New! Dark mode!
(Topic ID: 150149)
••• Hobbit & LOTR: Middle Earth GameBlades™ by Tilt Graphics Inc.
By jGraffix
  • 14 posts
  • 9 Pinsiders participating
#1 4 years ago
Tilt Graphics Inc. com
Here's one of our latest creations. Designed to be used on The Hobbit or Lord of the Rings pinball machines. These are custom designed, custom fit and use only the best materials around. Hope you like them. You can see more of our designs on our website www.TiltGraphicsInc.com. We're adding new designs every day.
#3 4 years ago
Link does not work
#4 4 years ago
URL (link) no good.
#5 4 years ago
Sorry about that. Link has been fixed.
#6 4 years ago
That looks great, I'm interested in a few of the other titles you have up but there aren't any pic links.
#7 4 years ago
Can you describe the material? Sticker? Plastic? Installation?
#8 4 years ago
These are crafted with industrial quality Air Egress Vinyl‎, and for an additional layer of protection we laminate them with the highest quality scratch resistant laminate. Essentially these are decals on steroids.
What makes these special is the Air Egress Vinyl. They created with a mesh backing that allows you to easily reposition them on the pin. These inner cabinet decals take all the worry out making a mistake.
#9 4 years ago
Could you please describe in more detail, how they have to be installed. Are they removable without problem in case you warnt to remove them in later years?
#10 4 years ago
Quoted from Zora:
Air Egress Vinyl comes with a micro mesh on the underside of the decal. It's barely noticeable. In fact unless you were actually looking for it you would never notice it. However this mesh allows the decal to initially be repositionable. You simply raise the play field wrap the GameBlade™ (image facing the play field) then slide it down. When the GameBlade is in proper position lightly tap it to the side wall. Walk around to the other side. Make sure you like the positioning. If you're happy with the placement just rub the decal down harder in place. It's just that simple. The most important part of installing these is to make sure you allow clearance for the PLAY FIELD GLASS. Make sure that the decal does not overlap the glass track.
#11 4 years ago
Thank you for your Feedback. That sounds easy.
What about the possibility to remove it after some years. Is that as simple, just tear it off?
#12 4 years ago
Quoted from Zora:
yup
#13 4 years ago
Can you upload some pictures of the blades on a machine? Or, if not, if someone buys them can you upload a pic? Im visual and the price is not minimal so would want to ensure I would want them ahead of time There are others, like on pinballlife, but has a bit too much red for my taste. Thanks.
#14 4 years ago
I think these would look fantastic on TH... Personally don't think they would fit the general artwork look of LOTR.
Either way, cool-looking mod!
5,200
Commack, NY
$ 49.95
Pin Stadium Pinball Mods
