Picked up a cheap Judge Dredd (sight unseen) recently that was having issues with the DMD. Well, upon getting the game I discovered tons of mildew growing inside the backbox, the dmd appears to be the least of my concerns.
I have taken all the boards out of the backbox and begun the demildew process but was curious as to if the particular pcb can be salvaged. I noticed a lot of white around the upper right area, and this was still present after a good cleaning of the boards.
I assume it is corrosion or mildew? Is this worth saving, or should I just pick up a new board here soon. (Can't test as of now as my JD is in parts at the moment).
// Error: Image 266209 not found //
// Error: Image 266207 not found //// Error: Image 266206 not found //
DSC02323.JPG// Error: Image 266389 not found //DSC02325.JPGDSC02326.JPGDSC02327.JPGDSC02328.JPGDSC02329.JPGDSC02330.JPG
