This just started happening but the 10amp fuse for the playfield lights kept blowing. When that fuse goes out... everything works the same except the playfield lights go out. I was able to isolate the issue to the D passive bumper. I took the light bulb out and now it doesn't blow the fuse. I don't see anything wrong with the wiring on the outside. I am not super excited to try and take this apart. I do not want to replace the socket. Can I use a slow blow fuse or would an LED light help... lol I know I shouldn't be looking for band-aid fixes. Are there any tricks I should try before pulling the bumper apart?
It doesn't blow super easy. For example, I can turn the D bumper light on and let the machine sit there on (like in the pic) and it wont blow. It is only when it is switched on in play and then other switches around it are activated that it is too much for it and the fuse eventually breaks. That is why it took a bit to figure out where the issue was, because the ball hits the D bumper but then it doesn't blow right that second it has to bounce around some more.
