I have changed the eos switch after adjusting it 713 times. It seemed to work for a while. I also changed the flipper/plunger assembly that attaches to the flipper bat and goes into the coil. Last night I changed the coil and sleeve (second sleeve). The coil stop is hammered and I have a new one but I gotta drill out one of the holes to accommodate 1 larger screw. The mounting plate seems weird too with one small hole and one large. the coil itself seems to move quite a bit more than the other two flippers too and there's a hack on the coil connection wiring which just looks like a jumper because the wires were getting too short. I'm guessing this has been a problem for years. I don't see any capacitors anywhere either. A couple of questions. does anyone know where to get a new mounting plate? does anyone have a picture of what its supposed to look like under there? the lower right flipper works fine so I am convinced its just in that whole assembly. I would gladly buy a new one and be done with it or do a total rebuild if I can find the plate. I cant have this game out of commission or I will never get laid...
