(Topic ID: 50762)
Metallica owner's thread
By swampfire
7 years ago
  • 17,646 posts
  • 987 Pinsiders participating
  • Latest reply 1 day ago by Monk
  • Topic is favorited by 370 Pinsiders
There have been 3,031 images uploaded to this topic. (View topic image gallery).
5 key posts have been marked in this topic (Show topic index)
There are 17646 posts in this topic. You are on page 352 of 353.
#17551 63 days ago
Quoted from Pinoffski:
I made some like this.[quoted image]
I can recommend these they work perfectly
#17552 63 days ago
Yes thank you very much. I could not find any mention in the manual whether it's a #89 or #906. I found the hole yheceuring goes through and the work required to get to it that I now might not bother to change it. But at least I know what to order if I do decide its worth it. Thanks
#17553 58 days ago
Just picked up a Premium Roadcase. Freaking love this game. Anyone know where I can get a set of the neon yellow pinbits plastic set? Their site shows sold out. Anyone else laser cutting these things? Any other recommended mods for the premium. Has Pinblades and shaker motor and I will order a Color DMD that's a must for me.
#17554 58 days ago
Quoted from IdahoRyan:
A friend in the UK does them: https://www.colspinballmods.com/shop/metallica-pinball-plastic-protectors-copy/
Col's a great guy - talk to him! But you might find others closer to home.
Get that ColorDMD sorted ASAP - such an improvement.
I quite like subtle mods, like the snake fangs, and speaker lights/inserts from Doug @ http://www.speakerlightkits.com/
#17555 58 days ago
https://pinside.com/pinball/forum/topic/metallica-owners-thread/page/351#post-5636796
But he's in australia
#17556 58 days ago
What are your thoughts on PIN2DMD for Metallica? Is the conversion 100% complete? Thanks for the advice.
#17557 57 days ago
Quoted from MJR8peanut:
the end of the line scoring gets really crazy. the super jackpot for me was a 1 billion shot (under 4x). you can lock balls in the snake like normal multiball but this time every time you do it adds a ball instead of just the first time. and 4x playfield is super valuable. if i had 4x for the collect the final shot would have been 12 billion points. also, your super jackpots are based off of what you did in the 4 previous crank it ups
How many extra balls do you have yours set for? Mine on location is set to 1 extra ball and I do that to all of my games that don’t award them at random (like some of my System 11’s do). So far the closest to End of the Line is somebody starting a 3rd CIU. I have been as far as doing 2 and having the 3rd lit.
#17558 57 days ago
Quoted from embryon:
I dont believe Australia is shipping international right now. I have an item I ordered from Mr. Pinball that has been "Cleared and awaiting international departure" since April 3rd
#17559 57 days ago
Quoted from Pin_Guy:
Yup, I have mods coming that have been tied up almost two months.
#17560 57 days ago
Quoted from yzfguy:
#17561 57 days ago
yep, a 1-1/2 months here as well. my parcel from rtbb still hasn't left australia
#17562 57 days ago
Get an external sub. that is the #1 mod to do!!
#17563 57 days ago
Sorry guys wasn't aware of such delays. I got something coming from you guys, looks like it could be a long wait too.
#17564 56 days ago
Ok. I'm stuck here.
I am trying to replace the magnet core, but the nut will not come off. The whole core moves but the nut is on for good.
What am I missing to remove this?
I read about heating it up, but not working.
#17565 56 days ago
You need a lot of torque.
#17566 56 days ago
Try the shock/impact method to break it loose. Put a wrench around each nut, hold the assembly carefully on its side or put it in a vice and whack the nut that spins with a hammer. That’s what I’d do.
#17567 56 days ago
Put an impact on it.
#17568 56 days ago
Quoted from finnflash:
Ok. I'm stuck here.
I’d spray some pb blast on it and let it soak for an hour. Then give it another shot.
#17569 56 days ago
Quoted from Roostking:
Get the pinwoofer system- bit of a pain to install but the results are fantastic and nice clean look with better sound all around
#17570 56 days ago
Quoted from zpinman370:
100% agree with this, the pinwoofer kit blows away the external sub.
#17571 56 days ago
The post is slow everywhere..even local postage
Due to the current situation we are all in though out the world....
items are held for 14 days before they are touched from what I have been told ..
I have a item that is coming from the uk and it has been 2 weeks so far ..
Some items arrive early than expected it is just the luck of the draw atm
#17572 56 days ago
He is flat out processing orders atm ..
Even owe local postage take a few weeks due to the current situation we are all adjusting to
Be compliant to the no touch service that is required for the current situation that we are all in atm
You might find that it will arrive before you receive a tracking number..
#17573 55 days ago
Work in progress but I think it's coming along nicely. I have a few ideas on lighting and painting ideas on the go. So if ok will post as they come to along
#17574 54 days ago
Does anyone know the Pinbrowser request numbers for the tunes that play post game when your score comes up and also the one for when entering a high score?
#17575 52 days ago
Does anyone know where I can get a replacement data cable other than direct from Stern (can't get in touch with them because of the pandemic)? I've been trying to fix the strobing GI issue with no luck. I've replaced the rectifier twice, reseated all the connecters, searched for bad bulbs and am going to order a new 3 pin connector today from pinballlife.
Is the data cable a "specialty item" only available from Stern or can I find it elsewhere?
Also, should I put new connectors on the four 2-pin plugs that attach to that GI board in the middle of the playfield?
Thanks for any help!
#17576 52 days ago
Quoted from dgposter:
What's your gi setting at 50% or higher?
#17577 51 days ago
I've played around with that setting a lot. When I turn it down it does stop the strobing, but only temporarily. It always comes back regardless of the intensity, sometimes within minutes.
I was reading another thread where someone was having the same problem and it seemed to be due to having too many extra lighting strips and mods tapped into the GI. That could definitely be my problem as well. Off the top of my head I have the following:
under cab lighting
custom backbox lighting with multiple led strips
lighted snake eyes
lighted snake mouth
lighted fuel target bank
led strip under left graveyard plastic
lighted translucent targets using 3 comet opmax bulbs
lighted topper (not sure if this is tapped into GI)
I'm going to try to disable these to see if I still have the strobing. Are there other folks who have a number of GI lighting add-ons that are 'not' experiencing strobing issues?
For the record, I have inspected the GI board and the 3-pin connector. They appear to be fine, but I will replace the connector once it arrives from pinballlife and I'm still on the hunt for a replacement data cable.
#17578 51 days ago
under cab lighting
lighted snake eyes
lighted snake mouth
not sure where you got the back box and undercab lights, but those almost certainly are not tied to the GI (likely 12v) and would not be causing the issue you describe. the other mods you list draw very little power, but what I would do is unhook all of them and see if the strobing persists. If it does, you know it's not the mods. If it doesn't, add the mods back one by one to see when the problem begins.
#17579 51 days ago
Quoted from Lermods:
Good idea. BTW I'm very suspicious why the factory setting on gi is 50%. To me that means stern knows of the problem and really are pressed for the solution. I reckon the gi intensity setting has solved the issue on most games so stern consider the rest effected as inconsequential.
#17580 49 days ago
Hope I'm not annoying people posting this stuff but here's my first painted and in position prototype of the coffin that covers the ball hop plastic. I did make a mistake in painting under the lid black and then realised I covered the cross. Sanded a good bit of it off too let the light through again. Currently it turns on and off with the white gi.
#17581 49 days ago
Looks way better painted dude!! And as long u like it.. then deadly
#17582 49 days ago
Is there a way to turn down the shooter eject on this game? I didn’t see it in the menu and it ejects into the shooter lane kind of violent, I’d like to tone it down.
#17583 49 days ago
Quoted from Dee-Bow:
Thank you very much.
#17584 49 days ago
How I'm not annoying people posting this stuff but here's my first painted and in position prototype of the coffin that covers the ball hop plastic. I did make a mistake in painting under the lid black and then realised I covered the cross. Sanded a good bit of it off too let the light through again. Currently it turns on and off with the white gi.
Pics never give you justice on how it looks like in person...
Very smart looking Metallica
#17585 49 days ago
[quoted image][quoted image]
Now it’s time to paint Sparky! My favourite of all time mod, it really changes the game for me and makes it more personal.
#17586 49 days ago
Quoted from Indusguys:
I was just thinking this morning. I have an air compressor kit that came with a paint sprayer and about three more month's time on my hands. I may watch a bunch of YouTube videos and learn how to air brush.
12
#17587 47 days ago
Feel like I’ve reached the “End of the Line” in a different way. Joined the club with a 2017 Pro about two weeks ago and just finished reading through all 352 pages (17586 posts) this morning.
Lots of fun banter and a wealth of information. Shoutout to s_vares for the local parts hookup and hottubr for connecting me with him.
#17588 46 days ago
Quoted from tbpd349:
Lots of fun banter and a wealth of information. Shoutout to s_vares for the local parts hookup and hottubr for connecting me with him.[quoted image]
tbpd349 that is deduction... I plan on doing the same thing, HEAVILY MODDED Pro is coming home Friday!
#17589 46 days ago
Quoted from pinballbrat:
It's dedication too!
#17590 44 days ago
I would possibly reinstall the guard just to install this mod!
#17591 44 days ago
Thanks very much, I'm currently refining it via painting, cross size variations, led colour etc. Also looking at what could be done for the pros where it has three leds to indicate ball locks?
#17592 44 days ago
Keep it up. I have an LE so ill be watching!
20
#17593 40 days ago
I finally broke 1 billion and got to End of the Line! Not such an amazing feat, but pretty cool for a mediocre player like me. I thought I’d only get that far by taking the glass off.
#17594 39 days ago
I'm thinking about putting my Metallica Pop Vinyls as toppers on my pin. Possibly something like this?
#17595 39 days ago
Looks great. U gonna be selling them?
#17596 39 days ago
Please no.
#17597 39 days ago
Quoted from Spelunk71:
Mediocre? Give yourself some credit. That's an amazing feat. I can put up some decent scores on games but still have not got EOTL or anywhere close to that score. You have to make a lot accurate shots to get that far.
#17598 39 days ago
Agreed. Those are goofy looking. MET needs a badass topper.
#17599 39 days ago
Quoted from jawjaw:
Thanks, dude. Unfortunately, I kind of choked in EOTL itself and couldn’t bump the default high score off the board. Kind of hurts, but now there’s something else to shoot for! Quarantine has been good for my pinball skills I guess.
#17600 39 days ago
Quoted from Hayfarmer:
If it turns out well then yes I'd be in on that. I'll post my final designs when done. Thanks fir your interest btw
$ 24.95
