This is a warning to all Metallica owners. LE, pro, doesn't matter. There's an odd case where lifting the playfield with the coindoor open may cause the sparky coil to short on and burn up.
This problem happened to me on two separate machines. First on my pro. I was working on the game and heard a click. Thought nothing of it. Coin door open so high power disabled. A minute or two later I see massive smoke. Sparky seems to be on fire. The coil behind him is burning up. Power off the machine, power it on and immediately the coil locks on. Disconnect the coil, test it with meter. It's not shorted. Test the transistor, it is also not shorted. Also find it baffling because the coin door is open and this kills all the high power. Hook the coil back up. Go close the coin door and fire up game, everything is fine. Everything has been fine since. I figure this must be some fluke so I don't worry about it.
Few days later. I'm working on a different Metallica. An LE this time. Open coin door, lift the pf, hear the same click. Same coil locked on with coin door open, different machine. Again test the coil, transistor, nothing shorted. With the machine on and coils locked on, push the coindoor interlock switch (which reenables high power) and immediately the coil disengages and has been fine ever since.
So the warning is to all you Metallica owners. If you work on the game listen for this problem. If it happens try just shutting and opening the coindoor again. It seems to be related and solves it.
