New! Dark mode!
(Topic ID: 187126)
Metallica pro grave marker issue - Solved
By Soulrider911
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by Soulrider911
#1 3 years ago
Hey guys I was playing my new Metallica pinball tonight and something unfortunate happened. I knocked down 2 grave markers and was going for the 3rd. I hit a slow roller up the graveyard and the ball got stuck on the 2nd marker as it appears to not retract enough into the play field any suggestions
#2 3 years ago
Usually with drop targets there is a screw under the playfield on the drop target mechanism that you can use to adjust the height of the target.
#3 3 years ago
I had to do this with my metallica.
#4 3 years ago
I have a different issue
The first marker is stuck down
The machine cycles at the start of every ball
Trying to raise it
But it stays stuck down
I have also noticed a small wear Mark on the bottom left corner of the drop target
Any ideas what might be making the marker stick in the dropped position
(And sorry for high jacking the thread)
#5 3 years ago
Soled thank you guys, I adjusted the screws to lower them slightly more
Back Alley Creations
Trade
Machine - For Trade
Blacklick, OH
