On my original MM, when the trolls are both up the left troll flap sits lower than the right troll flap. This is because the left troll flap is in direct contact with the habitrail return ramp from the Peasant ramp, and it does seem that the entire troll mech pushes up somewhat on that ramp. The left troll does come up so that the mechanism is properly flush with the playfield so the troll works correctly, but that troll mech contacts the bottom of the Peasant ramp habitrail. It has always been this way on my machine, but I bought it used so I don't know how it would have been when delivered from the factory.
Is this normal? It certainly makes it hard to keep the Peasant return habitrail adjusted properly so the ball doesn't fly off that ramp. I'm wondering if I need to shim the mounting points at the top of the Peasant ramp and perhaps elsewhere on the return habitrail so that the left troll mech and flap don't contact the return habitrail when the troll is up.
How does this look on your machine?? Did you need to make an adjustment?
