Back further in your posts your were asking about slingshots. I have borrowed your pics.
The kicker on the left is classic Stern used in some sort of ball launcher. I cannot remember which pin, though. The one on the right is the classic Stern slingshot kicker. I have learned recently that the washer is a blueprint item. I think it is supposed to keep the spring going cockeyed on the plunger link.
You have replaced those Stern units with the Bally/Williams/ Data East style of kicker. I think you may have used your original Stern pivot mounts. Although, it is hard to see for sure in the pic.
If you have not already done so, you might want to upgrade your pivot brackets with these from Pinball Life. I have used these to replace some worn out units on my Sterns and they work fine. But the geometry is a little different and you must relocated one attaching screw (no exceptions).
https://www.pinballlife.com/williamsbally-slingshot-kicker-mounting-bracket.html
