(Topic ID: 50762)
Metallica Club - Ride the Lightning!
By swampfire
10 years ago
  • 21,667 posts
  • 1,177 Pinsiders participating
  • Latest reply 2 days ago by Rampmaster
  • Topic is favorited by 427 Pinsiders
7 key posts have been marked in this topic (Show topic index)
There are 21,667 posts in this topic. You are on page 348 of 434.
#17351 4 years ago
Quoted from j_m_:
takes 2 hits on mine as well (I'm still running 1.70 code), but the game even has a call out when you hit it the first time (after dropping all 3 in-line targets) and the playfield lighting goes blue on the premium/LE
Must be a code setting or possibly 1.7 being different. On mine its 1 hit after the drops for first mb, then 2 hits on 2nd mb, etc.
#17352 4 years ago
Quoted from RobF:
I finally have a fully functioning prototype
Uhhh YES PLEASE!
#17353 4 years ago
Quoted from Dee-Bow:
Have you installed the newest code? It seemed to take two hits to start graveyard mb.. it should only be one hit after the drop targets are down
Quoted from j_m_:
takes 2 hits on mine as well. (I'm still running 1.70 code)
You are both right. On 1.80 it changed. From the release notes;
- Changed default cross hits from 2 to 1.
I am on 1.80 code, but the video starts on the 2nd MB of the game that's why it shows taking two hits. I also show it starting on the 3rd MB to demonstrate that the logic understands the different starting scenarios. It should work correctly regardless of the game settings or variances in code version.
#17354 4 years ago
Very cool mod for us METpro peeps! Well done Rob!
#17355 4 years ago
Anyone know where I can get individual plastics? Have a cracked plastic on the back left that got caught on my mirror blades...
#17356 4 years ago
I am on the latest code and it still takes two hits for mine. I would be in for a raising cross if you are gonna make them orderable.
#17357 4 years ago
Quoted from RobF:
After several months of this project sitting on the shelf, I finally have a fully functioning prototype of my MetPro rising cross mod. It is a few 3D printed parts, a servo, and a control board. It's plug and play as far as connecting to the target opto board and the cross LED. It needs a few tweaks and a lot of play testing before it's done, but I was excited to share a video of it in action.
I've gotta have one of these. Put me down for one once you have it ready to go!
#17358 4 years ago
Count me in too.
#17359 4 years ago
Quoted from hoby1:
Count me in too.
Yes me as well - better ramp up production it should be a good seller
#17361 4 years ago
Creeping death light mod. Yay or nay?
Cant tell whether the light mod is tacky or awesome from the youtube videos. Also not sure how much of a nuisance it would be when cleaning the playfield.
Getting the art blades regardless.
#17362 4 years ago
Quoted from IdahoRealtor:
I thought the pinstadium lights make it obsolete? You don't have to see those fixtures, but you have flip the pinstadiums out of the way when lifting the PF.
#17363 4 years ago
I like it. You don't notice the rails much. Shouldn't be a problem for cleaning.
#17364 4 years ago
Quoted from Neal_W:
Thanks for the suggestion. I like that those are less obstructive, but otherwise am not a fan of Pinstadium. Strictly considering the creeping death rails.
#17365 4 years ago
Quoted from Neal_W:
Oops. Double post.
#17366 4 years ago
I have the gi strobing issue that I have solved by turning down my gi intensity setting to 40%. If I reseat the data cable and/or the power connector to the gi pcb I can sometimes adjust the setting to factory 50 and even up to 55%. But it is unstable and the flicker returns not long after.
Is there something I can do to address this and actually fix it?
I also found that if I want to connect a led strip to a gi globe it will strobe both the strip and gi's. I need to reduce the gi intensity to 18% to stop the flicker.
Ideally I'd like to be able to set the intensity to whatever I want, even 100% without strobing.
Any ideas please? Met premium monster led version.
#17367 4 years ago
Quoted from embryon:
Replace bridge rectifier located in the backbox lower left corner. It fixed GI strobing issue on mine. Use a 400V rated one.
#17369 4 years ago
Everyone I worked on that had this issue was due to a burned power connector.
#17370 4 years ago
Thanks guys will look at all options
Re cable did you replace or repair BTW?
#17371 4 years ago
Quoted from legui:
Does that mean you could increase the intensity of gi passed 50% without strobing?
#17372 4 years ago
I did not change GI intensity settings in the menu. If I'm correct, GI intensity is set to 100%(factory settings). No strobing anymore after replacing BR.
Before replacing BR:
https://www.dropbox.com/s/eyk2qae97a0apg6/GI%20strobing.mp4?dl=0
After:
https://www.dropbox.com/s/p651rhm9t2n35x9/GI%20fixed.mp4?dl=0
#17373 4 years ago
OK not going to say problem solved but I reseated the connections on the bridge rectifier and I could definitely on rease my gi intensity to around 80% but was a little instable
But at 60% it works fine. So will test for a few days before considering this a fix and then will try replacing it with a 400v to see if I can get stability in the higher settings.
Thanks again guys will keep you posted
#17374 4 years ago
So, I installed translucent drop targets to replace the MET grave drop targets. I’m going to use an LED strip to light them up and make them glow. However, the drop targets are not working now? I wrapped electrical tape around the tab where the opto is, so the opto would work correctly. I tried the same technique with my deadpool translucent drop targets I installed and it worked great. However, the MET translucent drop targets don’t pop up at the start of a game or if you knock them down. Any idea what the issue could be? I was very careful with putting the drop target mech back together exactly how it’s supposed to and double checked that all the connectors are plugged in. Thanks for any help you can give me...
#17375 4 years ago
Quoted from Jimmyhonda:
It may not have enough reflection for the opto to know it is down. I have an LE that I bought new, had issues with the targets registering. Instead of getting a new board, I put some chrome vinyl on the target so it would reflect better. Targets have worked perfect ever since. I am thinking the black that you installed isn't reflecting back well enough.
#17376 4 years ago
Optos do not work by reflection. Opto will trigger when receiver does not see the light beam. It should be easy to test if opto is working or not by manually blocking the light beam with something in switch test. If optos are not working then it has nothing to do with targets.
#17377 4 years ago
Quoted from jawjaw:
In general this is right, but is not correct for the drop target optos on Met. The sensor board uses proximity sensors that do work on reflection back to the receive sensor that is on the same chip package as the transmitter.
#17378 4 years ago
Quoted from RobF:
So, what is the fix? Remove the electrical tape? Thank you.
#17379 4 years ago
Quoted from RobF:
Ah, I see. Good to know if I ever have problems with the targets. Is this still something easy to test?
#17380 4 years ago
Try that, if that doesn't work, add a small piece of chrome vinyl where it should bounce the signal back.
#17381 4 years ago
My suggesting would be first to put the game in switch test, raise the PF, and with the targets up, put your finger over one of the sensor spots and make sure things are reading correctly. Once you confirm that, you can start playing with the targets to see what it will take to trigger. My guess is that maybe they don't have the right fin for this specific game. Can you compare them side by side?
If it is because of the translucent material, then I would try with a white blocker of some kind, not black. Try some white-out, white paint, white paper glued on, maybe some tin foil? Also make sure the blocking fin is as close as possible to wear the sensors are reading.
#17382 4 years ago
Quoted from jawjaw:
Yep, easy to test. The sensor board attaches to the drop assembly with a plastic mount. On that mount, there are three round cylinders that surround the proximity sensors and extend through the metal target bracket to isolate the sensor's reading. As I mentioned, you can put the game in switch test and just cover these holes to check if it is reading. If it is too much of a pain to do that, it's two easy screws to remove the sensor board and cover the sensors with your fingers directly.
The only bummer is that the sensor parts themselves are obsolete. I found this out the hard way when working on my rising cross circuit and I killed on of them. I was hoping to replace components on the board, but the sensors are unique, obsolete and way out of stock. Board replacements are still available, but I don't think they can make any more of them without a circuit redesign.
#17383 4 years ago
That was it! Thanks Robf and others. I took off the electrical tape and mounted white paper on the opto plastic pieces. Works perfect! Thank you!! I can’t wait to light these drop targets up now!!
#17384 4 years ago
I want to connect a led strip to one of my gi's. What type do I need to purchase 6v Ac or DC. Thanks
#17385 4 years ago
Met GI is 5.7 VAC.
#17386 4 years ago
I bought some 2 months ago. Easy install and a bargain. I wish they lit the blades up more than they do but Metallica has a lot of ambiant light going on.
#17387 4 years ago
Quoted from Viggin900:
Did u go with the creeping death rails or pinstadium?! I'm thinking of making up a set of the poor man's pinstadiums! I find the C-D rails an too obstructive and always an eye catch when not on.. they do look radd when flashing tho!
13
#17388 4 years ago
Best score yet.
#17389 4 years ago
Quoted from lpeters82:
Best score yet.
Speaking of best score, yesterday, I first got to EOTL and got a decent amount of points, ending up at about 2.6B. Then I relit CIU, and when I got back in there, it put me right back at EOTL. This time around though, I played for a few minutes, and finished EOTL, but got very few points, maybe like 20M. Can anyone explain?
#17390 4 years ago
Does the Dirty Donny premium have any difference in value as compared to the other premium version? Thanks.
#17391 4 years ago
Quoted from pinballjah:
Never heard of a Dirty Donnie premium. Are you talking about the difference between the Monsters and the Road Case?
#17392 4 years ago
the dirty Donny premium has a hand painted sparky, snake and hammer (by the man himself) in what is otherwise a monsters premium game
#17393 4 years ago
Quoted from j_m_:
Thanks for confirming. After buying an Iron Maiden and Metallica, have decided to keep the Metallica! Game rocks!
#17394 4 years ago
Quoted from j_m_:
Wow, if that's what this is, I would say it is worth more for sure!
#17395 4 years ago
Who sells the sparky helmet mod?
#17396 4 years ago
Quoted from Electronmagic:
Mezel Mods used to sell them but I don't see it on their site at the moment.
#17397 4 years ago
Hi folks
We have a new Mod for MET available if anyone is interetsed.
https://www.pingraffix.com/product-page/metallica-pin-plate-coin-door-mod
-Joe
Screen Shot 2020-03-22 at 10.22.41 PM (resized).pngScreen Shot 2020-03-22 at 10.22.41 PM (resized).png
#17398 4 years ago
I have been waiting for something like this ever since I saw the kick ass ones on Pirates!
Also would be interested in a KISS one.
#17399 4 years ago
Please dont take this the wrong way, I love Cliffys products, but ive gotten a lot more lazy shots into the scoop since taking the cliffy out . Happy I tried it out.
#17400 4 years ago
Quoted from jandrea95:
I agree with you, I have this on mine since day one. https://mantispinball.com/product/metallica-protector/
Chrome Candy
$ 26.50
$ 22.50
$ 149.00
7,600 (OBO)
$ 12.95
$ 29.95
$ 69.99
$ 93.00
$ 160.00
Sparky Pinball
7,000 (OBO)
Ronkonkoma, NY
$ 69.99
Downers Grove, IL
SilverBall Designs
YouBentMyWookie
$ 69.99
7,000 (OBO)
Elgin, OK
$ 1.00
Mitchell Lighting
$ 16.00
Slap Save Creations
$ 68.50
SilverBall Designs
SilverBall Designs
Filament Printing
Pinball Z
$ 7.00
Pinball Z
$ 29.95
$ 19.95
SilverBall Designs
$ 69.99
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/metallica-owners-thread/page/348 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
