(Topic ID: 16687)
Mill Wax Pinball Playfield Wax and Cleaner
By pacattack13
6 years ago
  • 91 posts
  • 34 Pinsiders participating
  • Latest reply 5 years ago by Bamaro
    There are 91 posts in this topic. You are on page 2 of 2.
    #51 6 years ago
    Quoted from Hawkeyepin:
    RobT....Holy cow dude, calm down. Have you researched millwax or been to it's site? It says right on the bottle "Pinball Playfield Wax and Cleaner". Do any car wax products say they are designed for pinball machines? Maybe you could tell me where car wax products actually do say "designed for pinball machines as well".
    "Mill Wax-- trusted by Operators and Pinball Collectors since 1976..."
    If you've missed posts where people discuss what they believe Millwax does to playfields then go look them up yourself. Why do I have to repost something you've missed?
    Your quote..."I'm willing to bet that this company simply had one of the car wax companies put one of their formulas into a bottle labeled Millwax "especially made for pinball machines".
    I don't know about betting but it looks like your ready to speculate that Millwax is also engaged in a relabeling practice. Sheesh.
    Wow, talk about completely missing the point!
    All you have done here is repeated the assertion that you already made...Millwax "is especially made for pinball machines". So apparently this means that it is the best product for pins, and car wax is a no-no? Really?
    Again, please tell me what is so special about Millwax that makes it specifically designed for pinball playfields, and what does it due that a car wax or cleaner can't?
    Please don't repeat yourself (again) by saying "well, it is specifically designed for pinball machines".
    As far as the re-labeling stuff, that happens all the time. Nothing unusual about it at all. I doubt that the Millwax company (or company that owns them) does nothing but formulate and produce Millwax.
    #52 6 years ago
    Rob just go to the Millwax site and look it up yourself.
    #53 6 years ago
    Just to clarify further: On the front label of Mill Wax bottle is says pinball playfield wax & cleaner. And on the back side instructions it says to use a soft clean cloth and apply to surface of playfield or chrome. It actually does not say to use it on playfield plastic posts or playfield plastics.
    Thus, to me, if there is a long term problem with Mill Wax deteriorating plastic playfield posts, then the playfield should first be stripped (remove plastics, posts, rubber rings, bulbs, etc.), so you can do a better job cleaning/waxing the playfield and avoid getting the liquid Mill Wax on the playfield posts.
    I guess if you are in a hurry, you can just apply it in the more open high wear areas of the playfield and just stay clear of the plastic posts.
    I've got a bottle of it, but never used it, that I bought around yr 2005.
    Novus 2 & carnuba wax seems like a good way to go for playfields.
    Thanks for all the good posts. Have a great weekend.
    #54 6 years ago
    Quoted from Pinball-is-great:
    that's what I did.. Hot Shot & 300 were "rescues"... Dirt & mold on playfields..... Did the magic eraser/ 91% alcohol , wiped down with Naphtha, Novus 2, then Milwax...
    #55 6 years ago
    Quoted from johnwartjr:
    That stuff is even too strong for the bottle it comes in, drop a bottle that's more than a year or so old, it shatters. Squeeze an old bottle too hard, it shatters.
    If it eats through the bottle, why would I put it on my pins?
    For the record, I sold a pinball machine to John Buegel, the owner of Mill Amusements in 2009. John had recently purchased the company and asked if I had a bottle of Mills Wax. I told him that I did and he asked to see it. When he saw that is was in the older white bottle he explained that they had issues with the plastic used in the older packaging and promptly exchanged it for a new bottle which was black in color. After 3 years this bottle is still like new.
    With that said, the label clearly states:
    WARNING: Combustible. Irritating to eyes, skin and respiratory system
    PRECAUTIONS: Keep out of reach of children. Wear safety glasses
    CONTAINS: Aliphatic Hydrocarbons, Kerosene, Amorphous Silica, Dimethylpoly Siloxane
    I've seen this topic brought up on a regular basis and thought it warranted further investigation. I found that Kerosene is incompatible with Polycarbonates and some other plastics to a lessor degree. The Cole-Parmer Chemical Compatability Database lists a compatibility rating D, severe effect, not recommended for ANY use.
    knowing that I would avoid use on ramps and plastics unless I knew their composition and Kerosene compatibility.
    Randy
    #56 6 years ago
    So let's break that down:
    Aliphatic Hydrocarbons - That's a broad term that classifies many compounds, but most of which are 'enes'...IE, acetylene, ethylene, isooctane. What do these all have in common? Highly flammable solvents as are most hydrocarbons. But aliphatic hydrocarbons have been tested to be milder than aromatic hydrocarbons on plastics, so that's a good thing.
    Kerosene - petroleum distillate. Right on the bottle. Kerosene will dissolve many plastics in a matter of a couple of weeks.
    Amorphous Silica - Used as an Abrasive....That's where the cleaning benefit comes from coupled with the solvents. But certainly no wax.
    Dimethlypolysiloxane - This is silicone. It was used to make silly putty. Now commonly used as a food additive for anti-foaming. A poor wax substitute, and as mentioned previously, don't want it on your playfield if you ever want to clear coat it in the future.
    So, save yourself the cost of buying millwax. Just mix some kerosene, acytelene, sand and Pam cooking spray, and you're good to go
    #57 6 years ago
    I don't care if they made Millwax specifically for pins or not. IMO cleaning the field first then follow up with a paste carnauba wax (with no cleaners in it) will get the best looking results and protection. Ive tried both ways and this is just my opinion on it.
    #58 6 years ago
    Quoted from robertmee:
    ROFL
    It is practically free and now you can buy it at fred meyer
    #59 6 years ago
    Mill Wax is OK. Personally, once the playfield is good and clean, I just use Novus #1 on the playfield. I know this will get some "oh no's", but it's been working great for me for 10 years.
    Scott
    #60 6 years ago
    so, if I wanted to switch to regular wax... having a base already built up of milwax... are there any steps I should take? Or, they're just old EM's, so it really don't matter and I'm putting way to much thought into it?
    I have no complaints about how my machines look... I DO want to do everything I can do to keep 'em around as long as possible...
    #61 6 years ago
    Is it possible to get this thread "stickied"?
    The millwax question gets asked and answered every other month, is it me or is this one of the most commonly asked questions when it comes to what wax to use?
    #62 6 years ago
    I think you are ok Juggernaut - next time you wax try a carnauba wax
    see if you like it?
    #63 6 years ago
    I've used Mill Wax for years without problems.
    I wouldn't, however, use Novus on a regular basis. #2 and #3 are slightly abrasive. Using it to get some deep down grime on a rare occasion, maybe.
    And to the person that complained about build up on posts, if this is happening with ANY cleaner / wax, you're using to much at a time! put a small amount on a cloth and start in a clear are and work outwards. And if you do end up with some on a post or other part, take a soft tooth-brush and gently brush it off. It's really that simple.
    #64 6 years ago
    Quoted from girloveswaffles:
    That is why they work, they finely polish the surface, removing small scratches. I agree, you should not use Novus2 often, use wax to clean up the play field. I use Novus2 in two or three applications depending on how hazed the play field is on the initial shop and clean, followed up with several coats of wax applied with a detail ball on my cordless drill and removed by hand. After that it only requires a bit of wax on a soft cloth to follow up and remove dirt build up from use. Looks amazing, plays amazing.
    #65 6 years ago
    It *Seems* if Mil Wax was so bad on plastics, there would be reports of damaged inserts on old E.M.'s.. I think I'm gonna gonna do when there is a dispute like this in the firearms industry.. Test it!! Gonna get some pop covers, extra inserts & if I can, find a set of slingshot plastics.. Novus 2 & wax on one as a control and the other with mil wax.. hit 'em couple times a week ea... see what happens....
    #66 6 years ago
    Well I had the pleasure of speaking to John, the owner of the millwax company recently and I can tell you for a fact he uses this product on all his machines and has for years. Granted he is mainly an EM guy but does have a few SS machines, I believe he mentioned Elvira and the PM was his newest machine. Not disputing anything said here but John is a stand up guy and I doubt he would sell a product for pinball machines if he had any formal complaints of his product damaging someones machine.
    TILTed post. Sign in to be able to view TILTed posts.
    #68 6 years ago
    I completely agree with the statement that Novus 2 should *not* be used on a regular basis to clean a playfield.
    #69 6 years ago
    I don't have any experience with Millwax as I'm new to this hobby myself. I have for some time seen a pattern in the "consensus" about Millwax, though. It's generally bashed all the time.
    I recognise this phenomenon from one of my other hobbies, where I have a lot of experience over many years - model airplanes. That's also a hobby that attracts a lot of strange people with different backgrounds. A lot of people in that hobby develop religious beliefs about various things, for instance what brands of fuel are good and which ones are bad. More than 9 out of 10 times you hear convincing testimony that the fuel you use is very bad for your engines, it comes from people who have never used it. They've heard from "somebody" that it's bad, and from then on it is that. Bad. Nothing can convince them that it works okay for you.
    After a while you realize that there are very few people worth listening to. You'll find that if you have a question about propellers, this guy can give you expert advice. If you have a question about a certain motor, that guy knows a lot. And a lot of the time you're better off going with your gut feeling and just finding out for yourself.
    Ask yourself two questions if you are really interested in this.
    1) The very popular pinball parts store Pinball Life sells this wax. In fact, it's the only playfield wax they sell. How come ?
    2) Seeing how "everybody" is so upset with this product, how come nobody takes a piss at Pinball Life for selling it ?
    I'm going to use Mill Wax for polishing my playfield.
    #70 6 years ago
    Quoted from PinHog:
    Because they have a contract with the company, has a "pinball" name on it, and it sells.
    Quoted from PinHog:
    Why would you choose to use a product that contains all these?:
    Why not just use a pure hardwax like Carnuba?
    #71 6 years ago
    Actually, you shouldn't use wax to clean. Do you wash your car every time it's dirty, or use wax on it?
    After my initial shop where I use Novus2 then multiple coats of wax, a dry rag will remove any dirt because it is on the surface of the wax not the surface of the PF. I use a dab of wax to restore and maintain the shine at the same time. Takes only a few minutes and the results are amazing and long lasting.
    But using Novus (especially #3) will remove paint or fog surfaces by itself. It's not a cleaner or wax, it's a polish (As in buffing rouge).
    Correct, Novus3 is a Heavy Scratch remover. I have only used it on two things, very hazed Mylar and polishing balls in the tumbler, makes balls shine like mirrors. Use as the directions indicate, straight lines not circles, follow up with Novus2.
    I have used Millwax, it really did, almost nothing, Novus2 and Carnuba (which cost about as much together as one bottle of Millwax) do a better job in my experience. I have used the Treasure Trove polish kit before, it is amazing. Everyone has different experiences and results. Better products will come out in the future I am sure, in the end it is up to you to use, judge and choose what products are best for you.
    #72 6 years ago
    Quoted from Pin_Crazed:
    Carnuba do a better job in my experience.
    I plan to use Novus 2 and Millwax. Novus 2 for the tougher dirt, Millwax for the lighter cleaning and polishing.
    #73 6 years ago
    Quoted from PinHog:
    Well you just can't argue with logic like this now, can we?!
    Why yes, yes we can.
    I love Pinball Life and order from them all the time. Doesn't mean that everything that they sell is the best for the job. This should be obvious.
    I ordered a soldering iron from them. It is the only one they offered. Honestly, I would have been better off just buying one from Harbor Freight. Their soldering iron works, but it isn't the best, and probably not even the best for the price.
    There could be a million different reasons they sell Millwax, but the mere fact that they do should not be reason enough for you to buy it.
    #74 6 years ago
    Quoted from RobT:
    Pinball Life is not alone. A few of many stores that sell this playfield destroyer :
    Marco Specialties
    Bay Area Amusements
    Game Room Guys
    MAD Amusements
    The Pinball Resource
    Several of them offer no alternatives. I guess they're in a conspiracy to destroy all their customers' machines.
    #75 6 years ago
    I use Meguiars NXT. It is a High Tech polymer. No residue when you wipe it off. No hard buffing with your hands to get it off either...simply wipes off. Super shine and it is safe for clearcoats I am told. Do not use it on anything else unless you check first!
    I have only been in pinball ownership for about a year. I came up with the NXT idea myself since I use it on cars. I am so happy with it on my pins and my pinball bud/expert/friend cannot believe the shine and concealment of scratches on my playfields.
    Just my 2 cents...hope it's worth at least 2 cents
    #76 6 years ago
    RobT says...
    "Pinball Life is not alone. A few of many stores that sell this playfield destroyer"...
    So have you gone to the Millwax website yet? Have you contacted the owner because you've just made a definitive statement.
    #78 6 years ago
    Quoted from TunaSled:
    Remember... if your erection lasts for more than 4 hours, discontinue use of Millwax and consult your physician.
    Best reply ever!
    #79 6 years ago
    RobT says...
    Careful with your quotes there, RobT didn't write that - I did. And I was being sarcastic.
    Like I said earlier, I plan to use Millwax (and Novus 2) myself.
    #80 6 years ago
    I thought millwax was FINE on REAL WOOD.. Just not "synthetic" materials...
    #81 6 years ago
    I forgot to put more info about NXT in an earlier post. I was at work at the time. If anyone is interested, here is what I use. The NXT 2.0. Straight from Amazon:
    <<<Meguiar's NXT Generation Tech Wax 2.0 liquid is an ideal synthetic protectant for modern automobile finishes and clear coats. This formulation goes on and comes off easily without a powdery residue, leaving a deep, wet-look shine. It protects against UV damage, and eliminates fine scratches and swirls, providing a tough polymer bond for durable protection.>>>
    amazon.com link »
    I like this product. I have used it for several years on cars but only about 13 months on pins. No issues so far. Balls runs fast, shine is like glass, lasts for ...hmmm...I am thinking 50-75 games at least but please do not quote me on it. All I know is I usually re-apply anyways and likely too soon! That is just how I am. I can be playing a game or two and all of a sudden I will shut it off and re-apply just to feel good...kind of like relaxation and I really do enjoy maintaining my playfields...lol
    Anyway, I am not picking sides on this Millwax debate...whatever. Each is own. I use NXT and don't see that changing anytime soon (unless I buy a laquer finish pin machine I guess, a non-clearcoat playfield...then yeah, need something new).
    GL and peace all!
    Loverboy...I mean PinballDad OUT!
    #82 6 years ago
    Pin_Crazed said:girloveswaffles said:I wouldn't, however, use Novus on a regular basis. #2 and #3 are slightly abrasive. Using it to get some deep down grime on a rare occasion, maybe.
    Years ago I was told this by a WMS technician. I was also told that you can use light detergents, or even soap and water (lightly applied with a rag) to clean newer play-fields ( specifically clear coated ones) as long as nothing containing Ammonia is used.
    And as I'm posting this right now, I have a Bottle of Novus #3 right here with me
    On the back, top paragraph:
    "NOVUS PLASTIC POLISH NO.3
    Removes heavy scratches and abrasions from most acrylic surfaces. Contains abrasives. Not for use on eyeglasses, polycabonate, or coated plastics."
    Yes. Novus CONTAINS ABRASIVES! Would you also use an emery cloth to clean your play-field?
    This is why you shouldn't use it on a regular basis.
    Of course most of us dont use novus #3 anyways, Simple green to clean, novus #2, then caranauba wax. Mill wax will lift your mylar and dont use it on ramps
    #83 6 years ago
    Not that anyone is interested but if so. I went through this wax thing with madness.
    Switched to collinate and the others are cheese.
    I can get the # if anyone is interested.
    #84 6 years ago
    TunaSled said:Remember... if your erection lasts for more than 4 hours, discontinue use of Millwax and consult your physician.
    Best reply ever!
    Thanks, but the tilt warnings show that the Millwax reps are alive, well and watching this thread.
    Come on, it implies that Millwax is a turn-on! Lighten up!
    #85 6 years ago
    Best reply ever!
    On a related note:
    The use of Millwax itself probably will not cause described side effect, but heavy buffing will. XD
    1 year later
    #86 5 years ago
    Hi,
    I agree that we should be careful when it comes to bashing someone's small business.
    I have had people tell me Millwax is no good. I use it on my machines and I am very happy with the outcome. It IS recommended by Kamoroff, who I have a ton of respect for, The Pinball Resource not only sells it, but recommends it as "their favorite" product for pinball playfields.
    My own personal experience, plus the recommendation of a long time pinball restoration expert like Kamoroff (Pinball Maitenance Guide) and the expert folks at PB Resource is all I need to know to be satisfied.
    To all those who have said, as we move along we find better ways or better products. Moving forward doesn't ALWAYS mean we find better products, sometimes we dupe ourselves or talk ourselves out of stuff. People who have used Millwax on many machines for many years and love it cannot all be wrong.
    PS - Keep in mind one more thing. It was stated earlier in this post that there is Mill Wax and then there is Millwax made for pinball machines. The latter is I believe a home wood or furniture polish, the second is made for pinball machines. I can't help but to wonder if some confusion over the years has caused people to purchase the wrong item and then report that Millwax has melted their brain and killed their family. Maybe they were using the wrong one. Who knows? That's my entire take on Millwax for what it's worth.
    #87 5 years ago
    I think the **hate** for Millwax comes from playfield restorers.
    Because it is a silicone suspended in solvent, it often makes fisheyes in the clearcoat, no matter how much you thought you cleaned the playfield. This makes for extra work, lol.
    I hate buying a game and finding a bottle of it inside the cab.......
    #88 5 years ago
    I've met John, the owner of Millmax. He is a pinhead and would not sell a product that would harm a pin. He is a great guy, owns quite a few EMs. I belive vid is right the restorers hate Millwax, I have heard cfh voice his opinion on this matter.
    #89 5 years ago
    I think it is good stuff and have heard a lot of pros and cons about this product.
    If you don't like it, don't use it. Firkin simple.
    I use it on everything, plastics chrome, balls etc etc, especially the shooter rod and WOW.
    plays like a demon and looks like an angel.
    I suppose it is like SPIT or LUBE, ha ha ha
    #90 5 years ago
    I love the Mill wax, I use it on ALL of my em's . I would not say it has ever done any damage to my playfields or plastics.
    I agree that a nice pure carnauba does a nice job as well I wholeheartedly stand by and would recommend Mill wax to other pinheads. I can only speak for my use of this product on my EM's and early SS pin.
    Mill wax has always worked well for me but as always to each their own,use what make you happy.
    Brian
    Madison hts MI
    586-344-0721
    #91 5 years ago
    I began to use Mill Wax a few years ago before I read negative comments here and didn't know any better.
    I still use it!
    Does what it is suppose to do with no negative results.
    € 279.00
    Displays
    PINBALLSP
    $ 229.99
    $ 229.99
    $ 5,599.00
    Classic Game Rooms
    $ 9.95
    $ 149.00
    Displays
    Boston Pinball Company
    $ 7,499.00
    Gulf Coast Pinball, LLC
    $ 19.99
    Playfield - Plastics
    Docquest Pinball Mods
    £ 45.00
    PinballToys
    $ 225.00
    Professor Pinball
    $ 79.95
    Pinball Photos
    $ 149.99
    $ 78.00
    $ 180.00
    Pinball Customs
    $ 40.00
    Lighting - Backbox
    $ 219.00
    $ 39.99
    $ 200.00
    Professor Pinball
    $ 999.00
    $ 99.99
