Hi all, after a bit of a break from owning a Metallica (pro) I'll soon have a Premium
In the U.K there's not really much choice with regards to mods and so will likely have to order from the U.S (although next month my wife and I will be in Canada (Toronto and Montreal) on holiday, so am considering ordering some things and having them sent to our hotel there to save on shipping cost etc)
One thing I've noticed however is that there's not just one site which has everting I'm looking for, so thought I'd ask for advice here in case I've missed some good mod websites, or to see if anyone has any of the following spare which they might want to sell?;
Snake teeth (the Prem. I'm getting doesn't have any snake teeth)
Right ramp snake decal/revised plastic above the snake
3D snake mod (I gather this was a limited run by a pinsider and so have missed out?
Coloured Gel inserts for FUEL gauge
Cap/Wires for Sparky (ideally ones which light up during sparky hits)
Speaker lighting kit (round speakers)
Grave marker/Cross under PF fittings for the Grave marker inserts (so that the light doesn't bleed outside of the cross shape)
I think that's it. I've already ordered a colour DMD (LCD one - will use the dots mode(s) to get as close as I can to an LED look), shaker and some plastic protectors etc.
I also have a couple of questions re; the Premium model, as have only played one (well, an LE) in tournament scenarios:
If you've Physically locked 2 balls in the Coffin and you start Sparky Multiball (which is a 3 ball MB IIRC), as there are only 4 balls installed in the machine (correct me if I'm wrong), or if it's a 2 ball MB and you add-a-ball - do the physically locked balls exit the scoop from the Grave? (if so, I take it lights are then used to represent the 2 balls which were previously physically locked, like aon a pro)
The PRO I used to own came with incandescent bulbs, but it was really easy to swap bulbs out to LEDS; is it just as easy on a Premium?; I wasn't sure if on a Premium the LEDs are circuit board mounted or something.
I used to like putting a different colours flasher beneath the Grave marker on my PRO, as wasn't a fan of the red flashing. My PRO also came with pink FUEL lights, which was also cool.
Many thanks
