B
When I took score reel/timer apart I did not lube anything and left the leather clutches as is. I only cleaned the disc and wiper fingers of old grease and gunk and once cleaned applied small amount of super lube to those. Its not clear, and I was not sure what to clean or lube in the clutch reels and they seemed to be working ok. Thanks for the neatsfoot oil suggestion for the leather washers. What did you clean those with? what other surfaces in that set up should be lubricated? I did clean and lube bearing at each end where shaft goes thru end plates. Not sure at this point I want to take system back out of game and apart unless necessary. I thought when I bench tested it all before going back into box it was fine but clearly did not notice credit reel issue.
Not sure what "top this score" mech looks like or where it would be. I do not have light sockets for star, shoot again, credit or 40. those are just holes in the metal plate. I did start a game and manually hit the credit relay on back door and credit reel did increase. I also played a game that started with top this score at 500 and when I scored over 500 a credit was added.
I did notice some arcing in a couple relays on back door which I did clean?? So this time I took each one apart and made sure they were cleaned (some had pits on the seats) and adjusted to ensure good contact in both on and off states. (included pics) After doing this my credit decrement issues is almost gone. I say almost as I only saw it once in about 6 game starts so more play time needed.
