(Topic ID: 293039)
Mini Playfield motor issue - The Shadow
By rvermeire
2 years ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by rvermeire
#1 2 years ago
Started a new post after I dropped it first in the shadow club. Other messages are getting mixed up so better to isolate issue.
On my Shadow the mini playfield kicker is not working and get a number of error messages (pics)
The optos on the MPF are ok on the playfield and under it.
The seperate motor board didn't have LED 'on'. Found out the grey/yellow cable +12V had no continuity to J116 pin2 where power should come from.
Thinking this was a direct connection I changed the cable and got continuity and LED got on.
Also did resoldering on the 2 connectors on the board. (just to make sure)
However it seems the grey/yellow cable is not a direct connection to J116 and also going to Opto board and diverters.
This resulting in 'check fuse F115/116 / J112 and opto 12V issue. (Fuses are OK and did reseating of J112). But of course if no powers come to the opto board (replaced gr/yel with new direct cable motor board J116) it's normal to get this error.
Does anybody have a shematic/map on the route and stop points of this grey/yellow 12V+ cable ?
Testing the mini playfield (thru display test) with opto 12V error still popped up the same error (pics)
So even I find the error on the cable GR/Yel not sure the playfield will work.
The coil is working at the kicker (when you remove all balls and pin start to search for them it's activated)
All feedback much appreciated !
error error resizes (resized).jpgerror error resizes (resized).jpgerror mini bad resized (resized).jpgerror mini bad resized (resized).jpgmini playfield under (resized).jpgmini playfield under (resized).jpgmotor pcb resized (resized).jpgmotor pcb resized (resized).jpg
#2 2 years ago
Check the voltage at test point 1 on the Driver Board. This is the 12 VDC unregulated that feeds the Opto & Motor Board
#3 2 years ago
Quoted from WH20_Buzz:
TP1 : 14.12V
TP2 : 4.97V
TP3 : 11.96V
#4 2 years ago
Replace caps on opto and motor boards
#5 2 years ago
I found a connector (2plugs) with on one side 2x grey/yellow (12V) & Black (ground) and on the other side (no grey yellow) only Black.
Brought them altogether again and opto 12V error and fuses is gone.
LED on motor PCB is on but the LED on the pcb board of my first post is out now !! (under mini playfield)
This one is also powering the 2 optos 19 and 20 near the motor.
In switch menu error is still present.
Can not activate motor (even not with white button behind coin door pushed-in) via the test menu.
I connected an old 12V adapter (despite it should be 20V) and got the motor moving the kicker a bit from left to right and opposite when I changed wires (in step by step mode).
Meaning motor is still working.
What else can I check ?
Flashinstinct
$ 259.99
5,800 (Firm)
Thornton, CO
€ 38.00
PPmods
$ 16.00
Slap Save Creations
$ 29.50
Playfield - Plastics
€ 47.00
PPmods
7,250 (Firm)
Hamilton, ON
€ 8.50
Pin-Decals
$ 69.50
$ 109.95
PinSound
$ 49.99
$ 45.00
Pinball Mod Co.
$ 78.50
$ 58.00
Pinball Mod Co.
€ 8.50
Pin-Decals
Trade
Machine - For Trade
Aurora, IL
$ 9.95
$ 43.00
Pinball Mod Co.
$ 5.00
YouBentMyWookie
5,000
$ 54.95
€ 47.00
PPmods
$ 329.99
$ 22.50
bdash's bits
This page was printed from https://pinside.com/pinball/forum/topic/mini-playfield-motor-issue-the-shadow and we tried optimising it for printing. Some page elements may have been deliberately hidden.
