(Topic ID: 254865)
Mm low power coils out
By aeneas
6 months ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 6 months ago by hoby1
#1 6 months ago
Original mm, worked fine.
During playing suddenly the ball gets stuck in the merlin saucer.
Ok no problem I think, probably a wire came loose..
Now I do the solenoid check, all low power solenoids on fuse f102 are out.
No problem I think, bad fuse.
So I measure the fuse, it's ok..
Maybe the problem is further on the wire on j133-3 ?
Connector j133 - all 3 pins have 70vdc.
Weird.. so maybe the red wire broke further ?
I start measuring under the playfield, no broken wires, and all coils have 70vdc.
When I ground the purple wire of a coil that doesn't work (like merlin eject or pop bumpers) the coils work.. so the red wire or that fuse is not a problem?!
Now I am stuck. What can cause all coils on f102 not to work(in game or selftests), while there is power present ??
Asic / flatcables / .. ? The machine was working well, after being played half an hour this happened.
#2 6 months ago
Quoted from aeneas:
Asic / flatcables /
That would be the best start.
Machine 'OFF' and reseat the ribbon cable between cpu- and powerdriver-board.
Give the asic a gentle push into its socket.
#3 6 months ago
Removed the asic, put it back in, and everything works again.
Weird that it caused this issue..
#4 6 months ago
Good to know. That is an odd one.
#5 6 months ago
Quoted from aeneas:
Quoted from aeneas:
Well the pic does control flipper power. Kinda makes sense
$ 279.95
Pin Stadium Pinball LEDs
Trade
Machine - For Trade
San Mateo, CA
