Quoted from Sparky:You should only need to remove the plastic over the drops. Feed the wire through the hole to the left of the flasher behind the cross. From the underside, remove the bayonet holder of the flasher. Replace the flasher with the one they provided, and I think you need to connect the cemetary wire to the new flasher wire (it's been a while, but I think there are tiny connectors). Replace the plastic, but before putting on the nuts, put the cemetary on the threaded post and secure with the nut. I believe only one side gets secured? Can't remember. Be careful when securing. The 3D print material is vulnerable and will break if you secure too tight.
Hope that helps.
That’s about spot on. After I looked at the instructions again and looked at the game itself it wasn’t bad at all. I didn’t even have to remove the plastic. Just the one nut to hold the cemetery gate down. I was able to fish the wire where it needed to go and then used the alligator clips to connect to the existing LED flashers
