There is no adjustment for this unfortunately and the jaw lock mechanism isn't exactly very robust either. One alternative that some have done is placing washers under the mechanisms which is what I did. To make re-assembly much easier, I secured the washers in place with a bit of CA glue. I used 2 washers which totalled about 1mm in spacing. I also used washers on both mechanisms so everything works like it did before. There's 4 tapping and 2 machine screw locations to shim.
Sorry, I didn't take a before picture, but here are the results. I think it's a very good improvement.
Rob
