(Topic ID: 50762)
Metallica owner's thread
By swampfire
9 years ago
6 key posts have been marked in this topic (Show topic index)
There are 20,674 posts in this topic. You are on page 414 of 414.
#20651 15 days ago
Quoted from finnflash:
Now you need a colordmd
I have one.
#20652 15 days ago
Quoted from snakesnsparklers:
Correct. And once you do this I believe the bonus song is then unlocked in the song select menu. I've owned my game for years and still haven't managed to complete 4 CIU modes
Yep, I only did it once and unlocked The End of the Line. Now that song appears as part of the overall song menu and is selectable just like the other songs.
#20653 14 days ago
Quoted from Anony:
Go into switch test mode and see if any switches are being triggered on their own. Bumping the machine around a bit to see if vibration is causing anything helps,
Use your hand to manipulate the switch in the shooter lane (the ball sits on top of it when it's in the shooter lane) to see if it triggers properly and isn't opening when it is depressed.
I would test all switches in the game - targets, flipper buttons, rollover switches, sling leaf switches, optos, etc. Look for the switch matrix in the manual. It will be a grid showing all the switches in the game so good reference. Another indication that a switch is triggering is if you get points without doing anythign.
+1 on banging around the pf to see if any switches trigger. Optos can get flaky where they work fine in testing but randomly trigger under vibrations.
#20654 14 days ago
Quoted from Anony:
+1 on the magnetization. Also don't trust any type of test to see if they are magnetized just change them and see if it helps. I was never able to detect any magnetization on my balls but changing them solved this issue for me.
Just use a small metal piece. That’s what I do. It’s almost impossible to tell it if not.
#20655 14 days ago
Quoted from Gunnut40:
I can start to tell when my balls get magnetized when multi-balls are going on and they seem to follow themselves straight down the middle and I'm not kidding.
#20656 14 days ago
Quoted from Roostking:
Yeah it might just be one ball. Doing that.
#20657 14 days ago
IMO, if one is, they all are, or soon will be. I go ahead and replace all at the same time.
#20658 14 days ago
Metallica Related, not pinball, finally got a pair of these shoes from the Metallica store!!
Patience pays off!! Next time I’ll get the ankle versions.
#20659 13 days ago
Quoted from zermeno68:
get another pair, put one under each leg of the machine. Boom, you just invented bottomers, your machine is now 2k$ more valuable.
#20660 13 days ago
Quoted from Acronymicon:
Wow you just gave me a million dollar idea... truck nuts for pinball! Watch them swing as you nudge and tilt your way to grand champion.
#20661 9 days ago
I have a few leftover ninja magnet I designed for my MET coin door . If anyone is interested , please pm me
#20662 9 days ago
Selling a Pro translite $50 and DMD display $150 if anyone needs them.
Translite: https://pinside.com/pinball/market/classifieds/ad/150575
DMD DISPLAY:
https://pinside.com/pinball/market/classifieds/ad/150574
#20663 8 days ago
Will have the Metallica flipper button protectors available shortly in my Pinside store for sale, preorder link is below. They will be $80US for the pair plus shipping. They are attached with three screws and have an insert that fits under the lockdown bar. Very easy installation, fit over the flipper buttons and under the siderails. Only need to remove the lockdown bar to install. Comes in clear or metallic lettering.0B8F9A1B-9A51-46A8-854A-3F8D5636BF05 (resized).png
If you have any questions, please PM me. Cheers.
https://pinside.com/pinball/market/shops/1448-pin-music-plus/07667-metallica-flipper-button-protectors
CA987A6F-C6CE-4E46-866A-C9730D121F87 (resized).jpeg2742D15F-08F7-4418-9853-31FD14EB365E (resized).jpeg
#20664 7 days ago
beautiful! Preordered.
#20665 3 days ago
My Pro today let's the ball loop on the plunge without holding the left flipper, it no longer stops at the top lanes. Haven't had a chance to look yet, but Any idea?
#20666 3 days ago
Quoted from Hayfarmer:
There’s a setting to disable it iirc, might want to check that first.
#20667 3 days ago
Haven't been into the settings in a long time, but ill check there first. Thx
#20668 3 days ago
Check if one of the two leads going to the coil for the post has come loose.
#20669 2 days ago
Quoted from Bundy:
Or it may be the hot wire that is daisy chained from another coil that came loose at the other coil.
You could start by simply checking the diverter post in the coil test.
#20670 2 days ago
Connections are fine, won't fire in coil test. Been told it's most likely a transistor or diode. Thx for the responses, appreciate them
#20671 2 days ago
I’d bet money on a transistor. I’ve replaced a few of them already as they don’t seem to last. So far I’ve swapped the snake eject, both slings, and the flippers for failure or weak action.
#20672 2 days ago
Quoted from OutlawTorn304:
That's my next step. Always hope for an easier fix ,
#20673 2 days ago
They aren’t to bad to do, takes longer to pull the board than it does to swap them out.
#20674 14 hours ago
What are we doing to keep this ball guide from bending inward? I’ve replaced a few now and it’s always bent studs that go through the playfield.
$ 54.99
Shooter rods
Filament Printing
Other
Armor and blades
This page was printed from https://pinside.com/pinball/forum/topic/metallica-owners-thread/page/414 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
