(Topic ID: 275299)
Metallica Premium: F7 Fuse Blows As Soon As You Start A Game
By xbmanx
1 year ago
  • 22 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Bellagio
#1 1 year ago
Any help here would be much appreciated.
My game was working perfectly and then something weird happened with the coffin magnet during game play.
After that I noticed that the coffin magnet wasnt working. I investigated and saw Fuse f7 blown so I replaced it. Started another game and blew another F7.
I opened the game up and the switch that was on the magnet mech that i ASSUME tells the magnet mech to return home was super loose. I tightened it up. I put another F7 fuse in. This time I started a game and F5 blew. I replaced it, started another game and F7 blew again.
It seems that F7 blows as soon as a new game is started and the ball kicks into the shooter lane.
Any ideas? THANK YOU!
#2 1 year ago
Shorted wire at the magnet connections, bad diode or bad transistor on the board. The manual will tell you which transistor is associated with the magnet. If it’s not a broken or shorted wire, which you should be able to see, most likely the transistor has failed. Test one of the other working transistors with a meter and see if the one associated with the magnet reads the same.
#3 1 year ago
Quoted from Lermods:
Is that something that’s fixable or is it a magnet board replacement situation?
#4 1 year ago
Quoted from xbmanx:
they are all fixable, if it’s one of those three things I mentioned. I have a pro so not familiar with the magnet board.
#5 1 year ago
Thanks. Wish i was a bit more competent right now
#6 1 year ago
Is it weird that there is no technician alert indicating an issue?
#7 1 year ago
Quoted from xbmanx:
No, blown fuses don't trigger alerts. Typically, bad switches trigger alerts.
#8 1 year ago
I have a little more info. I disconnected the black wire that leads from the magnet board to power the magnet in the coffin.
When I start the game now the fuse doesn't blow. Does that mean the magnet card is bad, or does it mean something on the magnet mech is bad?
#9 1 year ago
My guess is the magnet is shorted. Get a meter and put it in resistance and measure across the two leads and report back.
Now why is it shorted will be the real question. A blown transistor will melt a coil and cause that.
#10 1 year ago
Quoted from pintechev:
Sorry to sound dumb but in pinball tech i am...
When you say sounds like the magnet is shorted, what exactly are you referring to? Is that the magnet board? or the actual paper wrapped magnet at the top of the mech?
Also if i put it in resistance, wont that just blow another fuse and not allow me to test it since it won't work?
#11 1 year ago
I have more information on the problem. I really started diffing and notice that the white resistor on the board was detatched from the board on one side. I took the board out and soldered it down. I put the board back in started the game up when I start a game I hear the buzzing of the magnet and then the fuse blows and it stops so it almost seems like something is telling the magnet to be on. Is the magnet card just totally shot?
#12 1 year ago
The transistor is likely shorted to ground which is telling the magnet to always be on. Test the transistor and see if it’s open.
#13 1 year ago
And for the magnet, just test across the two leads on the magnet connector itself. Unplug it and test for resistance across the two pins.
#14 1 year ago
I did a continuity test on this and it beeped
#15 1 year ago
I wish i better understood what this means. Can you point me to a resource on testing this? Does changing the magnet board fix this?
#16 1 year ago
The transistor on the board is ultimately what turns on the magnet. Given what you found, it sounds like the transistor is shorted internally. Basically it's like a switch that's stuck on. Replacing the board should fix it as long as the magnet itself is ok. The fuse most likely prevented damage to the magnet, though.
#17 1 year ago
Quoted from xbmanx:
It’s supposed to beep don’t test continuity. Test for resistance.
#18 1 year ago
Quoted from xbmanx:
Changing the magnet board may fix it. But you’ll want to know for sure the magnet coil is still good or you’ll blow the new one. You should be able to search here or google to learn what you need. Take your time, lots to learn.
#19 1 year ago
Quoted from frunch:
So, I happened to have another magnet board. I popped it in and it works fine now. This doesn't explain why the other board went bad but the magnet works and doesnt blow any fuses.
#20 1 year ago
Here’s a good thread on the topic:
https://pinside.com/pinball/forum/topic/metallica-hammer-magnet-board-melts-resistor
This thread includes info on replacing the transistor. It’s probably not a bad idea to replace it on your broken board in the event you have this issue again.
#21 1 year ago
Quoted from Bellagio:
Interesting and thanks for the share. Just buy those 2 parts and solder them on?
#22 1 year ago
Yep, should be pretty easy fix.
