Sorry for the English translation. Do you know why the second ball that enters the holes in the miniplayfield Dr. Who, that not stay and is returned immediately?
I just picked up doctor who so I am sure someone else knows better but mine will automatically kick the ball out if I haven't lit the lock yet by hitting the center target
When you start the game, both locks are lit. Once the first ball is locked in place, you can then lock the second ball. The playfield should rise up, then lower to release both and start multiball. If this is not happening, something is going wrong. Do a switch test to make sure they are registering correctly. Does is happen one side only?
There's a few reasons that this could happen. Some are normal with game play and others could be a disconnect in some of the bundle of wires to the MPF.
My Spanish is worse than your English.
Can you make a movie of the entire mode? No translation is required
faz
I think Faz has a psychic connection to all Dr Who problems - and we thank him for this! If anyone can help - he can.
My Dr. Who was doing this exact thing and it was a problem with the Bi-Directional motor drive board Part#A-15680. The #2 ball would go into the playfield and get kicked out immediately so multiball was not possible. There are some replacement boards out there or you may wish to have your board checked for faults and repaired.
Quoted from rgb635:My Dr. Who was doing this exact thing and it was a problem with the Bi-Directional motor drive board Part#A-15680. The #2 ball would go into the playfield and get kicked out immediately so multiball was not possible. There are some replacement boards out there or you may wish to have your board checked for faults and repaired.
I just hunted this board down for mine. They are out of stock everywhere. Make a want ad and someone on here will have it. That's what I did and I had several responses. A friend of mine had the board so I didn't end up buying or from pinside but they are out there. Same board fits cirqus Voltaire, white water, and party zone
The time expander mini playfield is complicated. Very complicated. People assume that time is a strict progression of cause to effect, but actually, from a non linear non subjective viewpoint, it's more like a big ball of wibbly wobbly timey wimey ... stuff.
I had mine repaired here http://webpages.charter.net/coinopcauldron/brepairs.html along with several other system 11 boards and Gottlieb system 80 boards as well.
This page was printed from https://pinside.com/pinball/forum/topic/miniplayfield-dr-who and we tried optimising it for printing. Some page elements may have been deliberately hidden.
