stronger/stiffer, because it has a real Plywood bottom, not crapboard like the original.
The circuit boards are different, as is the modern, efficient, power supply.
The clearcoat is better on the MMr playfield.
The MMr cabinet has decals, so that is certainly NOT as good or durable as the original silkscreened cab.
Most of the mechs are exactly the same, but some, like the flippers, are stronger and can now can be software controlled.
The sound is clearer on the MMr.
The LED lights will probably never burn out in your lifetime on the MMr, and no old lamp sockets either.
The display is in color when it boots up, but then it goes to monochromatic mode in gameplay.
Still a few little bugs to iron out, but I've put a ton of plays on it and it is a worthy successor.
