(Topic ID: 285514)
Miami beach points given immediatly coint till zero
By Lambecka
8 days ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 5 days ago by Lambecka
#1 8 days ago
My miami beach started during the game with the following problem. As soon as scoring positions are met, it gives the winning point as normally, but as soon it reach the winning points it counts back till zero. Rest of the game is without any problem
Who can help???
#2 8 days ago
Your anti-cheat relay is dropping out. You probably have a short somewhere in that replay circuit. I had this problem on a Bikini years ago, the problem turned out to be on the score unit.
#3 8 days ago
if the anti-cheat unpowers, most of the lights go off and the tilt light comes on.
if that's not happening, look to see if the replay reset relay is powered / staying powered.
#4 7 days ago
Everything works fine and i can continuing playing without any problem , lights works, screen works and als machine give point by winning combination. The only thing it does is that as soon as point are given, it counts back to zero. After that you can play again new game and machine fully resets.
#5 7 days ago
So you are saying the game will correctly add the replays to the meter, and then reset immediately after correct addition? No matter how many are awarded?
#6 7 days ago
Yes thats correct it goes direct to zero again. Then insert coin and you van play withour any problem
#7 7 days ago
payout completes because search index 17B opens and disconnects the start/replay reset circuit for duration of the payout.
most likely anti-cheat relay switch E is connecting wire 56-2 to 75-2 ... manual page 418.
since all the wires on that switch probably look grey, just check switch E and make sure it's doing something sensible. 56-2 is connected to the middle blade, and should only touch the blade with 75-2 when the anti-cheat relay is unpowered, so 75-2 should be on the top blade. If necessary, stick paper between the contacts and see what happens.
if the game is on free play, you may need to check how they did it ... tho I guess you said "insert coin", so mebbe it's not been modified.
#8 6 days ago
Machine is original and not on freeplay
#9 5 days ago
Quoted from baldtwit:
Thanks for pointing me in the right direction, it was indeed the anti cheatrelais causing the trouble.
Adjusting and cleaning and problem solved.
Machine runs 100 procent again,
Very much appreciate your help
Pinball Photos LLC
$ 159.99
$ 48.00
$ 199.00
Lit Frames
$ 19.95
$ 99.99
$ 229.00
PinballBulbs
$ 16.00
$ 45.00
$ 66.95
$ 44.95
PinBoss Mods
$ 119.99
Cabinet - (Alt) Translites
FlyLand Designs
$ 29.99
$ 69.00
The MOD Couple
$ 79.00
Lighting - Under Cabinet
Arcade Upkeep
$ 3.00
Docent Electronics
$ 139.99
Bent Mods
$ 139.00
Sparky Pinball
$ 125.00
$ 349.95
Pin Stadium Pinball Mods
$ 369.00
