The repair guide from http://homepinballrepair.com/ says:
"Microswitches are enclosed and cannot be cleaned. If they malfunction, they may need to be physically adjusted or replaced."
I found that it is not exactly correct, and if you are a cheap b*stard like me, you might be able to salvage an existing microswitch.
I have an old #black-knight that had a number of microswitches with very high resistance readings, varying from 64 Ohms up to infinity/open when the switch is closed.
I simply drilled out the melted plastic holding them together (some can be split apart without doing this),
then take a picture (for future re-assembly),
and finally, I used the business card trick to clean the contacts.
Re-assembly & retest
