Finally have gotten around to doing a Meteor PF swap. A couple of drop targets were in bad shape so I ordered a full replacement set from Marco. Installed with no problem but the targets are short. Bottom of each number and letter is below the pf when targets are set. I don't see any way mechanically to adjust them higher. Measured one against an original and sure enough, the the small tab that catches when the target is set is shorter than on the original.
Anyone else have this issue? If so, did you find a solution?
