New! Dark mode!
(Topic ID: 272079)
Missing 20v - Creature From The Black Lagoon
By at1105
3 months ago
  • 8 posts
  • 3 Pinsiders participating
  • Latest reply 3 months ago by Ronkz650
#1 3 months ago
I recently got a CFTBL and noticed the flashers weren’t working. It has a Rotten dog driver board and cpu board. Opened the head and noticed the 20v LED isn’t lit. I have checked the fuses and they are all good. The interlock switch is good but strangely doesn’t have any effect when opened. The voltages at J102 connector are
When plugged in
Pins 1&2 - <1 VAC
Pins 3&4 - 16.6 VAC
When NOT plugged in
Pins 1&2 - 11 VAC
Pins 3&4 - 5 VAC
Not sure where to go from here. Any ideas?
#2 3 months ago
Plug J102 back in.
Power on.
Measure AC voltage between J102 pins 1 and 4.
It should be about 18VAC.
Report back.
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact ... for board repairs
#3 3 months ago
Quoted from ChrisHibler:
Plug J102 back in.
Power on.
Report back.
Between pins 1 & 4 measures 17 VAC
#4 3 months ago
Quoted from at1105:
That's good. That is what it should be.
Remove and "buzz" F111 to ensure that fuse is good.
After that, next step is to test BR4.
#5 3 months ago
Fuse tested good. I couldn’t locate BR4. This Rottendog board doesn’t seem to have one.
#6 3 months ago
Oh. Forgot it was a RD.
Follow the trace from F111 to a pair of large diodes. Those two diodes will also connect to two other diodes. Test all four of those diodes.
Http://chrishiblerpinball.com/contact
http://www.PinWiki.com/ - The new place for pinball repair info
#7 3 months ago
It’s fixed! I checked those diodes and they tested good so I went back and pulled the fuse again and it tested bad this time! Strangely it tested good the first time. Not sure how. So I replaced the fuse and the 20v is back.
Thanks for your help!
#8 3 months ago
Glad it's fixed. Best way to check fuses is to simply check volts on both ends. Of course both ends need the same voltage, whether it be AC or DC. No need to ever pull a fuse out to check it. Check between J102 pin one and the fuse would have revealed you had 17vac on one end, 0vac on the other end and for sure that means a bad fuse.
$ 9.99
$ 5.00
PinSound
6,000 (OBO)
Johnson City, TN
