When I did the coil test the other day, it seemed strange. I swear I'd run it before, and it was very straight forward, 1-20, or whateve rit was, and the coils would fire in order- the targets would go down in order (meteor), but it seems like it wasn't working right. I'll run the coil test again this evening and see what I come up with.
Target #s. No, the numbers printed on the targets are correct, it's the CPU's values of those targets. When you knock them down in order, 1,2,3, on the same target bank, the Test switches go in an odd order, like 21, 23, and then 22. not 21, 22, and 23 consecutively. The middle target switch number is out of order.
I don't recall seeing any acid damage on the board. You could be right, it could be an MPU problem, and the game could be further cooked than I thought, but since it was working (not perfectly, but it was playable) and now, a week later it acts so bizarrely. Such is the nature of pinball machines.
I'll keep plugging away. I have an EBD next to the Meteor. That's my only other Bally/Stern of that era at the moment. I have ancient EMs, and Newer System 11 stuff, but no other boards. Would the system board from the EBD work for this test? I really hate involving known GOOD hardware in swapping situations. When I was a kid I sort of got the idea that boards almost had viruses that could pass from hardware to hardware. Even now I am SO careful when I plug things in not to plug them in backwards, or somehow bend the pins, or any of the dozen other things that can thwart a diagnostic process.
I suppose I could just unplug the speaker for now, It's a cart before the horse type of issue. It's so loud I cant' turn it on to begin debugging it!
Thanks guys. I'll get pics to confirm acid/no acid.
-Brian
