BR, so did you put screws in them at all? At the 7 minute mark you grab the drill and I could not tell what you were doing? Thanks for the vid!
I knew someone was gonna ask that Question , I was moving some kinda metal ( Thang's ) Stern has on the cab- wall's , I had 2 turn the 1 on the left-side / side-ways ... I used NO screw's when installing the Blades ..
On Bally/Williams how do you remove the bolt for the backbox hinge? This needs to be done as far as I understand. Is that bolt grounded?
Shanetastic Nail'd it to the Tee .. And the Bolt Isn't grounded .. I' will tell you 1- Thing , When I installed Mirror Blades on HS2 , You Better Stick a Good size bolt thru Poking inside so you Can Line up the Hole Rt the 1st tyme ( Trust me )
Dang right! Well, not a mirror blade, but it is a custom cut piece of mirrored acrylic. It was something like $12. I can't remember the website I ordered it from, but there are probably several sites out there that could cut one to size.
I Still have the receipt where I purchased the Pre-Cut Acrylic Mirror for TZ , S.t liked mine so I Passed it down the Line .. Brother member Out-West in FairOaks , CA sent me the info ..
Also , The Mirror Blades I installed on Tron came from Pinball decal's and were $ 142.00 ship'd
CoinTaker's Mirror Blades are $ 114.00 then you use Our PINSIDE 10% discount , $ 104.00 ship'd
http://shop.cointaker.com/category.sc;jsessionid=CB12306A1C7FCF330A3271CF270D5F0A.qscstrfrnt02?categoryId=214
