I'm trying to convert some leaf switches (with diodes on them) to microswitches on an 80s game but not really familiar with microswitches. I bought a couple of new ones to experiment with that are made for rollovers on today's games marked NC/NO/NC, so it's like a double throw where depending on the lugs used, the actuator can either complete the circuit when closed, or open it. Has diode across the outer lugs.
So how do I (or can I?) connect my existing two leaf switch wires to this? Same as old switch where one wire goes to lug with unbanded diode end, other wire goes to the center lug? I'm not sure because on the leaf switches the unbanded diode end isn't connected to the switch blades itself, only to a mounting lug for one of the wires. Or am I just trying to use the wrong switch? Thanks!
