I have a customers machine im working on. None of the playfield gis work at all. Backbox works fine. Playfield has none. Pulled all fuses and checked. All are good. Reseated all connectors. Still nothing. Is this a known problem?
Quoted from CaptainNeo:Is this a known problem?
No.
I'd check if they still have power and then go from there. Also check power supply on floor of the cabinet near the front.
Quoted from CaptainNeo:They are unsure if they ever worked
Unplug the game, check connectors to transformer in the rear of the bottom.
Check fuses on board over on/off switch
Problem fixed.
She changed a setting from White to interactive in the settings, and now they work again. And shows white. WTF Chicago Gaming? WTF? Why have it as an option if it doesn't work at all?
Quoted from CaptainNeo:Why have it as an option if it doesn't work at all?
Because it probably works in MMR's that don't have RGB lighting.
This page was printed from https://pinside.com/pinball/forum/topic/mm-remake-royal-edition-gis-stopped-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
