Quoted from pindude80:Ok, makes sense it's scoring the rocket value over and over since the targets are all down and not resetting.
Dropping all #1 targets = outhole fires YES
Dropping all #2 targets = 2nd Meteor E target fires I am pretty sure it's the second E, but would need to confirm
Hit pop bumper = Right sling fires Not sure, would need to check
Hit left sling = Bank #3 resets Not sure, would need to check
Win a game (knocker) = Meteor bank resets Not sure, didn't get this far.
I'm not sure what you mean here and as referencing as being the fix, probably over my head
Am I looking to see if there is a bad connection or cold solder joint at J4 pin 1? Sorry for the rookie question here.
Open your back box.
There are three circuit boards looking straight at you.
Part #1
The board at you upper left is the MPU. You have four connectors that plug into the MPU.
Each connection point on the MPU is labled in several ways.
1) It will tell you which connector you are looking at by using small white numbers and letters. J-4 is the lower left connector on the MPU.
2) It will tell you how many pins are on the connector. J-4 has 19 pins on the connector
3) It will tell you the direction of the pin numbers. On the MPU J-4, Pin #1 is at the top of the connector and pin #19 is at the bottom.
4) All of your connector plugs will have a pin hole that is not being used and a small key/plug is inserted into that empty hole. That small plug prevents you from removing the connector and then screwing up by installing it backwards. You will see a small mark on the the MPU board that tells you where the small key/plug is located. On the MPU J-4, the key is located at pin #14.
So he is telling you the first item you look for is MPU connector J-4 pin #1 is your start point.
The Meteor schematics do not tell you the color of the wire but it is a red wire with white bands painted on.
Part #2
1) The SDU, or Solenoid Driver Board, is located at the upper right side of the back box. Look at the labeling and it will tell you this.
2) On the SDU, the J-4 connector is located at the lower right hand side of the board. It is marked and labeled just like the MPU connectors.
3) While on the MPU the J-4 connector is located in the lower LEFT corner of the board, on the SDU the J-4 connector is located at the lower RIGHT hand side of the board.
4) the SDU J-4 connector is labeled for 12 pins. Pin #1 is at the top. The key plug is located at pin #2.
5) He is telling you that you need to locate SDU J-4 pin #3.
On SDU J 4, pin #1 location is an open hole. It is not used. Pin #2 is an open hole because this is where the key is located. The first pin that has any wiring is pin #3 and that wire is color Red with White bands.
He is telling you are having trouble with your connection along the red/white banded wire between MPU J 4, pin #1 and SDU J-4 pin #3.
If you CAREFULLY cut some tie wraps you will be able to follow the red/white wire all the way across the back box.
