I bought a very cheap, very dirty Midway Little League pitch n bat EM. Cleaned it out, ran a business card through every contact I could find and it woke up. It will register a credit, but it will not pitch the ball when you hit the button. If you go to the pitch relay and manually tap it, it will pitch and you can swing the bat. But, it will also not score anything ever. Thoughts? I also have a “LOCK” relay with a very short red wire coming off of it that is disconnected, but there is not local terminal to attach it to..... could that be it? Anyone know what an “Alternator step up unit” is? Mine is missing a small nylon arm and the coil plunger. It says “switch operates change over relay”. Any help would be great.
