(Topic ID: 134253)
Meteor Club - "We will let you know when the danger is past"
By pinballholder
5 years ago
  • 1,743 posts
  • 165 Pinsiders participating
  • Latest reply 1 day ago by Pinball_Nate
  • Topic is favorited by 80 Pinsiders
  • Meteor Stern Electronics, 1979
There have been 453 images uploaded to this topic. (View topic image gallery).
There are 1743 posts in this topic. You are on page 28 of 35.
#1351 10 months ago
Quoted from KSUWildcatFan:
Woooah. That allows getting rid of the entire stupid assembly? $44 well spent.
Plus you gotta buy all the twist sockets. It's about $80 all together. Well worth it to eliminate the unreliable sockets.
#1352 10 months ago
I've got a lot of random flickering (ESPECIALLY with that stupid center bank of lights), even with LED adapter boards installed. I assume I probably need some board work done but those sockets also suck. Looks like I'll be ordering some parts.
#1353 10 months ago
Meteor is a special case with LEDs. I had to add resistors to 11 lamps even after adding the seigecraft anti flicker kit. 8 or 9 of them were in the bonus count area. It's a good idea to make sure your lamp driver scrs test good, but I suspect you just need some extra resistors to sort that out.
#1354 10 months ago
Quoted from treborlicec:
Certainly possible. From what I saw it was randomly scattered nonsense, aside from that center bank which altogether just sucks to begin with: One of the star rollovers, the spot meteor target, the "R" light near the spinner, maybe a few others.. but most others worked fine with LEDs and the anti flicker boards.
That said, I've also done zero board work on this game since I picked it up from someone's personal collection (it had sat unplayed for quite some time, as with the other three games I got from her) so I would not be surprised in the least if some SCRs and other misc things needed addressed. For example, my sound only goes up to a point and while being plenty loud for playing, it's absolutely nowhere near the output I can get out of my space shuttle.
#1355 10 months ago
I think I had 3 or 4 bad SCRs in my LDB on Meteor. And a broken trace on the back I had to fix. Common from battery corrosion dripping down. It's hard to know for sure if a dead lamp is a crappy socket or a bad SCR or in some cases, the wire feeding from the socket back to the LDB. Had a couple of those on Strikes and Spares. A quick test of the resistor theory would be to add one temporarily and see if one of the problem lights stops flickering. With those aftermarket lamp pcbs, it was easy to add resistors. I just tucked them under the ears/tabs on the twist socket and boom.
#1356 10 months ago
Good advice. I've got some pretty awful hackjob wiring "fixes" to address at some point as well, but it's down on the list with hardtopping my high speed (already torn down) and eight ball deluxe (fully working but plays like absolute trash right now) and represents only one of three games in my collection right now that's even worth playing. Hate having to just deal with some of this but I'm kinda drowning in all the stuff I need to do, lol
#1357 10 months ago
I think we all deal with it. I had a plan to do the LED conversion on mine. Did the full conversion at once. GI and controlled and put the seigecraft in there. Several were flickery and I undid the controlled lights and contacted seigecraft. He explained about Meteor and some early M200 games having this issue due to low voltage. So, I figured I wouldn't attempt the LEDs again until I got those aftermarket pcbs and addressed the SCRs.
10
#1358 10 months ago
Added the 7th digit.
#1359 9 months ago
Quoted from semicolin:
Probably a header issue. Get the manual on IPDB, and identify which connector on your solenoid driver board goes out to your outhole kicker. That pin is probably garbage.
Circling back to say thanks. Reflowed the solder on the header and it took care of it.
Meteor pop bumper question: where does the pop bumper cap with the red star first show up? It isn't on the flyer. Did all games ship with the star on the cap or was that introduced later?
#1360 9 months ago
Quoted from A_Bord:
As far as I could remember... Yes.
The only thing that really changed was the drop targets...
Meteor OEM was all "tomb stone" style drop targets.
The "M,E,T,E.O,R. drop targets were prone to break.
When ordering replacement drop targets from the distributors...
The new drop target design came into effect.
That is why, some times, you see a mishmash of drop targets on Meteor.
#1361 9 months ago
Has anyone successfully put LEDs in their meteor, ive got some anti flicker boards installed and when I put LEDs in the controlled lights they flicker like crazy if they even work...
Need some suggestions please.
#1362 9 months ago
Quoted from Y3AG3R:
I've successfully converted mine to all LED using the Seigecraft anti flicker boards. Now, initially, I did have some issues. First thing, those old sockets mounted to the plates can be problematic. Also, make sure you check all your SCRs on the lamp driver. I had a couple flaky ones and a broken trace. Even after all of that, with Meteor in particular, you will have to add an additional resistor to some of the lamps. I think I had to add 8 or 9 resistors on mine. I also did away with those old metal lamp socket clusters and used these:
https://pinballreplacementparts.com/products/stern-meteor-set-of-lamp-boards-to-replace-the-old-metal-ones
#1363 9 months ago
Lots of flickering with mine even with the boards. Check the SCRs, ours are both most likely shot.
#1364 9 months ago
New Lamp boards and sockets are on the way. I also ordered some SCRs because I had to order some for my Baby Pac Man also.
I am really tempted to order the individual lamp boards and sockets for my baby pac also. They are a nightmare on the early games, later games switched to a larger lamp board but I am stuck with this...
Would be even better if this person made the board for Baby Pac (let me know if you are listening lol)
#1365 9 months ago
I think I'm converting my eight ball deluxe to bayonet when it gets hardtopped. Those early/mid 80s Bally sockets can ESAD
#1366 9 months ago
Hi all. Can anyone point me in the direction of a place to buy a shooter rod? It is different to the spares I have.
Thanks in advance.
Got my machine back yesterday and just tweaking it - hoping to post some finished pics up later.
#1367 9 months ago
Pics
#1368 9 months ago
Beautiful! I really love how meteor looks.. And plays!
#1369 9 months ago
CPR had Meteor playfields up as "printing now", but I noticed today they are no longer on the site. I was definitely late to the game, but curious if anyone got a purchase e-mail from them? Probably gone already....
#1370 9 months ago
Quoted from Pin-up:
I signed up for them, twice, and haven't heard a thing.
#1371 9 months ago
I haven’t either, I had preordered one also.
#1372 9 months ago
I preordered as well, no idea why they've disappeared from their website. Hopefully it's only an oversight when updating the preorder page as my game needs one badly. In fact I only bought it knowing CPR were releasing a playfield sometime soon.
#1373 9 months ago
I am new to this post, does anyone know what would be the best replacement spinner part for Meteor. I see that the original Stern ones are very hard to come by.
#1374 9 months ago
Quoted from Pin-up:
Quoted from Coyote:
Quoted from Y3AG3R:
Quoted from Pinballer73:
They are still in process. I don’t know why they aren’t on their site anymore either.
https://pinside.com/pinball/forum/topic/catacomb-club/page/18#5356523
Post #871.
#1375 8 months ago
Quoted from bcrage88:
Try Pinball Resource. They have a Bally spinner that is beefed-up. The spinner is white.
They may have one that is unpainted and you can paint/decal the spinner yourself.
#1376 8 months ago
Who has the best replacement drop.targets nowadays? Saw Marco's has a set with the decals. Also saw classic arcades has a hot stamped set? My game has different ones. Some hooded and others non-hooded?
#1377 8 months ago
Quoted from Multiball33:
The non hooded drops are NLA. The hooded and non hooded are interchangeable.
#1378 8 months ago
Quoted from Lovef2k:
#1379 8 months ago
Pbr has hot stamped, but both my sets from them were warped.
#1380 8 months ago
Quoted from zacaj:
Did you tell Steve? I'm sure have corrected that for you.
#1381 8 months ago
After I got the first set, I contacted them, and they sent another set.... that was also warped. Between the two I was able to at least get one set together that was only sorta warped and still at least worked, so I gave up
#1382 8 months ago
Quoted from zacaj:
That sucks. You would have thought that they would have made sure the second set was straight. It must be the way they are storing them or crappy plastic. I have gotten their's before without issues.
#1383 8 months ago
I see the new playfield are listed on cpr. Just ordered mine.
#1384 8 months ago
Quoted from nocreditdot:
Were you on the preorder list and got an email?
#1385 8 months ago
I was on pre-order list, got an email last night and just ordered mine
#1386 8 months ago
Yes I was on the preorder list. I have been waiting for this for quite some time!
Quoted from ita47:
#1387 8 months ago
Eagerly awaiting the email to place my order.
#1388 8 months ago
I am also on the pre-order list and also eagerly awaiting the email. I was put on the list March of last year. I am praying they get to me before they run out.
#1389 8 months ago
Quoted from ita47:
Got my e-mail yesterday and ordered it yesterday as well. This is going to rock once that's installed! Looks to be the last title that will be silk screened at all. Total transfer to digital printing now. They also updated the "pre-order" section on their site today to say that it's an obsolete process and all of the botique titles will now be made in digital form, as they all have the art ready to go. Much longer message in the pre order section on their website, and is worth a read!
EDIT: just got my shipment notification tonight. Awesome!
#1390 8 months ago
i haven't had an email and I went on the list last January...
#1391 8 months ago
hae any of you guys got a different email address for CPR? I've emailed preorders and kevin at
Neil.
#1393 8 months ago
Quoted from NeilMcRae:
neilmcrae fyi my name was on the list as of March 31 2016. I got my "CPR ** METEOR Reproduction Playfields ** Boutique Zone List - Instructions" email on Jan 12 2020. I assume you may have to wait a few weeks to receive your email.
#1394 8 months ago
money burning hole in pocket
#1395 8 months ago
Well meteor is not on the playfields list and they shut down their preorders section. I didn’t get an email about my preorder (granted it was July 2019). Wish they would be a little more clear about how many they have.
#1396 8 months ago
They're nuking the preorder process as it's obvious they have no idea how to manage it.
#1397 8 months ago
Quoted from Y3AG3R:
"We will be emailing notifications to Meteor Inbox respondants, in orderly waves of 10-20 a week, until everyone is contacted, or every playfield is gone (whichever comes first)."
Hang in there, it may take a few weeks to get your email.
#1398 8 months ago
The wait was worth it and finally over!! In photos, my restored PF on the left, CPR on the right. Very pleased with the PF. Smooth clear with no flecks or boogers. Wood thickness and dimensions are consistent to original. Major cutouts for flippers, slings, drops and pops are very consistent to the original. I verified by placing the CPR over the original and I can see all cutouts aligned very well.
P1170114 (resized).JPGP1170115 (resized).JPGP1170116 (resized).JPGP1170117 (resized).JPGP1170118 (resized).JPG
#1399 8 months ago
Thanks for the pics. It's always nice to know in advance that things line up.
I wonder why CPR decided not to put the rubber ring sizes on the playfield? It doesn't matter to me as you can't see once plastics are installed... just wondering Mine should be here next week.
#1400 8 months ago
I'm still waiting for my shipping confirmation I got the order confirmation and verified that they got it, but I also ordered a Stars backglass at the same time to save on shipping costs. Hoping they don't sent me a meteor glass by mistake!
I ordered on Monday as soon as I got the email.
$ 7.00
Displays
PinballSolutions.eu
Third Coast Pinball
$ 9.00
Cabinet Parts
Third Coast Pinball
nvram.weebly.com
$ 100.00
The Flipper Room
