Quoted from raysco:My question is, is this acceptable with an Alltek board, am I likely to damage anything.
It would appear that this sequence of LED's needs a little more current to lock the scr's.
Since the Alltek will run regular incandescent bulbs as well, that are higher current... it should be fine to add a bit more load via resistor at the lamp socket.
Quoted from raysco:I wonder how low I can go with the resistors to achieve the required result.
The answer of course is to go only as low as necessary to stop the flickering, but also keeping in mind that at some point there is going "too low" (and you may need to then suspect a board issue).
With the extra resistor added to the lamp socket, you've got to do the parallel resistor calculation I think.
https://www.allaboutcircuits.com/tools/parallel-resistance-calculator/
Assuming the Alltek resistors are 1k ohm (just a guess, you'd have to check what it is if there's a schematic or via a mutlimeter).So let's say you went with 680 ohms on the resistor on the lamp socket. According to that calculator, it would bring the total resistance down to about 405 ohms. With a 470 ohm resistor at the lamp socket, it would be around 320 ohms.
I'd say keep the resistance above 350 ohms if not above 400 ohms. Excessively low total resistance values on the circuit will cause excess heat and part failure. Anything under 200 ohms total resistance for sure, but I wouldn't shoot for anything lower than 350 ohms total resistance (after doing the parallel resistor calculation) and would personally aim for a bit higher than that even.
This is just an example, I'm not 100% certain if the resistors the Alltek uses are 1k or a bit higher/lower.
