(Topic ID: 182557)
MM ball ends, trought optos working fine
By forensicd
  • 25 posts
  • 8 Pinsiders participating
  • Latest reply 3 years ago by whthrs166
#1 3 years ago
Ok, i am at a loss on this one. Recently have had the issue where the game will think the ball has ended while still in play. I have checked all of the trough optos several times over and all function correctly. Not sure what is going on, as it think s the ball is in the trough and will then kick out two balls.
#2 3 years ago
Only four balls in the game ? Not 5 ? Or three and one stuck somewhere ?
#3 3 years ago
Quoted from forensicd:
It still sounds like a jam opto problem or a connector problem. Could you have a bad solder point or intermittent opto problem?
#4 3 years ago
i think its the trough, just watched the balls ans they arent going all the way to the end
#5 3 years ago
When i bought it it had one of those plastic pieces in the trough, but it doesnt appear to be working any more.
#6 3 years ago
Magnetized ?
Or divots on the bottom of the V where they roll - if so, remove the ball trough, coil end and opto boards. Big flat bastard file in the open end and go to town, file those divots smooth.
#7 3 years ago
Ok here's the update. Bought new trough and optos and installed. Still getting same issue where game will just end in the middle of the ball. Any more ideas?
#8 3 years ago
Quoted from LTG:
Magnetized ?
Are the balls magnetized ?
#9 3 years ago
Changed balls out and still the same result. The game will just end. Checked all the new optics and all work perfect.
#10 3 years ago
Also just for reference I was watching the trough the whole time while buddy played and balls never got stuck or moved. Game would just end if no apparent reason ( as in it thinks the ball drained).
#11 3 years ago
bump for some help!
#12 3 years ago
Switch matrix issue ? Triggering the last opto in the ball trough, switch wired wrong, short to switch wiring, diode on backwards.
If you worked on the machine and this started, I'd check that first. If not and it started on it's own, I'd check ramp switches that balls could hit the wiring on first.
#13 3 years ago
Like LTG said, check the ball trough for divots by observing if all the balls in the trough move when the trough popper ejects into the shooter lane.
If the balls are hanging up, then roll down during a ball in play, could make the machine think the ball ended.
#14 3 years ago
I see you observed the trough already.
Sorry.
Like LTG said...probably a switch matrix (likely a switch diode) problem. Take off glass, start a game and see if a certain switch is causing the end-of-ball.
#15 3 years ago
I had to put some washers under one end of mine to give the balls a better angle to get all the way down. And there was some type of forked mod for those troughs that just slid in and spring clamped to the bottom. That also was part of the cure because of uneven spots and divits on the edges of the center slot.
#16 3 years ago
ok, heres the latest. I have replaced the trough and put in new trough optos. Still getting the issue where it will end then kick out two balls. It seems like it has the be the 10 opto board under the playfield. Would this be my next option?
#17 3 years ago
Some thoughts, may help.
Did you try a factory reset ? Made sure balls aren't magnetized ? Run through switch edge test and hit every switch and are sure the correct ones register on the DMD, to rule out switch matrix issues ?
#18 3 years ago
Another thing to check is the voltage levels at the test points on the board. Do you have a ColorDMD installed? That can cause the voltage to drop too much and then optos can act up.
#19 3 years ago
Thanks all! I will check everything when i get home. It has worked flawlessly for months and months and then just started to do this, so I figured it had to be trough or optos.
#20 3 years ago
Quoted from DCFAN:
If so, unplug the power connector to it and play a game blind. See if problem remains.
#21 3 years ago
Quoted from LTG:
To go even further, I would disconnect all mods that are electrical (shaker, lights, topper etc.). If that solves the problem you could start adding them back one-by-one until the problem comes back.
#22 3 years ago
Quoted from pincredible:
Sorry.
This sounds like a good idea, have you tried this yet forensicd?
#23 3 years ago
Got a buddy picking up a pin then will get on trying all of these.
4 months later
#24 3 years ago
I wanted to conclude this thread as i purchased the mentioned game from the OP. The issue was left loop switch 65#, cold solder on the white-green parallel joint. by moving playfield slightly in switch edge test, i was able to open the ball 4 trough circuit on the switch edge. hard to find but found. thank you all for the prior comments i used them to lead up to the final conclusion.
#25 3 years ago
Thanks for your post on conclusion. I have been following this thread (since I have a MM) from the start. What an amazing find and fix good job.
$ 8.50
$ 11.00
$ 99.00
Arcade Upkeep
$ 36.99
Lee's Parts
$ 11.95
$ 209.00
KAHR.US Circuits
€ 8.10
Buthamburg
$ 26.50
9,600
Potomac Falls, VA
$ 229.99
$ 279.95
Pin Stadium Pinball LEDs
$ 119.99
Cabinet - (Alt) Translites
FlyLand Designs
$ 95.00
M&M Mods
12,500 (OBO)
Huntington Beach, CA
$ 259.95
Gweem's Mods
$ 395.00
M&M Mods
Arcade Upkeep
$ 16.50
