Quoted from MikeO:Let the Blitz cure for a minimum of 24 hours before you reapply or the new coat will just cut the previous coat away and be ineffective. I believe it presents this right on the instructions on the container.
So do I keep it on there hardened for 24 hours before I wipe it off? I am confused.
Anyways...I just wiped off the first coat and OMG! AWESOME is an understatement! This playfield GLEAMS like a 400k Italian sports car.
So here is my final order....
1. 91% alcohol on Magic Eraser for ball swirls. Ring out the Magic Eraser so it is just slightly damp. Work slow 3 inch by 3 inch areas with very light pressure. Do this for no more than 5 seconds on an inconspicuous area first. Check for any paint loss. Work 3 inch by 3 inch circles for no more than 10 seconds. Immediately use a dry clean microfiber cloth to soak and dry the area just wiped. Repeat until desired results are reached and entire playfield is clean and ball swirl free. I can't emphasize this enough....Go slow as a turtle...This is not a race. If you see a yellowing lacquer on the Magic Eraser then immediately stop. If you see small chips of paint or any paint...STOP.
2. Use a microfiber applicator and pour light amounts of Novus #2. Use this to rub down the playfield and it does a nice job of cleaning up white residue from the alcohol along with any surface ball swirls you might have missed. After it dries and hazes up use another (different) clean microfiber cloth and wipe off the dried up Novus #2.
3. Grab a bottle of Millwax and use a clean microfiber applicator and apply liberal amounts to the playfield. Let it dry about 15-20 minutes and wipe off. You should notice a HUGE difference in the shine of your playfield. Apply a second coat of Millwax. Again wait for it to dry and haze up and then wipe off. Your playfield should be very clean and shiny.
4. Grab a container of Blitz "One Grand" wax and a "blitz applicator sponge" they are yellow and cost a buck a piece (both available at Pinball Life's web site) Let it dry and haze up and then wipe off.
This is as far as I have gotten and my results are beyond amazing! Don't believe me? Try it yourself on a moderately ball swirled playfield that is moderately dirty from a normal 500 plays. Everybody has what works for them but I really went the extra mile testing all this stuff out. I must of spent a week asking people what they though of all the different products
I do like Johnson's paste wax and I would give it a B+ but Blitz is OMG an A++++ worth every penny. To quote Odin "It is The Shit"
